Question about Husqvarna Husky 165
Husqvarna chainsaw repair
How to replace fuel line in husqvarna model 36 chainsaw
  • nepeancanada Jan 19, 2009
    finally got the fuel filter out of a husqvarna 40, now I am wondering about the line
  • 17 Answers
Usually empty fuel, use hook to pull out line , remove filter. Remove air filter cover and airfilter ,now you should be able to see line. Most just pull of carby and go through tank, some you may have to take screws out of av mounts in back of tank to see hole to put it back in.cheers hope this helps if where a stihl i could tell exactly.
Posted on Dec 29, 2008
6440 husqvarna sewing machine needs repair and replacement parts are difficult to acquire. where to get repair?
Try here http://www.sewingpartsonline.com/viking-6440-sewing-machine-parts.aspx
If your needed part isn't available there... The only hope in that case is to find another Husky of the same model and use one or the other as a parts machine. (or part out your Husky and buy something else with the earnings..... just don't buy new plastic ones)
Aug 24, 2012 | Sewing Machines
Husqvarna Sewing machine #1 model:: Tech says that I need a new mainboard. Hate to put that kinda money in a 20+ year old machine. He said that it sews like butter now (also had to replace a fuse in
it's a hard decision to make, also another thought to trade the machine in for a new machine,, get a new machine with new features that you might use more
Mar 03, 2012 | Husqvarna Sewing Machines
Our sewing machine is only running reverse (backwards) Can you please provide me we an service manual, type husqvarna 2000, modell 6440
You can find the service manual here.
http://www.sewingnz.com/categories/Husqvarna-Viking/
and a video on this page.
http://www.absolutesewing.co.nz/SewingHusqvarna.html
Your husqvarna 2000, model 6440 machines mechanical parts are in the need for a good clean and oiling. There is an explanation to this on the blog below.
http://sewingnz.blogspot.com/2011/04/repairing-reverse-on-husqvarna-2000.html
Apr 01, 2011 | Husqvarna Sewing Machines
Husqvarna 4320 sewing machine
Certainly from a VSM Husqvarna dealer, many good sewing repair shops will have a range of bobbins to suit most makes/models Google VSM Husqvarna and find the store locator page for your country or region to locate the nearest one...........or look in the phonebook for service centres.
Sep 08, 2009 | Husqvarna Viking 1
Husqvarna 51 chainsaw will barely run, magnito and carberator ok
Probably need to re-adjust the carburetor jets. They are very small screws in the base of the carburetor. They will be labeled with an "H" and an "L" . Set the low speed first by turning it in slowly until the rpm drops slightly then start turning it outward untill the engine idles smoothly. At that point you can also adjust idle speed. Then you need to be careful here but you need to hold the throttle wide open at the same time adjusting the high speed jet. Turn it in until the rpm drops then slowly turn it out. The rpm will keep increasing. Once you get to a point where it is max'ed out then screw the jet back in one half a turn. Changes in altitude like using your chainsaw in town versus going to the mountains for firewood can sometimes make it necessary to adjust the fuel/air ratio.
Feb 18, 2009 | Husqvarna Husky 165
Chainsaw (Husqvarna 345e) will not start due to start attempt without adding oil to fuel.
If this was started without oil in fuel, then the piston is likely scored, and the compression rings stuck in a smeared aluminum mess. You can remove the muffler and probably see the damage to the piston. It can probably be repaired though. Take it to a reputible shop, then read the owners manual and get some help to learn how to safely use and maintain your investment that you have in this saw.
Jul 04, 2008 | Husqvarna Husky 165
Is there a bar oil adjustment on my 36 cc husqvarna chain saw. Where might is be? Cheers paul
If there is one it'll be underneath the saw just behind the clutch cover/side plate. Though some of the smaller cc / hobby saws don't have an oil adjustment screw. happy hunting
Jun 29, 2008 | Husqvarna Husky 165
Sewing Machines Logo
1,335 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
