Question about Pioneer DEH-P9200R CD Player
Alarm malfunction Accidental alarm was deactivated with key-ignition switch only. Now have overpowering static in front right speaker that sounds even without much volume. Noticed that the right-hand door doesn't show open or close during the re-setup process and yet the door does turn dome light on and off correctly. Have tried resetting many times over including power disconnect and microprocessor reset and can get stereo to play any system but audio is overpowered by the front right speaker with terrible static.
5 Suggested Answers
SOURCE: speakers dropping out & engine sounds
sounds like your amp is bad
remove the amp and hook your speakers directly to the radio if the problem stops
then the amp might be messed up
if you got another radio try the amp with that radio to "double" check that it is the amp
if the problem is still there with the speakers hooked to the radio then you need to fix or get another radio
Posted on Mar 28, 2008
SOURCE: Setting Time on DEH 5850
With the ignition key in the accessory position, and the radio off.
1. Press and hold the Function button.
- This should get you to the time adjustment area.
Posted on May 04, 2008
shagone
  • 34 Answers
SOURCE: will not power up
the ribbon cabe needs to be replaced .pioneer part # is cxx1799
Posted on Jan 09, 2009
XSdB
  • 80 Answers
SOURCE: i have the deh p8000r has no sound
Usually with this model, when all else works, and there is no sound, the internal amplifier IC is blown. Smell the back, and see if it smells burnt. It may. It does not always tho. The IC is a PAL007a or something similar. It's kinda hard to replace if you aren't skilled with soldering, but it can be done by any decent repair shop. Also, test to see if there's a signal on the RCA's, if there is, you can forgo the internal amp, and get an external one. (it will require running speaker and power cables, but if you really like the head unit...;-)
Posted on Jun 12, 2009
Car will not start or even turn over - battery is good and starter is good
Do you have an alarm system? Try activating then inactivating the alarm system. Sometimes the alarm system will disable your ignition. You can also try using the key to unlock the driver door to deactivate. Some cars deactivate different ways once the alarm system disables the ignition.
Oct 11, 2017 | Cars & Trucks
Tip
How to Program Acura Remote Transmitter
Acura Remote Alarm / Central locking
Model: CL Year: 2001-2003
Model: TL Year: 1998-2006
Model: MDX Year: 2001-2006
Model: RDX Year: 2007-2009
Model: RL Year: 1996-2004
Model: RSX Year: 2002-2007
Model: TSX Year:2004-2008
System Operation
  • Pressing remote transmitter LOCK button once activates alarm and central locking.
  • Pressing remote transmitter UNLOCK button once deactivates alarm (if fitted) and unlocks driver's door only.
  • Pressing remote transmitter UNLOCK button once also activates driving position memory. Driver's seat and mirrors move into memory position specified on remote transmitter when driver's door opened.
  • Pressing remote transmitter UNLOCK button twice within 5 seconds unlocks all doors.
  • Pressing remote transmitter trunk release button for 2 seconds activates trunk release.
  • Pressing remote transmitter PANIC button for more than 1 second activates panic alarm.
  • Pressing any of the remote transmitter buttons deactivates panic alarm.
  • If vehicle unlocked and doors not opened within 30 seconds, locks are reactivated.
Synchronization.
when
  • Remote transmitter battery replaced.
How
  • Press remote transmitter LOCK button or UNLOCK button 5-6 times.
  • System should now lock and unlock vehicle to indicate synchronization procedure complete.
  • Check operation of remote transmitter
Programming
How
  • Obtain all remote transmitters.
  • Switch ignition ON.
Proceed as follows:
NOTE:Point remote transmitter at central locking signal control module (located behind glove box).
  • Within 4 seconds: Press LOCK button or UNLOCK button of first remote transmitter.
  • Within 4 seconds: Switch ignition OFF.
  • Within 4 seconds: Switch ignition ON.
Repeat procedure above twice.
  • System should now lock and unlock vehicle to indicate programming mode activated.
Within 10 seconds:
  • Press LOCK button or UNLOCK button of first remote transmitter, allowing doors to lock and unlock once.
  • Press LOCK button or UNLOCK button of each remaining remote transmitter to be programmed, allowing doors to lock and unlock once as each remote transmitter is programmed.
  • Switch ignition OFF.
  • Remove key
  • Check operation of all programmed remote transmitters.
Immobilizer
System Operation
  • System arms 5 seconds after switching ignition OFF. Immobilizer warning lamp flashes during this time
  • Immobilizer warning lamp illuminates for 2-3 seconds.
  • If immobilizer warning lamp illuminates for 2-3 seconds then flashes rapidly:
  • Key code not recognized.
