APC BP1100 4 YRS OLD. JUST STARTED. ABOUT THREE OR FOUR TIMES A DAY IT STARTS TO "CHIRP" AND THIS GOES ON FOR ABOUT FIVE MINUTES A QUITS ? ? ? SUSPECT SOMETHING IS STARTING TO GO. BUT WHAT ? NEEDS A NEW BATTERY ? THANK YOU, DAVID 'C'
    Scholar:
  • 89 Answers
It's battery. That's usually a low battery alarm. You need a new battery and possibly the internal software reset. You need an RBC6, check shopping sites, figure $80 for low end.
Posted on Oct 29, 2008
I have a small alarm clock with model # alck-487 and three buttons M, S, D. i can't find the right combo of push and/ or hold to change the time. can you assist?
ALCK-487 reset time:
Press M three times, you will see the seconds flashing.
Then press S once to adjust minutes, press D,
press S a second time to adjust hours, press D,
press S a third time to adjust date of month, press D,
press S a fourth time to adjust month, press D,
press S a fifth time to adjust day of week, press D,
Then press M to end settings.
Mar 11, 2014 | Audio Players & Recorders
Hi we have a 720 Magnavox flat screen tv that is about 5 years old. When i went to turn it on the other day the picture started flasing and making a chirp noise.. and won't fully
power supply problems does it have a separete power supply if so you can try to change or if you have someone with the same you can ask to try it.if its internal power supply it needs to be fixed.
Aug 20, 2012 | Magnavox 37MF437B37 37 in TV
Have a GE Profile bottom-freezer refrigerator, model #PDS22MBSBWW, serial #RL053351, approximately 5 yrs old. It has recently started making a "clicking" sound which goes on for anywhere from 1...
For the clicking if the fridge has been off for at least 5 min. and clicks when it tries to start then it may be the start relay on the compressor . If it does not stay off for at least 5 min then it may be the control which may also be why your display is not working.
Nov 30, 2010 | GE Profile PDS22MBS Bottom Freezer...
I have an A5 clipper, with three blades. I have had difficulty with this clipper, ever since I bought it. I have a schnauzer with very fine, soft hair, a bouvier, with very thick hair, and a Lakeland...
hi, on some ocassions when the clippers get hot the metal gear shaft moves meaning the movement of the clipper is limited, you can remove they gears in the gearbox when its hot and see if there is any side to side movement.
Nov 26, 2010 | Oster Golden A5 2-Speed Universal Motor...
My mom & I each have a Craftsman garage door opener at our respective homes & live @ 15 minutes apart. Our openers are about 13 to 14 yrs old. The past two yrs. we've both had the same problem. ...
If the main light flashes 10 times when the door reverses to the open position it is a door sensor problem. Make sure both lights on the sensors stay on and don't flicker while the door is moving and the sensors are firmly attached so they don't move. Tweak them just a bit.
Nov 09, 2010 | Sears Craftsman LiftMaster Chamberlain...
Turns on stays on five minutes works great then goes on standby
These tv is famous for high voltage it dead or cold solders to it FBT.The flyback transformer,a big black block of plastic with a red wire with a cap hook to the CRT(tv tube).U know how to solders? Take the tv aparts resolders the FBT.Or tries press the power button on/off couples times,if u get a picture.Don't touch it let it on,for three or four hours.Let the heat from the electricity to Amp up the heat,might solved this problems,without resoldering.
Apr 21, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
How do i reset the tpms on a 08 implala SS after a tire rotation,without a owners manual
You have two minutes to match the first tire/wheel position, and five minutes overall to match all four tire/wheel positions. If it takes longer than two minutes, to match the first tire and wheel, or more than five minutes to match all four tire and wheel positions the matching process stops and you need to start over.
The TPMS sensor matching process is outlined below:
  1. Set the parking brake.
  2. Turn the ignition switch to ON/RUN with the engine off.
  3. Press the Remote Keyless Entry (RKE) transmitter's lock and unlock buttons at the same time for approximately five seconds. The horn sounds twice to signal the receiver is in relearn mode and TIRE LEARNING ACTIVE message displays on the DIC screen.
  4. Start with the driver side front tire.
  5. Remove the valve cap from the valve cap stem. Activate the TPMS sensor by increasing or decreasing the tire's air pressure for five seconds, or until a horn chirp sounds. The horn chirp, which may take up to 30 seconds to sound, confirms that the sensor identification code has been matched to this tire and wheel position.
  6. Proceed to the passenger side front tire, and repeat the procedure in Step 5.
  7. Proceed to the passenger side rear tire, and repeat the procedure in Step 5.
  8. Proceed to the driver side rear tire, and repeat the procedure in Step 5. The horn sounds two times to indicate the sensor identification code has been matched to the driver side rear tire, and the TPMS sensor matching process is no longer active. The TIRE LEARNING ACTIVE message on the DIC display screen goes off.
  9. Turn the ignition switch to LOCK/OFF.
  10. Set all four tires to the recommended air pressure level as indicated on the Tire and Loading Information label.
  11. Put the valve caps back on the valve stems.
Aug 31, 2009 | 2008 Chevrolet Impala
Lint alarm sounds after three to four minutes use
Open the back of your dryer and clean out all the dirt. Ours had an old rubber glove reducing the air flow which we removed. We closed the cover on the back of the dryer and have operated more than six months without incident. We lived with this problem for two years before we cleaned 'er up! Now, all is well with my soul.
Jan 05, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Erratic beeping
This is a signal that the battery is dying, and is failing the self-test. According to Conext, the battery replacement alarm goes off for one minute every five hours. You should also see the replace battery light on the front of the unit lit. Changing the battery should solve your problem.
Jan 01, 2009 | APC Conext 900VA (cnb900) UPS System
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
