Question about Rival FSD200 4-Cup Rice Cooker
Steamer keeps shutting off.
My steamer works for about 2 minutes and then shuts off. I tried different water levels-makes no difference. Tried without removable ring-no difference. Tried different time settings- no difference. Please help!
  • 1 more comment
  • mariaoui Nov 01, 2007
    I have the exact same problem and I tried all what's been tried by this user with no success. Any suggestion?
  • firemanbob Mar 23, 2008
    Same problem. Tried different water levels, more/less time. Still no luck!
  • Anonymous May 22, 2009
    It seems to run for a max. of 40 minutes and then shuts off. I then cannot get it to run after that for more than 2 minutes either. I've ruined dinner already cause it won't start again. I'll try the cold water thing .
I have the same issue, but if I use cold water (15 C, 60 F), the steamer works. Hope this help.
Posted on Jun 23, 2008
  • Lawrence Fenton Oct 01, 2012
    I have this steamer and found that if you clean the heating post in the center some times it gets covered with scale. Remove this scale with a knife and the unit doesen't over heat and keeps working fine. Works for me .......
My shark professional steamer plug gets extremely hot. Is that normal?
no it should not get hot undo the plug and check if the wirers are conected tight one of the main causes is loose wires, have you tried a differant outlet.
Jan 22, 2013 | Vacuums
Rowenta Pro Steamer only works 5 minutes then shuts off!
temp limit switch bad... replace iron(sorry)
Jul 04, 2012 | Rowenta Irons
I need cooking instructions for RC3406 6 cup rice cooker and steamer
Since a steamer is a steamer, try the following suggestions:
White rice: 1 cup to 2 cups water for 45-50 minutes.
Brown rice: 1 cup to 1.5 cups water for 45-50 minutes.
Hope this helps!
Mar 23, 2011 | Black & Decker RC4 6-Cup Rice Cooker
I just divcovered my Rival Rice and vegetable steamer in my storage area. I loved it and used it quite a bit and can't figure out how it ended up in storage. I'm not sure of the model number - but my...
For white rice, put 2 cups water in the bottom and 2 cups water in the rice dish along with 2 cups rice (also in the rice dish!). Plug it in and when the light goes out, it's ready. Also, one thing to remember is to clean the little well after each use with a bit of vinegar so it doesn't build up hard water deposits (unless you're lucky enough not to have hard water!) It makes a BIG difference in the rice steamer's operation. BTW: each mark on the side of the steamer's base is about 1 cup which equals about 20 minutes of steam time. Hope that helps. -Donna
Nov 12, 2010 | Rival Kitchen Appliances - Others
I have a Black & Decker digital steamer Model HS1300. The steamer works great but beeps 5 times every couple minutes when we use it...this usually indicates a low water level BUT the water level is...
I have the exact same problem - still no solution - this is the only posting I could find ... anywhere! If I figure out something, I will let you know. I love the steamer, but the beeping is also driving me nuts!
Feb 16, 2010 | Black & Decker Kitchen Appliances - Others
Heating on the 4450 goes off
After posting the problem I remebered that my mother used to use vinegar to desolve mineral resedeu from water containers and coffee machines. So I filled the heater well with some vinegar aqnd let it sit over night and it desolved the resedue. Under all that grit was actually metal and on a trial run the machine worked fine. So I'm pretty sure the problem is solved.
Jan 10, 2009 | Rival Automatic Steamer/Rice Cooker 4450...
Would you return this PS200 steamer?
If the steamer starts making a "gurgling" noise, like its running out of steam, hold the hose straight up for several seconds. It says to do this in the manual and gets the steam flowing again--works great!
Jun 13, 2008 | Homedics PS-200 Iron with Auto Shut-off
Rival automatic steamer rice cooker 4450 guide needed
Here's all the info I've been able to find:
The older Rival rice cooker steamer should have a base, a lid, steamer basket, and rice bowl.
To cook rice, fill center basin of base with water. Place the rice bowl on basin. Add rice and water as follows. For white rice add water in a 1:1 ratio to rice plus 1/2 cup. For brown rice add water in a 1:1 ratio to rice plus 3/4 cup. Examples: 1 cup white rice, 1-1/2 cup water; 2 cups brown rice, 2-3/4 cups water. Put lid on and plug in and in about 50 minutes you should have delicious rice.
Timing is Everything
Whether using the Rival Steamer for a main dish or for a side dish, cooking is easy. But not Fast. Rice and steamed vegetables actually take twice as long to cook in this steamer. The simplicity comes since you add your rice or vegetables in one step. No waiting for one thing to happen before you can do the next. Put water and fruits, vegetables, fish, poultry or rice in the basket or bowl that come with the unit, cover, plug in and wait for the light to go off per the timing chart.
1/4 cup water takes 6 -7 minutes
1/2 cup water takes 10-12 minutes
3/4 cup water takes 16-17 minutes
1 cup water takes 19-22 minutes
1.25 cups water takes 24-26 minutes
1.5 cups water takes 26-30 minutes
2 cups water takes 38-39 minutes
2.5 cups water takes 43-44 minutes
3 cups water (max fill) takes 45-50 minutes.
Steamed Chocolate Pudding (From the Rival Steamer Guide)
3/4 cup flour
3/4 teaspoon baking powder
1/4 teaspoon salt
1/3 cup butter
1 teaspoon vanilla
1/2 cup sugar
1 egg, beaten
1.5 ounces unsweetened chocolate, melted
1/2 cup milk
1/4 cup chopped nuts
Sift together flour, baking powder and salt; set aside. Cream butter and vanilla until fluffy. Gradually add sugar, beat well. Add egg and melted chocolate; blend well. Add milk alternately with dry ingredients and beat until smooth. Fold nuts into batter. Pour into greased 8"x4" loaf pan. Cover pan with aluminum foil. Place pan in steamer basket. Cover and steam until wooden pick inserted near center comes out clean. Serve warm with **Marshmallow Cream Sauce. Water: 1 cup. Time: 19-22 min.
**Marshmallow Cream Sauce:
16 large marshmallows
1/3 cup cream
In a small saucepan, combine ingredients and melt over low heat. Serve over Steamed Chocolate Pudding.
Feb 23, 2008 | Rival Automatic Steamer/Rice Cooker 4450...
Rival FSD200 4-Cup Rice Cooker Logo
1,588 people viewed this question
Top Rival Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Ric Shull
Ric Shull
Level 1 Expert
Craig Butler
Craig Butler
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