  • Remove key and try again.
Programming
When
  • System malfunction.
  • Key added or replaced.
How
Immobilizer can only be programmed using diagnostic equipment.
Model: MDX Year: 2007-2009
Model: TL Year: 2007-2008
System Operation
  • Pressing key LOCK button once locks the vehicle.
  • Pressing key LOCK button twice within 5 seconds activates the alarm.
  • Pressing key UNLOCK button once unlocks the driver's door only and deactivates alarm.
  • Pressing key UNLOCK button within 5 seconds unlocks all doors and tailgate.
  • Pressing key UNLOCK button within 5 seconds and holding will open windows and sunroof
NOTE: Models with "Technology Package": Alarm central locking functions can be altered using digital multifunction display in instrument panel.
  • Pressing key PANIC button for more than 2 second activates panic alarm.
  • Pressing any of the key buttons or turning ignition ON deactivates panic alarm.
  • System will automatically lock all doors when vehicle is driven above 15 mph (if function selected).
  • If vehicle is unlocked and doors or tailgate not opened within 30, 60, or 90 seconds (depending on programming), locks and alarm system are automatically reactivated.
  • Pressing tailgate release button once will open, close or reverse direction of tailgate.
Programming
When
  • Key remote transmitter added or replaced.
How
  • Obtain all keys fitted with remote transmitters.
  • Ensure doors, trunk / tailgate and hood are closed and unlocked.
NOTE: A maximum of 5 remote transmitters can be programmed.
Proceed as follows:
Repeat procedure above twice. Locks should cycle when button in pushed.
  • Within 4 seconds of each other press LOCK button or UNLOCK button of each remaining remote transmitter to be programmed, allowing doors to lock and unlock once as each remote transmitter is programmed.
  • Remove key.
  • Wait 10 seconds.
Immobilizer
System Operation
  • System arms when vehicle is locked using the remote transmitter.
  • If key code is not recognized:
  • Engine starts, then shuts off.
  • Immobilizer warning lamp flashes once, then blinks until ignition is switched OFF.
  • With ignition switched OFF, immobilizer warning lamp will flash 10 times to indicate the system has reset.
Programming
When
How
Model: RL Year: 2005-2009
Programming
When
  • Remote Transmitter added or Replaced.
  • System Malfunction.
How
Remote Transmitters can only be programmed using diagnostic equipment.
Automotive and Commercial Locksmith Acura Remote Transmitter Programming...
on Mar 26, 2015 | Televison & Video
Key alarm sounds even after key is removed. Drained battery.
Make sure your Battery is fully charged. A partially charged Battery can make the alarm system malfunction. Also, make sure the
regulator is charging the Battery. Some key alarm systems can
and will drain your battery if the Car is rarely driven especially
if there is a ignition kill switch wired into the system. The key alarm
system on my Mercedes 560SL used to drain my battery whenever
I didn't drive the car enough.
Sep 08, 2017 | Cars & Trucks
Why is the temperature alarm light on, on my freezer Model# FFU21M8CW?
Good Afternoon Friend,
I understand that the temperature alarm light is on for your Frigidaire freezer, model# FFU21M8CW. This feature is designed to provide a warning of a possible malfunction. If the temperature of the food rises to a level unsafe for long-term storage, the buzzer will sound. The red light, if equipped, will also glow. The Temp Alarm feature operates on household electricity. If power fails, the alarm will not function. An ON/OFF switch allows you to deactivate the Temp Alarm when not wanted. Your freezer is shipped with the Temp Alarm in the OFF position. After your freezer has run approximately 4 hours, the red light, if equipped, will go off. Then you may activate the Temp Alarm without the alarm sounding. Press the ON switch to activate the Temp Alarm. To deactivate, press the OFF switch. If the alarm sounds, be sure freezer is properly leveled, and the door closes freely, and seals properly. If you suspect a technical malfunction, call an authorized servicer immediately. Hope this is helpful.
-Best Regards-
WP
Jun 24, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
1999 Montero, changed battery, alarm going off. No key fob. How do you stop the alarm
1) Disconnect Negative Battery Terminal
2) Turn Ignition Key On
3) Connect Negative Battery Terminal
4) Alarm will be deactivated. You should get a fob for this vehicle to prevent any accidental alarms going off in the future.
CAUTION: This procedure will create a spark when reconnecting the battery. A recently charged or discharged battery can be surrounded by a cloud of explosive hydrogen gas. Wear safety glasses and turn face away from battery while making connection. Do not perform this procedure with a battery that has recently been on a charger!
