Question about Zanussi ZJD1219 Front Load Washer / Dryer
Error code 20
Hi there, machine is showing " E20 " I believe this is the pump but want to clarify. Many thanks, chris.
  • Anonymous May 27, 2008
    Hi i have had the same problem with e20 showing and water not draining have tried calgon , descaler, lemon juice and have just brought new filter as the pump wants to work but is retaining water and emptying by bowls after each cycle is this the problem.
Hi, I also got the error code E20 when the filter became totally blocked during the washing cycle (due to a pair of my son's old work jeans!). Once I cleaned out the filter everything worked ok again. Put a large bowl under the filter as you unscrew it; a fair amount of water could be there. Regards, John
Posted on Dec 15, 2006
SOURCE:
When washer turns on there is a horrible buzzing sound, e 20 error message was on before
This is a blocked drain error code (E20) which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code. In addition, replace the drain pump after having found no problem with the drain hose, cleaned the filter, and checked the drain pump impeller but the drain pump just hums, buzzes or whirs.
Error Code E20 on Frigidaire Front Load Washing Machines
Aug 25, 2011 | Frigidaire Affinity ATF7000E Front Load...
Error codes E20
Hi
Error code e20 means a clogged drain pump. This might have happened due to small clips, pins, coins, etc being stuck in the pump. Please note that error e20 can also occur when the drain pump is not pumping fast enough or when the pump fails. To fix the issue you'll need to check the drain pump.
Remove the 2 screws from the bottom of the front access panel, it will come off. Now check for the pump on the right side and remove hoses from it. Remove pump from machine then remove whatever is there in the pump. Hope this helps... Please post back for any further assistance.
Nov 27, 2010 | Washing Machines
Zanussi turbodry 1200 There was a first error message E20, while drying, so i stopped the proccess but now in a new washing cicle, i´ve the same error while filling Whatt is E20? what must i...
Hi
Error code e20 means a clogged drain pump. This might have happened due to small clips, pins, coins, etc being stuck in the pump. Please note that error e20 can also occur when the drain pump is not pumping fast enough or when the pump fails. To fix the issue you'll need to check the drain pump. Tilt the machine on its side and remove the 3 screws and 2 wires that hold the pump in place. Hope this helps... Please post back for any further assistance.
Daniel
Nov 16, 2010 | Washing Machines
My zanussi FJS1025W washing machine is showing the error code E20 and it wont let me spin or drain the water away. I have cleaned all the filter but still it wont do anything other than take in the water...
E20 is a draining error.
Check the filter.You need to take the filter out, empty it of all lint and replace it. It may have water trapped in already, so get a cloth ready to soak up excess liquid! Also, make sure when you put it back in you have tightened it enough to avoid leaking but not too much that you cannot get it back out.
If still the problem persists then the problem is with the draining pump.The pump is not pumping out the water.Check the pump impeller it may got stuck due to some obstacles.Replace it and this wont come again.
Thank You
Sep 09, 2010 | Washing Machines
What does e20 mean? The display shows an error of e20. Looks like the water is not pumping out during the regular wash.
Hi
Error code e20 means a clogged drain pump. This might have happenned due to small clips, pins, coins, etc being stuck in the pump. Please note that error e20 can also occur when the drain pump is not pumping fast enough or when the pump fails. To fix the issue you'll need to check the drain pump.
Daniel
Jul 31, 2010 | Frigidaire ATF6000ES Front Load Washer
Error code e20 model # gltf2940ee0
Hi
Daniel
Jul 28, 2010 | Frigidaire ATF6000ES Front Load Washer
Error message E20 and can't open the machine
E-20 error is for drain pump /filter blockage.
Drain the pump manually.Clean it internally.The filter and drain pump are getting blocked in your machine.It needs to be cleaned.In some cases drain pump needs to be replaced if its cracked.
This will help.
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Jun 11, 2010 | Bosch Exxcel WFX 2467 Front Load Washer
What is error 20 on frididaire gallery washer? Clothes just sitting not moving at all?
E20 is not an exact error code. It's indicating a possible pump out problem. Here is a few possible causes of an E20 error code:
1. Restriction in the drain pump
2. Failed pump
3. Water not pumping out fast enough (crimped drain hose)
4. Too many suds ( too much detergent or wrong kind)
5. Pressure switch (not communicating with control board)
6. Loose wire at pressure switch
7. Loose wire at pump or control board
8. Failed control board
Apr 29, 2010 | Frigidaire GLTF2940ES Front Load Washer
Zanussi Electrolux ZWF 1430 W (E20 error)
Check water "forreign object trap". It's under the lid at the bottom of the machine. First drain water by pulling out the hose and pull out the plug. Then unscrew the trap. Have had this E20 error twice. First it was two coins there, next it was a big paperclip. Have worked fine ever since.11_20_2011_8_57_27_am.jpg
Sep 26, 2006 | Zanussi ZWF1430W Front Load Washer
Zanussi ZJD1219 Front Load Washer / Dryer Logo
602 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
