Question about HP Pavilion MD5020N 50" DLP HDTV
No picture tv turns on and off by itself already replaced the bulb but still no picture
  • Michael Cummings Oct 29, 2008
    HP Model ID5220N DLP TV powers on and off get no picture was working fin yesterday
  • 51 Answers
You will need to be more specific or try to contact guy at plasmatech@gmail.com, he has parts for HP DLPs
Posted on Sep 18, 2009
Tv comes on then turns itself off
Sounds like the projection bulb is heating up then it shuts off for safety reasons. If you can locate the bulb, there is most likely a screen (wire mesh) that traps dust when the fan is on to cool the bulb. Try cleaning this screen and see if it helps. It could be already too late and you might have to replace the bulb.
Feb 27, 2014 | Sony KP-65WS500 65" Rear Projection...
I have a Sony Grand Wega KF-60WE610 television. It now seems that the picture is darker than it used to be. I can still watch a show, but many people who have seen my television comment on the poor...
I'm sorry that the pictures on the TV screen is black. Based on the information you have provided, it appears that the issue is with the Lamp itself. The lamp of the TV may have to be replaced within two to three years depends upon the amount of usage.
If the screen becomes dark, the color looks unsual or the LAMP indicator on the front of the LCD projection TV flashes, it is time to replace the lamp.
Thanks for understanding. Please let me know if you require further assistance in replacing the lamp of the TV.
Jun 08, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
Hello, I have Sony KF50WE610. I have already
Blinks 4 times means a temperature error. Check the fans and if ok replace H3 board part# A-1405-433-A a small board located in the left side(when you are in the back of the TV).
Jan 03, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Wega KF-42E200A Projection Bulb
New bulb is just fine.
3 blink shows that lamp cover after replacement of bulb in TV is not fixed properly or not seated well in its position.
Put new bulb and carefully place back lamp cover in its position because lamp cover will press tinny safety switch inside that will send signal to system control of TV that lamp is installed properly.
Turn On TV and get vivid picture of Sony.
Thanks.
Oct 17, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
The picture went out in my 61" panasonic projection tv
If you still get sound out of your TV then the bulb could have already spent itself out and would need replacement. Many times you can gbuy one online and replace it yourself but with great care.
If you don't have the manual anymore, try googling it online. Good luck!
Aug 28, 2009 | Panasonic Televison & Video
My Samsung DLP rear-projection TV has had a very dim picture for months. We have replaced the lamp once already.
How long ago was lamp replaced, also you can try cleaning dust off the lamp. Dust builds up on it and causes pre mature failure. Also moving the TV around can cause the bulb to fail after extended use. The bulb are only as good as any other regular bulb. They start taking longer to warm up then dont get as bright then fail totally. Some Tv's wont allow itself to turn on in some of those states.
Aug 18, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
I have a Toshiba 52HMX94 rear projection T.V., i've had it for 4 years, replacing bulb every year. I now have another new bulb, but when I turn on the T.V. i hear a buzzing noise from the rear, and then...
Your TV requires ballast power supply board that gives you buzzing noise when TV turns ON.
Ballast supply board is available in Part Store and replacement of that board requires expertise.
Jul 23, 2009 | Toshiba Televison & Video
Tv continues to turn on and off by itself..
When it shuts off by itself, does the blue circle screen under the "Samsung" label show a picture of a light bulb? If so, it's probably time to replace the lamp.
Jan 24, 2009 | Samsung HLP5085W 50" Rear Projection...
Samsung tv turning off by itself
I had a similar problem where my 61" Samsung DLP was turning itself off very frequently I had resolved to try replacing the bulb. I called a local TV repair place to see if they had my buld in stock. The guy I spoke to actually told me how to fix my problem! There is a little blue switch behind the bulb access door. The inside of the door has a little piece that presses the switch down. The switch is supposed to work correctly weather the switch is in the up or down position but samsung forgot to take expansion from heat into account. If the switch is held in the upper position by the door and the plastic expands to a certain point, it triggers the set to shut off. This does not occur of the switch is held in the lower position. What you need to do is take the access door off and put it back on by sliding it into position from above. That will hold the switch in the down position, eliminating the problem. My set has not **** itself off ever since.
Jun 16, 2008 | Samsung LTP326WX/XAA 32 in. HD-Ready LCD...
My samsung sp50l7hx dlp tv wont turn on,last night i fell asleep while watching and awoke to see tv switch off then back on by itself, colour was dull, this morning i tried turning unit on. it started...
usually when that symbol comes up it means your lamp is defective so I would replace the lamp because if you had the set for that long and not replaced the lamp chances are thats your problem and you may be able to get a user manual for your tv by going to this sight
http://www.retrevo.com/
Apr 26, 2008 | Televison & Video
HP Pavilion MD5020N 50" DLP HDTV Logo
217 people viewed this question
Top HP Televison & Video Experts
Tony
Computer Links
Alun Cox
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
