Question about Graco Apsen 3-in-1 8740 Crib
Converting bed to headboard
I absolutely cannot figure out how to convert this bed to a headboard, I assume you use one of the 2 long sides of the bed. Decorative knobs were included but I can't find anywhere to screw them into. Please help!!
  • 4 Answers
You will also need the mattress support posts. You remove the S hooks and one post goes on each side of the stationary side (A). Here is the number for customer support: 800-858-8323. Hopefully they can help.
Good luck.
Barb
Posted on Jan 29, 2008
Need brackets for a crib to twin bed conversion
call the number listed in the instruction sheet . they and only they have the parts
Sep 19, 2015 | Baby Gear
We have a Morigeau-Lepine convertable crib-day bed-full size bed, but we are missing the instructions to convert it to the full-size. It's model number is DA722-BC & the model is somewhere between...
I can't offer the exact answer, but hopefully my suggestions will be helpful...
Converting the crib to a full-size bed should actually be a fairly simple process of detaching the 4 sides that make the crib, and replacing the 2 short sides with the full-size bed rails that were sold separately in a conversion kit. The 2 long sides of the crib become the headboard and footboard of the full-size bed.
Unfortunately, it's only a simple process if you already have the full-size conversion kit bed rails. And since Morigeau-Lepine went out of business, they aren't making any more conversion kits. If you don't have the full-size bed rails, then this could be quite difficult.
It's possible that some stores that used to sell Morigeau-Lepine cribs might still have a conversion kit hidden somewhere in the back of their stock room or warehouse. You could try calling around to a few of your local stores to ask if they would check for you. It's a long shot, but it doesn't hurt to ask.
If you have the rails, or are lucky enough to find them, then it should be as simple as locating the screws that hold the crib sides together, removing them (most likely with an appropriatly sized hex-key,) and putting the screws back through the headboard and footboard into the bed rails. (I'm really just assuming that it works the same as the Babi Italia conversion.) If no screws are visible, or if removing them doesn't detach the crib sides, then they are probably also held together with locking bed rail fasteners. To release the fasteners, remove any visible screws, then push upwards on the short side rail while pushing down on the long side rail. You might have to tap the rail up with a rubber mallot to get it moving.
If you don't have the full-size bed rails, and you can't find them anywhere, your only option may be to build them yourself, or find a woodworker to build them for you. Search online for "Bed Rail Fasteners" and you'll see several options for hardware, but they might require modifying the headboard and footboard as well. Full-size matresses are 75 inches long, so you'll want the length of your rails to accomodate (ours are 77 inches long.)
I hope I've been helpful. Good luck!
Jan 19, 2011 | Baby Gear
Converting Simplicity Ellis crib to full size bed with headboard
Did you ever figure out how to do this? I am having the same challenge.
Jan 17, 2010 | Simplicity for Children 4-in-1 Convertible...
Bambino Reale 312C crib conversion to double bed
I have the directions- but it is poorly written by the company...
I could scan and email I guess - if you still need them.
Nov 06, 2009 | Storkcraft Baby Ariel Stages (3-in-1 Crib)
Unique Oak Treasures Crib - Full Bed Bassett Model 5542-0521
We have this crib as well. We bought it from Babys R' Us in 2005.
We also purchased the rails to convert it to a full sized bed. It did not come with instructions but I can explain to you how to put it together.
The rail conversion set should come with 2 pieces of wood that act as the bed frame. You do not need to purchase the extended frame. The set should also come with 4 long screws, the hex tool to tighten it and 4 metal pieces. You might also have some wood nail cover plugs.
Once you've taken apart your crib, the only pieces that you will need are the 2 longer pieces of the crib...the headboard and the footboard. The 2 shorter side pieces which served as a headboard and footboard as a crib and the metal grate to hold up the mattress can be put into storage.
On the sides of each of the new wood rails, you will see a circle indent on each end with a hole. You will insert one of the long screws into each and then insert it into the head board. You must use the special tool to screw/ tighten it in. The metal flat pieces can be inserted into it the circle befor eyou are done tightning so that it does not strip or damage the end of the circle. You do this with the other rail on the other end and then add the footboard using the same process. If you would like, I can send you a copy of what this looks like close up. ( the cricle indent with screws. The bed is extremely strong. We've all napt in it as a family along with our 2 large dogs. I highly recommend ordering the extra long/ tall bed rails from OneStepAhead for security because my son has rolled out of the bed and it is super tall!
http://www.onestepahead.com/catalog/product.jsp?productId=534602&parentCategoryId=85183&categoryId=85216&subCategoryId=86203
Jul 12, 2009 | Bassett Cottage 3-in-1 Crib
Converting Delta Martinique 5-in1 Crib to single bed
I have the same crib and it can be transformed into a toddler bed by removing the front rail and it can be transformed into a full size bed using a full size bed frame and the front and back rails of the crib.
May 30, 2009 | Delta Martinique 5-in-1 Crib
I need the instructions for the cosco heritage collection crib model number da0504kmc1w
This site has instructions for the cribs listed below. The 1st two listed seem to be generic cribs with a metal mattress support. It worked for my used crib.
www.milliondollarbaby.com/help.milliondollarbaby.com/
*For cribs with snap-in spring hangers hooks & metal mattress support.w/ spring hanger hdware.
*For cribs w/ bolt-in metal hdware for metal mattress support w/ metal hdware.
For cribs with Safety Glide nylon(rodless) hardware
Sleigh Convertible 3001 Crib
Sleigh Convertible 3091 Crib - Safety Glide
Jenny Lind Crib
Ashley/Alexandria Crib (1 piece headboard) +Day bed info.
Ashley/Alexandria Crib (3-piece headboard) +Day bed info
Lauren Crib ) +Day bed info
Emily Crib (One piece headboard) ) +Day bed info
Emily Crib (Four-piece headboard) ) +Day bed info
Mini Emily Crib
Anastasia Crib
Bridget Crib
Valerie Crib ) +Day bed info
Bailey Crib ) +Day bed info
Ellie Crib Day bed and full bed info
Kalani Crib Day bed and full bed info
Bordeaux Crib Day bed and full bed info
Annabelle Mini Crib
Italian Cribs-Metal Barrel Nut
Italian Cribs-Nylon Nut
Canopy cribs with snap-in spring hanger hardware
Canopy cribs with metal bolt-in hardware
May 17, 2009 | Baby Gear
Need instructions ofr converting crib to a toddler bed.
Jenny Lind Crib
Mini Emily Crib
Anastasia Crib
Bridget Crib
Annabelle Mini Crib
May 16, 2009 | Bassett New Haven 3 N 1 Crib
Need help converting simplicity 4in1 crib to full bed
spacer.gif You can call or email and get the instruction sheet.
You can also call and they might be able to walk you through how to do it.
Our instruction sheets are available upon request.
Please call the Customer Service Toll-free Hotline:
Mon thru Friday - 9:00 am to 5:00 pm EST
1-800-858-8323
Or e-mail Customer Service:
customerservice@simplicityforchildren.com
Apr 25, 2009 | Simplicity for Children Ellis 4 in 1 Sleep...
Need Help converting the Storkcraft Ariel Crib into a full size
Beats me. All the frames I am familiar with have brackets at the headboard end and open channels at the foot. Maybe Storkcraft can explain.....
Dec 24, 2017 | Storkcraft Baby Ariel Stages (3-in-1 Crib)
Baby Gear Logo
94 people viewed this question
Top Graco Baby Gear Experts
gggg
Vincent_G
Vincent_G
demecoj
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
