Question about Brother MFC 240C All-In-One InkJet Printer
Brother MFC-240C Error 34
How do I fix error code 34. The machine tells me to look in maintenance section of manual but there is no indication of what to do.
  • Anonymous Nov 04, 2008
    help
  • shel736 Nov 15, 2008
    Totally useless just like the printer.
I think error 34 is print head related. I've had the same problem with my 240c but was able to fix it. I took the printer apart to access the print head. It is rather easy to take apart so I won't post a how-to on that. I noticed that the print head was getting kind of stuck on the right side. First, I cleaned the tracts, metal and plastic parts that come with contact with the print head. Then, I lubricated these parts using WD-40. A Q-tip works well for all of this. This resulted in a smoother movement of the print head and solved the problem. I can you can or should use gear grease but I love WD-40.
Posted on Jul 16, 2009
  • 41 Answers
You can download the manual from the link below..
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_240C_EN_249.PDF
Solution Center is here...
http://welcome.solutions.brother.com/BSC/public/us/us/en/model_top/colormfc/mfc240c_all.html?reg=us&c=us&lang=en&prod=mfc240c_all
I didn't see a error code 34 so you might have to call them...
7777 North Brother Blvd.
Bartlett, Tennessee 38133
1-877-BROTHER (877-276-8437)
901-379-1215 (fax)
9:00am to 8:00pm Eastern Time
Please Rate this solution if it helps.. Thank You..
Posted on Nov 12, 2008
How do I replace the pf kit on a brother mfc-9325cw. I have the replacement parts.
Laura, you get the necessary tools, get access and remove the old parts and replace with new ones. Make sense?
Jan 10, 2017 | Brother International Brother MFC-9325CW...
I have a schumacher xp2260 and am getting an error code of r02 but cannot find any information about it. Please tell me what it means and how to fix it.
I have no information on this fault. I suggest you contact the manufacturer directly with the question, but really doubt it will be something you can fix yourself.
Jan 09, 2017 | Office Equipment & Supplies
HOW DO I un-lock the scanner on a Brother MFC 7420?
Unfortunately, the MFC-7420 doesn't have a physical lock switch. You need to turn off the all-in-one and wait for the unit to clear its memory. If the error recurs after you press the power button again, wait 30 minutes and try again. (Note: you will lose any faxes that are in memory. See the User Guide page 11-5 to save this information.) You can find the manual on the Brother support page for the MFC-7420: https://www.brother-usa.com/support/ModelInfo.aspx?R3ModelID=MFC7420 . Click on the Manuals & Documents tab. Then click on the Manuals on our Online Solution Center for the English version of the manual. The direct link to the User Guide is currently: http://download.brother.com/welcome/doc000387/ALLFB_UsaEngUsr_B.pdf .
You can also try unplugging the all-in-one for several minutes to reset the error codes. If the error persists, contact Brother if the MFC-7420 is still under warranty (1 year). If it isn't under warranty, consider replacing the unit. The repair costs may be unreasonable.
I hope this helps.
Jan 09, 2017 | Brother MFC-7420 Printer
How do I correct error h5 on a Sharp printer AR-5620N?
Hello Sudhir,
The error code H5 means there was at least 5 pages in a row where the paper did not come out of the printer correctly (most likely paper jams. The following manual will direct you on the steps needed to clear the code, please note especially page #8-3
Service Manual SHARP AR 5618 5620 5623 SME
The following video should help also;
Jan 09, 2017 | Sharp Office Equipment & Supplies
Toshiba estudio 455 Error Code E030
E030 indicates jam error on exit...U need to see where the paper stop and why...
Jul 28, 2015 | Toshiba Office Equipment & Supplies
My printer brother dcp7065dn disply 71 and72 error
This is codes for the ink cartridge. The code means there is a problem with the cartridge. Change them both and restart the machine.
Jan 13, 2015 | Office Equipment & Supplies
Error code 3501
HI
I HAVE KONICA C6500
ERROR CODE 3501 and 3802 but know the error 3501
I know it rech high temperature I change the sensor 1 UP fuser roller
and I reset the error, the machine start and stop again with error 3501
Oct 01, 2013 | Konica Minolta Bizhub C 6500 Copier
Laser printer makes light clicking noise when idle
When idle is potentially the fuser unit, after heating and cooling. However the print quality issue associated with the clicking sound could indicate an electrical issue. The HVPS maybe faulty causing the print quality issue (due to dependant parts) and the electrical click. In any case I would recommend calling Brother and finding the nearest authorised service agent.
Oct 20, 2012 | Brother Mfc-9840cdw All-in-one Laser...
Ricoh 1045 error code sc 395
fix copier is a youtube channel
fixing error in videos
this is a video see you how to fix sc 395
https://www.youtube.com/watch?v=cI6o6mYOqow
Oct 07, 2012 | Ricoh Aficio 1045 Black and White Copier
Mfc-j630w error messagfe 4f
I don't know but I can't enter into maintenence mode I pressed just as its said but it's won't go and I really need my printer??
Jul 15, 2012 | Brother Multi-Function Center MFC-3360c...
Brother MFC 240C All-In-One InkJet Printer Logo
1,708 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
