Question about Medion M3 Composer 5200 PC Desktop
PC hot temperature reading on speedfan software
Do you know anything of the Speedfan software download?
i recently downloaded it and temp reading #3 reads 128 degrees celcius this worries me mildly. if you know what temp #3 is in this software could you let me know wut it is reading?
should i be worried in the first place?
keep in mind that this software reads temps in the pc and one of them (#3) read 128 degrees celcius!
this was a free download that i thought may be useful. and a high temp reading worried me. if you think you have any comment in the least, could i please hear it.
  • 796 Answers
This temp is normal...not anything to worry about this..
it is serious if it goes above 180 degree...
even if reaches 150 mark the replacement of the heat absorbing PASTE in-between the processor and the heat sink will solve this for you
thankyou
Posted on Oct 29, 2008
    Problem Solver:
  • 11 Answers
Hopefully you fixed anything you had to by this time since the posting ,but just in case .It might be a good thing just to remove this program from your pc if the site where you downloaded the software also has things for sale that can help fix the heating problem for you. Many of these sites will have the free download give false info so the consumer buys their product .which by the way comes with some additional software which cancels out the thing that trigger the heat reading in the first place. So all you end up paying for is a driver that removes part of the free download.so the warning wont pop up anymore.
I hope this helps many consumers as this is the same thing many companies do especially many of the free antivirus programs on the web that miraculously finds a billion things wrong with your pc in about 30 seconds.Then want to sell you the full version that cant remove these imaginatory viruses and worms which in many cases are programs you purposely downloaded anyway that contain some kind of ads.
Posted on Dec 07, 2008
    Genius:
  • 1,226 Answers
Can you identify that #3 which read 128 degree celius?
However, you can identify what parts is overheating by going open the cpu of the pc and then switch on and touch those you suspected parts.
however, on the other hand, thats maybe a software bugs because if you really convinced that your system is very functional then you have to stay to it.
melnavz
What is engine work temp for a honda blackbird with town driving
128 degrees c (260 degrees f) should be way to hot for that engine. It should probably be at max 210-220 degrees F. Listen for the cooling fan to run when its running hot.
Mar 29, 2014 | 2004 Honda CBR 1100 XX Super blackbird
I ve recently bought an Audi A6,2.7 litre with twin turbo from japan.The problem i ve is, when this car is idling the coolant temp rises to 110 degrees celcius and drops to 90 when its moving.The other...
when stationary their is no air flow through the radiator so temperature will rise and the cooling fan comes on ,now as for it not going off then this could be a sensor ,relay or the computer as the sensor tells the temperature to the computer which turns the fan on and off ,now on these cars the fan will stay on for up to 5 mins after turning the engine off so if after this time it hasnt gone off then consult the dealer as you have bought a asian market software vehicle so it will not respond to a code reader to locate any faults just like the europeon version but the american version can be read with a code reader .
Apr 12, 2012 | 2002 Audi A6
My leptop acer aspire 4732z , my leptop is more heaving and very slow and auto shutdown ,and hardisk more heating plz solve my problem
Most likely the machine is overheating, it could be the fan is not running normally but just to make sure if its hardware or software I suggest try to diagnose your machine and you can try this steps.
1. Follow this link to download Speedfan: http://www.almico.com/speedfan443.exe
2. Open and install Speedfan.
3. Launch Speedfan (this usually takes at least a minute to start).
4. Observe the temperature readings you receive. If your temperature readings are above 60 degrees Celsius or higher, especially when the computer is idling, then your laptop is running too hot. If your laptop temperature is below 60 Celsius, then leave Speedfan running and check on it periodically to see if the laptop is heating up (whether idling or in use).
If you are sure your laptop is overheating, then there are a few stopgap measures that you can employ:
1. Place the laptop on top of a cookie sheet.
2. Place laptop on edge of table so that the air vents on the bottom of the laptop are not being blocked.
3. Use a standing fan and turn it directly on the laptop.
Ways to fix laptop from overheating:
Follow this link for pictures and text explaining the next several steps. http://www.insidemylaptop.com/disassemble-acer-aspire-5610z-laptop/
(The laptop model used in these pictures isn't exactly the same as yours but it should be close. Don't worry, this process isn't that difficult, and you won't have to go any farther than removing the cooling fan.)
1. Turn off laptop, unplug laptop, and remove the battery.
2. Unscrew all panels on the back of the laptop.
3. Remove RAM, Hard drive, and cooling fan by following steps 1-8 on the linked website. Skip removing the DVD drive (step 6).
4. Using compressed air, a vacuum cleaner, or an air pump, blow air into the now open compartments in the back of the laptop.
5. Blow out the dust and dirt in the cooling fan.
6. Reassemble and turn on laptop.
7. Run Speedfan and monitor your temperature.
If your laptop is still running hot, then either employ the stopgap measures or take the laptop to a laptop technician. The laptop technician can take your laptop completely apart, reapply thermal grease to the CPU heatsink, and blow out more dust and dirt.
