Question about Gateway MX6920 Notebook
Won't start I took a part laptop for cleaning and after that it won't start. Only thing I see is the read battery LED blinking 3 times. Did I kill it?
    Genius:
  • Gateway Master
  • 1,250 Answers
Check battery, check RAM, or its better take it to the technician, because there are no servicable part on laptop why have you clean it
Posted on Oct 29, 2008
Compaq memory
Remove one at a time, and try to reboot, alternate one for the other. Remove the battery, leave battery out, and unplug each time during process. The Cap Lock? Does the HDD led blink? Do you get anything on the screen?
Apr 27, 2013 | Compaq Presario CQ60-220US PC Laptop
My laptop won't start
Does the HD light turns on?
If not, try to open HD bay, disconnect and reconnect disk.
Mar 22, 2013 | HP Compaq nx6125 Notebook
My laptop won't work on battery now!!
look at the bottom of the laptop where you install the battery, there's should be what looks like metal contacts where the battery connects to the actual computer. make sure that when you installed the battery you didn't accidentally bend 2 of them so they were touching eachother. you may have created a direct short which is what caused your heat and the smell. try to plug the battery back in and be careful that you don't bend the metal contacts.
May 18, 2012 | Apevia Acer Aspire 1670/1671 Notebook
My laptop screen is black and caps lock and scroll key are flashing
That is a security configuration on HP Laptops, depending on the way they blink is the problem your machine has.
Here is the web page where this info is posted, in case you need more info, hope this helps you to determain.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&lc=en&dlc=en&cc=uk&lang=en&rule=26781&product=3816592
This document pertains to HP Notebook PCs with the HP Unified Extensible Firmware Interface (UEFI) beginning in late-2008. On startup, you may see a blank screen. If the diagnostic utilities detect a specific problem with hardware components, the fan turns on, but the screen remains blank. To help identify the cause of the problem, various LED lights on the keyboard blink a series of codes. The diagnostic utilities use the LEDs near the Num Lock or Caps Lock keys to blink a series of error codes. At the end of the series the blinking stops. The pattern of blinks will occur any time you attempt to start the computer until the error is resolved. Battery power LED blinks The Battery power LED indicates the condition of the power supply. When starting the computer, or when the computer is in operation, use the chart to identify the power condition. Battery Power LED Component Tested Error Condition Battery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer. LEDs near Caps Lock and Number Lock keys blink when starting notebook The LED lights near the Caps Lock and Num Lock keys will blink if an error is detected during the start up process. The LEDs will blink a number of times in a sequence and then stop. The number of blinks in the sequence indicates what component caused an error when it was being tested during start up. If the LEDs stop blinking and the computer does not start, you can press the power button again to repeat the tests. Count the number of blinks, and use the chart to identify the error condition. Knowing the number of blinks is helpful when you contact an HP support agent for technical help. Caps Lock/Num Lock LED Component Tested Error Condition LEDs blink 1 time CPU CPU not functional LEDs blink 2 times BIOS BIOS corruption failure LEDs blink 3 times Memory Module error not functional LEDs blink 4 times Graphics Graphics controller not functional LEDs blink 5 times System board General system board failure LEDs blink 6 times BIOS BIOS authentication failure
Dec 01, 2011 | HP Computers & Internet
Hi, I have Acer extensa 5220 ,it is 1.5 years old...Recently a problem started that when i connect battery to my laptop(AC plug is on) the battery LED on the laptop blinks 3 times orange and turn into...
Borrow a "MultiMeter" and check the VOLTAGE and AMPERAGE output from the battery. Although it's rare for an 18-month-old battery to "die" (or to refuse to recharge), it can happen.
If you try to run the computer _only_ on the battery, without AC power, does it work? If not, replace the battery -- look on eBay for cheaper-than-Original-Equipment replacement batteries.
Aug 02, 2010 | Acer Extensa 5620 Notebook PC
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Feb 23, 2010 | Computers & Internet
Sony KDF-42WE655 "Lamp" LED Blinking
yes this is because of the lamp and these are the lamp types for your tv ,Use Sony XL-2100U or XL-2100 (for WE655 series)lamps
also here is where you can see the replacement procedure ,
it starts here at page 16
http://www.fixya.com/support/p228828-sony_kdf_42we655_television/manual-15827/page-16
just click the next page number to see step by step
and here is the lamp http://www.purelandsupply.com/GeneralSearch.aspx?search=we655
Mar 07, 2009 | Sony KDF-42WE655 Television
PT53WX54J Shut Off LED blinks 3 times
3 blinks LED shows problem with convergence out ICs that either bad or not getting supplied volts from supply board to function properly.
Sep 08, 2008 | Panasonic PT-53X54 53" Rear Projection...
Gateway MX6920 Notebook Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
