Question about RCA F32650 32" TV
Blue screen the screen is blue and says unusable signal. I've tried everything but no response. When I hook up the cables for cable television still no response
    Champion:
  • 252 Answers
First , auto program you tv ,if still the same , your tv need to re solder. if you know how to solder,. Solder the tuner the jungle ic and system ic, but be careful of short circuit.
Posted on Oct 29, 2008
Says unusable signal when correctly connected to Sony blue ray? Help
I can only guess that you have the cables hooked up improperly .or the input not set to the proper setting
Feb 13, 2016 | Sony Televison & Video
Lcd tv goes blue screen
Blue Screen usually means you have no video source, but also it can be a bad cable, bad signal, or week signal. I will try to hook it up to a dvd and test it on another source. However the screen should be all blue aand not blue lines, if you can email me a photo of the screen I will be able to properly address it.
Tony Mitri
goldtekfl@hotmail.com
Feb 15, 2014 | APEX Digital Inc. Apex Digital 32" 720p...
I have a Mitsubishi VS-50604. The sound is working but the screen is blue. No picture. What is the problem?
andychen993,
Depending on how you have your unit hooked up you may have a switch in the wrong position or not have a signal to the TV. Blue screen is the option if no video signal is present. Is your audio going through an amplifier? If so check all the signal feeds to verify that you have a signal going to the TV.
The easiest way to check this would be to hook a DVD up directly to the TV using a separate audio and video cable. If you still have a blue screen I would go into the menus and see if the settings are correct for blue screen.
If everything checks out ok then you probably have a bad small signal board and will need to replace it.
I have a tip at http://www.fixya.com/support/r4425498-basic_standard_tv_troubleshooting which could be helpful to troubleshoot your unit. It explains how to troubleshoot a dead TV but the procedure is the same to isolate a defective board.
Thanks for using FixYa and for the generous rating. We supply these answers for free.
hardrocko
Aug 21, 2010 | Mitsubishi VS-50604 50" Rear Projection...
Unusable Signal Message
I can;t keep my DISH satillite to turn on. when I turn the tv on and hook up the cales i get unusable signal and blue screen
May 21, 2010 | RCA TruFlat 27F520T 27" TV
Can i hook up a ps3 without attaching the cable? My son wants to use the tv mainly to play video games and later as a PC monitor. Do I really have to run another cable through the house just to get a...
No you dont need cable the game consoles can hook right to the t.v. Try hitting t.v video and seeing if its on another video channel. also make sure all of the rca jacks are hooked into the in on the t.v
Mar 11, 2009 | RCA L22HD31 22 in. LCD HDTV
Says unusable signal when trying to hookup my Nintendo 64.
Here are a couple of things to try. Go into the menu and make sure that you have the "ANTENNA" selected instead of "CABLE". Also make sure that the channel that you are using (3 or 4) is programmed into the memory of the tv. If not, use "auto program" in the menu to program the channels.
These newer tv's are not the same as older tv's. If none of that works, put a antenna amp on the output of the nintendo and then plug it into the tv. This should fix it.
Nov 17, 2008 | Televison & Video
Screen remains blue with "no signal" written on it, inspite of a cable connection and, of course, the input set to cable
Probably a bad video processor board
But, 1st try using a different type of Cable such as IRC, STD, or HRC different freqs and channels
Also, try using a vcr or dvd on one of the inputs to see if that works
Jonathan
Oct 26, 2008 | Polaroid FLM-3732 Television
Blue Screen
I just wanted to suggest some things for you to try, if you have not done them already. Try hooking up a known good signal, such as the main input cable from your cable or dish, hook it straight to your tv, and see if you can change channels, and get a picture on low band...2 thru 6, and then if not, how about any picture above channel 6, if you get picture on 2 thru 13 now, it could be whatever you have hooked in between the input cable and the tv...be sure you have the tv on the right channel for your receiver, usually 3 or 4, or if you are using another type of video input cable, make sure you have tv on the right input for that cable and that cable is good...check the in and out of your component unit, for correct cable hookup as well as your cables, in reference to using RCA video and audio left and right in and out...a lot of sets and vcr's will go to a blue screen if they lose signal to them....I hope this helps you out some.If you cannot get a picture from hooking your signal straight to your tv, it could be the tuner got a spike from a thunderstorm, or has lost the B Plus source for the tuner circuit. Be sure that it is not selected for an input signal,other than the cable or antenna mode, the onscreen text should verify this, if you can change channels with or without getting video...a picture....Good luck with it. T.
Jan 15, 2008 | JVC AV-27S33 27" TV
Unusable signal
Could be a bad buffer/amp or bad tuner, depending on source selected....accordianman
Dec 08, 2007 | RCA Scenium D40W20 40" Rear Projection...
RCA F32650 32" TV Logo
161 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