Good luck, thanks for using FixYa.
Apr 24, 2011 | Acer Computers & Internet
I can't get the Drivers or the nvidia control panels to identify the video card and then it freezes my computer and locks it up when i get the HDMI output to work. the DVI outputs sometimes work now....
New Nvidia drivers have recently been released, this may solve your problem.
1) Go to the Nvidia website and choose the following info from the boxes.
Product Type: GeForce
Product Series: GeForce 9 Series
Product: GeForce 9800GX2
Operating System: The Operating System that you intend on using with the card.
Language: English (US)
2) Then click Search.
It should come up with v260.99 drivers which are around 80.4MB.
3) Then click Download.
4) Once downloaded, install the drivers and try with the 9800GX2.
If all this fails then the lock-ups could be caused by system heat levels.
Go to CPUID and download their latest Hardware Monitor tool.
If the card reaches anything over 80 degrees celcius under load then you should be worried. I'd suggest making sure your case has adequate air flow and enough case fans.
If the card is not reaching 80 degrees celcius and it still locks up then you will need to try it on another system just incase the card itself is faulty.
Jan 17, 2011 | PNY GeForce 9800GX2,, PCI Express Video...
I can't change the temp. reading from celcius to regular temp.
Check the manual, you have to hold down Ambiant and the Temp Up button for 5 secs or something.
Jan 15, 2009 | 2002 Hyundai Santa Fe
ASUS P5VD2-MX Temperature label on speedfan
Hi dutchdj, speed fan software is not perfect. If you look on the motherboard, use your manual & go to page 1-6. You'll see there is a power connector in-between the memory & the main MB power connector. The 3-pin connector closest to the upper right hand of the board is for the CPU fan. The 3-pin power connector under the CPU fan connector is for the MB fan. You seem to have this covered. You are correct. There is no other 3-pin connectors for additional fans. (I went over your manual), your good!
It is possible that your software is trying to monitor the graphics card fan. I wouldn't worry about it. The temp 41c-44c is still within normal temp. If you want to help lower the over all temp, suggest you add 1 or 2 side case fans. These will bring in fresh air onto the MB & help cool CPU, MB, video & hdd's. I did this for my Asus & it has helped allot.
Check out this site if you want to add more case fans;
http://www.xoxide.com/casefans.html
Link to Asus;
http://www.asus.com/products.aspx?l1=3&l2=11&l3=0&model=1200&modelmenu=1
Your fine dutchdj!
Good eye.
Mike
Jan 14, 2009 | ASUS P5VD2-MX SE Motherboard
Sony VAIO GRT170 laptop fans wont run.
Overheating usually happens when the fan is not coming , therefore when the computer overheats.Or the fan is not cooling enough and computer is overheating.
Monitor computer temperature using a software, check if Fan is coming up when temperature gets critical.
If fan comes up but does not cool enough, then replace the fan, it is not efficient anymore because of a bad bearing or dust. ~Also ensure that fan is well mounted, if fan has poor contact with CPU surface , cooling will be poor.
If fan does not come up, and critical temp is not detected, then the sensor on motherboard is bad, this is very uncommon. When this happens the problem is usually related to system or power settiings , rather than overheating.
If fan does not come up and temp is critical, then fan is faulty, replace it.
There are also more than one fan on many laptops, check that one of the fans (CPU fan, video fan) is not completely ded, and therefore cause for the problem.
By using the software below you can also find out if the problem is really overheating. If temperature results within normal range, then usually it is not overheating.In that case test systtem and check power saving settings.
Here is the software to control your fan and temp. sensor state:
Download SpeedFan - Access temperature sensor in your computer
Download SpeedFan 4.38
SpeedFan - Free software download
Nov 03, 2008 | Sony VAIO GRT170 Notebook
My Emachine T5212 has a loud fan constantly running
sounds like a fan is going out .. with the case open can you identify which fan is making the noise?
Mar 10, 2008 | E-Machines eMachines Desktop PC
Abit eq software
Does it vary? If it changes, it's probably a bug. If it stays static, it could be either. Try installing a different version, ask ABit Support, check the forums, etc.
Sep 30, 2007 | Abit KN8 Ultra Motherboard
Abit EQ Temperature Monitor
If SpeedFan is showing the correct temp for the same sensor, and that temp varies, then it's an ABit EQ bug. Frankly, I've never been impressed with the latest round of Windows software that ABit/Asus/etc. have been bundling with their motherboards. I suspect they're outsourcing the development, and the programmers are better at "pretty graphics" UI's than solid functionality.
Medion M3 Composer 5200 PC Desktop Logo
416 people viewed this question
Top Medion Computers & Internet Experts
John Anderson
John Anderson
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