Mar 07, 2011 | 1999 Mitsubishi Montero
I have a 1997 Toyota Camry. Recently, the security alarm malfunctioned, blaring the alarm and the remote control on the keys wont deactivate the system even after changing the batteries on them. I recently...
You need to reset the alarm by inserting the reset key(small plastic devise with visible contactors that should be with the keys) for a few seconds in the it's hole in the right-hand rear speaker. Open the boot look at the underside of the rear right-hand speaker to locate the hole.
Jul 03, 2017 | 1997 Toyota Camry
I replaced battery in my audi 80 2.0 tdi but have lost the remote and alarm wont stop going off .
Depress lock or unlock button. Manually lock and unlock driver's door within 30 seconds. System should now lock or unlock vehicle. If not, carry out programming procedure.
Programming
When
Key added or replaced. System malfunction: Alarm LED in rear fog lamp switch illuminates for 30 seconds when vehicle is locked.
How
NOTE: A maximum of 4 keys can be programmed (one at a time).
As memory positions of existing keys are unlikely to be known: Obtain and reprogram all keys.
NOTE: Existing key memory positions will be overwritten.
Switch ignition ON. Use key not fitted with remote control. Manually lock vehicle using key. Using first key, press unlock button once (programs memory position 1). Alarm horn sounds once to indicate signal received. Wait 6 seconds. Press unlock button once to confirm programming. Vehicle unlocks. Programming mode deactivated. Switch ignition OFF. To program remaining keys into memory positions 2, 3 and 4. Carry out the complete procedure below for each key: Switch ignition ON. Use key not fitted with remote control. Manually lock vehicle using key. Press unlock button at 1 second intervals, as follows: Twice for memory position 2 (second key). Three times for memory position 3 (third key). Four times for memory position 4 (fourth key). Alarm horn sounds once every time unlock button is pressed, to indicate signal received. Wait 6 seconds. Press unlock button once to confirm programming. Vehicle unlocks. Programming mode deactivated. Switch ignition OFF.
NOTE: Ignition MUST be switched OFF between each key programming procedure
Jan 10, 2010 | 1992 Audi 80
VW Jetta alarm malfunction
Go to your local junk or scrapyard and pull them yourself. The dealer charges an average of 90-100 dollars an hour. So a lot of the money they quoted you for was probably for labor
Jul 02, 2009 | 1999 Volkswagen Jetta
1997 venture keyless remote programming
SYSTEM OPERATION
System warning lamp located on top of the instrument panel
Press UNLOCK button once , turns on interior lamps and deactivates alarm (if fitted)
Press UNLOCK button twice w/in 5 seconds unlocks all doors, turns on interior lamp and deactivates alarm (if fitted)
To activate alarm system (if fitted):
Switch ignition OFF
Open driver's door
Press Lock button on remote
Close Driver door
warning lamp will flash when system is activated
Press remote power sliding door button will open sliding door (if fitted) only if unlocked first
Pressing remote panic button:
*Sounds horn intermittently
*Flashes exterior lamps
*Turns on interior lamps
**Pressing panic for the second time OR switching ignition ON deactivates alarm.
PROGRAMMING
Remobe key from ignition switch
Remove the "BCM PRGRM" fuse, from the fuse box
Close all doors
Turn ignition switch to the ACC position
With in 1 SECOND , turn the ignition switch to OFF then back to 'ACC'
(really, with in one second)
Open and close the driver's door. A chime will sound, indicating programming mode activated
Press and HOLD LOCK and UNLOCK SIMULTANEOUSLY untill a chime sounds 2 times ( about 15 seconds)
Repeat this exact procedure for all remotes to be programmed
Remove key from ignition
Refit 'BCM PRGRM' fuse.
4 REMOTES MAXIMUM CAN BE PROGRAMMED
Aug 24, 2008 | 2000 Chevrolet Venture
I hope you can help me!!!!!!
It sounds as though you are having a security (alarm) system issue. Does this vehicle have an aftermarket alarm installed? If you recently bought this car, it might have one that you don't even know about. Try locking and unlocking both front doors with the key. If the vehicle has a factory alarm system, this is the usual way to deactivate it. If that does not work, look up behind the dash on the driver's side. An aftermarket alarm system is usually pretty easy to spot as it'll have a bunch of wires connected to it that are usually wrapped in black tape and you can tell it's not factory installed. If this is the case, there will be a valet switch somewhere in the vicinity of the driver's kick panel. To turn the alarm off, turn the ignition switch to the on position and press the valet switch. This should turn the alarm off.
Jul 21, 2008 | 1993 Chevrolet Suburban
Pioneer DEH-P9200R CD Player Logo
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
