Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool Washer model #LSQ9549LW0
The top of the washer has come loose from the base. It is the front of the machine. How do I seperate the outer shell to fix the problem?
    President:
  • Whirlpool Master
  • 2,651 Answers
You see the way to remove in theses you tube vidoes- easy enough
Posted on Oct 31, 2008
I have a Whirlpool #GHW9100LWI washer. The drum just started to wobble and sound like it was banging the sides of the washer. What should I be looking for?
Hello, Thank You for using FixYa. I will be helping you today. If the inner metal spin basket is loose when you try to move it in and out or up and down check to see if the pulley on the back is loose or damaged if you see a leak by the pulley the bearing failed. If its the outer tub moving too easy there are two springs on top and legs on the bottom to check if one broke.
Thank You and please rate my answer if it was helpful..
Jun 10, 2011 | Whirlpool GHW9100L Front Load Washer
Top enter collar of a whirlpool washer was pulled lose.
Greetings,
they have plastic tabs that lock it to the side of the outer tub. Its possible the front cover needs to be removed to gain access to the tub. The console needs to be removed and flipped up and two spring clamps hold the front cover on and there are one in each corner....now, you can actually remove the whole front off of the frame and work on the whole washer easy...Bruce Denton
Jan 23, 2011 | Whirlpool LSR5132PQ Top Load Washer
How do I open the top of the washer to change out the lid lock part?
top/front of washer seperates by way of hidden clips. insert putty knife or butter knife between front seam of cabanet and top. about 2 inches from left side and 2 inches from right side push in and pull up on top. lid switch is located under top/front
Nov 19, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
How to remove back & top of a whirlpool ultimate care II washer
I'm not sure of the model number of the stove but usually slide a putty knife under the control panel between the bottom of the control and the top of the base. There is a clip on each side then the panel will tilt back and you can take it off. After that there are 2 gold clips that hold the back on to the base. Remove them by snapping then out of the base. The the whole thing is loose and the base (where the lid and sides are. Comes out as 1 big piece. If you get the model number from under the lid, you can go to http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
and it will show you a breakdown of the machine. Let me know if you need anything else.
Mar 29, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool "Roper" top-loading washer leaking
two screws hold back control panel on. panel flips up. two clips hold case on. remove clips and lid switch plug and whole outer case will tilt forward off machine base. pump is down in front and can be bought separate.
Apr 14, 2017 | Roper RAX4233PQ Top Load Washer
The top of the washer has loosened from the base. How do I take off the outer shell to fix the problem? It is in the front top of the machine.
Here is a schematic of a base model of your series. More than likely the block drive is loose which is part 17 and should be replaced along with the nut.
http://www.searspartsdirect.com/partsdirect/retrieveSubComponentPartsAction.action?modelNumber=LSQ9549LQ0&productCategoryId=0153200&brandId=1198&modelName=WASHER - DIRECT DRIVE&diagramPageId=00003&componentDescription=AGITATOR, BASKET AND TUB&documentId=W0207069&backToLink=Return to Sub Components list
Oct 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool LSQ9549lW0
sounds like something is stuck in the water pump. look under the machine and you will see the water pump front and center of machine.
Jul 14, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool super capacity Lsq9549lw0 has trouble spinning on its own.
If the washer does fine thru the agitation cycle (the washing), that means the motor is OK and the coupler is OK.  It would not agitate unless both are OK.  (and don't listen if anyone tells you the lid switch is bad -- machine would not fill & go thru wash cyle). The spin is another matter.  There is a separate tube for spinning the basket.  There is a drive  block at top of the tube (that sometimes fails)  and there is a separate cluch mechanism below, under the tub.  Those places is where you should look.
May 14, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Thin twin
on this  problem one of 2  the Shocks have pulled a part (seperated),possibly even broke off.After removing the front panel ,you'll see that on each side towards the rear of machine you have a shock ( similar to a car) arm starting from the base and angling upward where it meets the tup.Look for the seperation there and then let me know and I'll be happy to guide you through this.
May 10, 2008 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
160 people viewed this question
Dan Webster
Dan Webster
Sal De
