Question about Lexmark Office Equipment & Supplies
WHEN I HIT PRINT NOTHING COME OUT BUT WHEN I SHUT DOWN THEN I START IT UP AGAIN THE PRINT COME OUT WHY
  • 488 Answers
Check and make sure the printer is "online" - look under the printers and scanners applet
Make sure spooling is active
This sounds like the print buffer is not active so the print job is being written to your hard drive instaed of the printer buffer.
Send the document to the printer then double click on the print manager icon in the status area of the screen ( bottom right hand corner) you should see the document in the list and if there is a problem, scroll along to the right to read what is happening with the document.
If this list is full, cancel all documents and clear this list.
Then reboot your machine to clear the printer buffer and the printer should not print anything on reboot.
Then print the document again but only once, then recheck print managers list.
Most printing issues can be seen here in print manager..
let me know if this helps
Swoop611
Posted on Oct 29, 2008
Printer error has occurred - says to cancel printing and shut off, then start again. I wasn't printing and there is nothing to cancel. Shut down numerous times and won't clear & start.
Brand, model, operating system, source of the error message all help in exploring an issue. The printer was shut down several times and the error message did not clear? If the printer is shut off for a significant time allowing discharge of any capacitors (which are similar to batteries) and yet you get an error message when you power back up, it suggests that there is a mechanical problem or inking problem. This would require troubleshooting of the device. You might find help for that on the manufacturer's site. HP, for instance, has a diagnostic program that can be downloaded.
Sep 01, 2017 | PRINTER Office Equipment & Supplies
MY HP printer can print but does not copy
Same thing just happened to my fairly new 7520 Hp.
I shut my machine first with the shut off button and then unplugged
it for about 5 minutes. Sounds like you tried this and I believe this did not work for me either so I just went into the HP official site and downloaded my printer again. Downloading your printer from their
site is easy and quick instead using the cd. It automatically removed my old printer and installed the printer again. The problem has not returned.
Another problem I just had and because I think one of my new
cartridges (yellow) is somehow damaged. I got a black line down
my pages with a note that my yellow ink is missing. Had black line only when printing and not copying. I reinserted the yellow ink and took a light damp qtip and slightly wiped the machine screen on each ink cartridge.(this screen meets the new opening from each
new cartridge. The black line left.
Hope this helps.
Jan 02, 2015 | HP PhotoSmart Office Equipment & Supplies
HP LaserJet 4100 for all applications in windows 7. When I go to print a document and click on print. The print screen exits, the print job doesn't processes, and the print queue stays empty. Noth
Ideas? Yes. I had this happen on an LJ 1000 while trying to print my tax return. I tried emptying the queue, removing power from the printer, etc, etc. What finally worked was to empty the queue (again), disconnect power from the printer, shut down the computer, plug in the printer again, restart the computer, queue up a print job again, and hit PRINT.
Hope this works for you
Apr 11, 2013 | HP LaserJet 4100 Printer
Dell V715w all-in-one print job stuck in que
Go to your search programs and files box in the start menu and type in services when you open services scroll down to Print Spoolers double click and you will see service status started hit the key that says stop after it stops hit OK to close it and reopen Print Spoolers and click open tab and then hit OK to close then close services box and you should be able to print again.
Good Luck
Aug 16, 2012 | Dell All-in-One Multifunctional (v715w)...
Nothing on powerup.
Open it up again and find the wire you blew off.
Oct 25, 2009 | Toshiba Satellite X205-SLI1 Notebook
Pc not always booting,
blow out dirts on bord, then you pack the board to avoid any bridging with the cassing
Jul 20, 2009 | Computers & Internet
Hp 1350v all-in-one printer won't print
if you have a print job stuck go in and hit cancel job. If it stays even after a few min right click "my computer" on your desktop and hit "manage" go to "services and applications" click "services" find the print spooler option and right click it and stop the service. Once stoped right click it again and start it. This should clear anything stuck in print queue trying to delete
Jun 22, 2009 | HP PSC 1350v All-In-One InkJet Printer
Canon clc 5100 problem
try a clear server on the Fiery. shut down/re-start
**Warning if u need your job log saved do so before clearing Fiery server.
Mar 09, 2009 | Canon CLC 5100 Copier
The power button keeps blinking and I can't shut the printer off . I was printing directions from mapquestand only one page and part of another page printed. I tried several times to print again but...
I fixed the problem. I guess I hit the hold button on my printer without realizing what I had done. That's why the printer would not shut off and it was kept in the active state. I just started hitting buttons and once I hit the resume button the printer started working again.
Thanks anyway.
Jul 07, 2008 | HP Office Equipment & Supplies
164 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
