Question about Nikon D50 Digital Camera
D50 Won't Turn On
I am beginning to have problems with my D50 not powering up correctly. At times, I can turn it on and view pictures through the LCD monitor, but it won't take a picture. This is an intermittent problem as it will suddenly begin working again (like the next day AFTER a wedding)! This has happened several times and has caused me to miss some pretty important pictures. It has never been dropped or abused, and has had a fully charged battery when this occurs. I don't know what to do. It is working at the moment and I am reluctant to ship away a functioning camera for repair. It's like taking your car to the shop for a repair because you hear a rattle under your hood, but as soon as the mechanic listens for the rattle it's gone!! Please advise on what I should do. Thanks in advance.
  • Cameron Scott May 11, 2010
    Are you using Nikon brand battery?
I have the same problem, caused by a small amount of water getting in the command dial slot. If I leave the camera switched on I can push the battery in and out firmly a few times and it comes good. I suspect a dirty film from the water in the contacts. I am trying to get a repair manual to have a go at getting at the contacts to give ithem clean.
I have tried pouring a little methlated spirit in the command dial opening - with the battery out and holding it at an angle to prevent the meth going right through the camera. This hasn't changed the condition.
Good luck
Posted on Apr 24, 2008
SOURCE:
Monitor on my D50 will not work
It sounds to me that their is a problem with the circuit board for the back of the camera. Please send it to a qualified repair centre.
Nov 21, 2008 | Nikon D50 Digital Camera
Canon S2 problems
Low battery power ? (rechargeables do not last forever).
Try a brand new set of batteries
Feb 06, 2008 | Canon PowerShot S2 IS Digital Camera
Nikon D50 LCD Display does not work
NatD, The D50 and indeed most SLR digital cameras [ I have a D40 ] does not allow you to take pictures using the LCD display ... this is by design, you are meant to use the viewfinder and the image you see through it is straight through the lens via a mirror block [ called a reflex pentamirror or prism ]. When the mirror is down such that you can see the image in the viewfinder it is obscuring the sensor [ the bit that takes the picture ] and when you take a shot the mirror lifts and the picture is recorded. Its this reason that DSLR's dont use the LCD to shoot, however there are a few now available that do let you do this, such as olympus, new panasonic one and higher end Nikon and Canon cameras. Hope this explains it without getting too detailed!
Dec 04, 2007 | Nikon D50 Digital Camera
No picture in the image screen
I suspect that you're looking for a "live view", like in the point & shoot cameras. Most DSLRs (like the Nikon D50) don't have live view. In other words, in order to see the picture you must take it first.
Dec 01, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
Problem with my D50 reading my card
Try resetting all folders in the camera to default setting or erasing any existing folders in the camera, then insert your card.
Oct 27, 2007 | Nikon D50 Digital Camera
Display overlaying pictures on LCD screen
Hi, the only thing I can see in the manual is on page 52 (below). You can scroll through the information provided using the up & down arrow keys on the multi-selector button. Scrolling though to the basic file info should give a clearer view. Perhaps if you select this option the next time you view it will default to it? I don't have the camera to try! Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 16, 2007 | Nikon D50 Digital Camera
Nikon D50 Lens won't work
I have a D50 as well but never experienced this problem. One thing to check as you already mentioned are the metal connections between the lens and the camera body. Make sure they're clean and shiny. Another thing to try would be switching between AF and MF modes on the lens itself.
Jul 02, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
Displays pictures remaining with power off
I'm not sure what exactly your question is but this sounds normal. My D50 does the exact same thing. It displays the number of frames left on the LCD on top of the body when a card is in, and an 'E' when it is not, even when the camera is powered off. The only way to comepetely turn this LCD off is to remove the battery from the camera.
Jan 18, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
Nikon D50 Digital Camera Logo
673 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
