Question about Smeg Cooktops
Smeg SA756X cooktop -cannot turn on
Hi, moved recently into a rental, there is a wall switch connected to the smeg oven and smeg cooktop, when wall switch isturned on the cooktop resets and all the numbers light up.... (oven is fine)cannot turn on the cooktop, tried everything logical to get it working, single touch, dbl touch, rangehood on at same time, hard touch, light touch??? any ideas would be appreciated - the real estate, owner doesnt have a manual... thanks
fridgetech
  • 473 Answers
SOURCE: Jenn Air Cooktop Burners Won't Ignite
The orifices may be dirty. They can usually be cleaned out with a safety pin.
Posted on Oct 05, 2007
SOURCE: cooktop light stays on when cool
Please be more specific.
A.  What is the "plate cut-out"?
B.  How does one access it?
Posted on Oct 15, 2007
  • 1314 Answers
SOURCE: Smeg SAR134A/X does not ignite.
give it a while for the switches to dry if it doesnt start working then reply to me most of the time they will start working also check to make sure the breaker didnt trip
Posted on Mar 18, 2008
  • 12 Answers
SOURCE: Kitchen Aid kecc508gbl3 Cooktop - Flashing Controls.
Held all off/on button for 5 seconds cleared the problem,
Posted on Dec 25, 2008
  • 10865 Answers
SOURCE: Looking for a manual for SMEG rangehood HACD60SS model
check to be sure that the fan works, and if it does check to be sure that the air flow path to outdoors is not clogged. one way to do this is to remove the hood and slide a dry garden hose through the entire vent pipe to the outdoors.
Posted on Jun 29, 2009
Smeg mod nu.sar93xlpg gas cooktop is 20 years old and in good condition The gas igniter recently has been sparking once every 5 mins. works fine except one spark every 5 minutes,any ideas
probably find that after so long the igniter is starting to fail
call smeg and see if there is a replacement one available
there may be after market units from your local gas shop
Jun 25, 2016 | Smeg Cooktops
Oven drawer stuck
It's stuck on the runner,only way is to use a wood pry tool to force it open
Aug 18, 2014 | Smeg Cooktops
Smeg gas cooktop is continually clicking.....going mad,,,,,
Ist unplug the unit. What you have is the stovetops valve switch defective. Sometimes this will happen after a boil over. The switches get wet and temparaly short. When they dry out it should work properly.http://www.on-timeappliance.com/ovenrepair.html
Mar 26, 2012 | Smeg 23 in. SE64 Gas Cooktop
Oven model 1996
try retravition, bj hifi, havey norman or aney white goods store
Jan 18, 2012 | Smeg Cooktops
One of my igniter in my smeg gas cook top does not spark
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Aug 30, 2011 | Smeg 23 in. SE64 Gas Cooktop
My smeg SE2640TC1 cooktop is cracked and we need to replace it. How do we go about doing this - (ie hardwire etc)
To replace the cooktop the first thing you need to do is turn off the breaker outside that supplies the power to the cooktop.. Then go under the cooktop in the cabinet and follow the flex power cord to the wall. Remove the cover plate on that box in the wall. un connect the wires from the wires in the wall. Next look up at the bottom of the cooktop to make sure there is no clamps that hold the cooktop to the counter top. if there is remove the. Then just lift the cooktop off the counter top. from here you just reverse the steps to put the new one in.
Good Luck
May 26, 2010 | Smeg 23 in. SA435X Electric Cooktop
Smeg gas hob ignition
There is a problem with the board. It has malfunctioned onto an ignition mode. By switching it off, it shows the capacitor is holding chage untill flat.(Hence the continual sparking) Replace it.
Sep 20, 2009 | Cooktops
Change the location of a cooktop
sure can but need to move the power to the new location. not hard sometimes if you can access from under the floor. need to see if you have a finished ceiling under or if you can get to it easy.
May 24, 2009 | Smeg 23 in. SA435X Electric Cooktop
Smeg SE64 Gas cook top
problem with hob is probably water ingress in area of ignition unit - will probably cure itself oven is a completely separate unit from hob. problem with it is that you have to re-set the clock - you have it on automatic. after power outage, oven clock always has to be reset
Apr 04, 2007 | Smeg 23 in. SE64 Gas Cooktop
Cooktops Logo
95 people viewed this question
Top Smeg Cooktops Experts
Timllfixit
ray gallant
marlin siecinski
Are you a Smeg Cooktop Expert? Answer questions, earn points and help others
