Question about Kodak Easyshare Printer G600 Thermo Printer
Printer fails to feed paper for printing
This is a fairly new Kodak G600 Easyshare Printer, which has suddenly started to fail to feed printing paper, after properly loading for months of use and hundreds of prints.
Try gently rubbing the take up roller with a damp cloth - let dry and try with no more than fifteen or twenty sheets of paper in the feed tray
Posted on Nov 03, 2008
Windows vista wont allow Kodak G600 printer to print pictures using easyshare program
Hi lomls3,
Are you using Kodak Easyshare ver8? If not, you may need to update the software in order for Vista to send the print jobs to the Kodak G600 printer.
Update the software to ver 8 first. Reboot the computer and retry printing.
Ver 8 can be downloaded here: http://www.opendrivers.com/driver/293165/kodak-digital-camera-kodak-easyshare-software-update-8.0-windows-2000-xp-vista-win7-free-download.html
Hope this helps.
Andrew
Apr 04, 2010 | Kodak Easyshare G600 (1633379) Dock /...
Prints only top half of picture
Can you print anything from WORDPAD or MSPAINT or NOTEPAD? try printing a website. if it continues to do this, then it could be a paper sensor on the printer, and that means, a failed printer.
Aug 28, 2009 | Kodak EASYSHARE Printer Dock Thermal Photo
My G600 easy share G600 will not pick up the paper to print my pictures
Try to take off the paper tray of the printer dock
Get a damp lint free cloth and clean the rollers on the printer dock
try to print again
Aug 10, 2009 | Kodak Easyshare Printer G600 Thermo...
Kodak Easy Share printer dock will not print pictures
If you have too much paper in it, the paper will stick and you will get a false reading.
Aug 09, 2009 | Kodak Easyshare Printer G600 Thermo...
Kodak #G600 printer dock/roller won't pull paper through
I read this solution to a problem someone else was having which was similar to my problem. I wiped off the roller with a damp cloth, made sure it was dry and that's all it took to allow the roller to be able to start to pull the paper through. - thanks for the help!
May 27, 2009 | Kodak Easyshare Printer G600 Thermo...
The paper is not feeding into the printer straight. And sometimes jams. The paper jamed when I tried to print onthe back side of a sheet of paper.
if its an inkjet printer then please mark that the catridges are able to free scroll on the carraige and if they fail then remove the catridges take a clean piece of cotton clean the foil which connects the catridge to the circuit , this worked for my HP 3940,
Mar 04, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
5300 won't load 8 1/2x 11 photo-weight paper.
''grabber'' roller out of work sometimes, you may try
1) there is a input paper sensor around roller, the roller out of runing if the sensor is not senitive enough or sensor switch dirty,
clean the sensor as you can find it,
2) Lighter-weight paper feeds and prints fine, which means this paper input sensor works ok, but you need to make sure they are same paper input sensor,.
3) the paper surface bright and the roller worn could be cause paper feed fail, you need clean the roller anyway. still not fixed, you need to adjust the roller pressure by increase the spring force.`
Feb 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Lines on print
check your paper guide and then run through it's maintenance test. then run another test paper.
Jan 05, 2009 | Kodak Easyshare Printer G600 Thermo...
Easyshare 5100 not printing on correct side of paper
Load a single 8x10 page and press Copy + Cancel until the printer feeds the paper. It will spit it out blank. Try printing another photo. Make sure Kodak logo faces up when you load it
Jul 12, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Printing problem
make sure center feed rollers are aligned, clean with alcohol, then it will grab paper instead of slipping. Worked for me.
May 13, 2008 | Kodak Easyshare Printer G600 Thermo...
Kodak Easyshare Printer G600 Thermo Printer Logo
249 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
