Question about Samsung SyncMaster 753S 17" CRT Monitor
Samsung 753S focus problem
I have taken the back off the monitor and spray painted it. On putting the back on I find that the focus is out, test is fuzzy looking. I would appreciate any suggestion as to how to fix this.
  • shuvendu Jul 07, 2008
    I am having a samsung syncmaster 17 - inch monitor. When the monitor starts it takes aroung 15 mins to gain the normal brightness and proper focus. what could be the problem? and possible solution... Please help.
  • Peter Dragonetti Nov 10, 2008
    I have a astvision 7u, have same problems with focus. It comes and go the focus. It did start after i connected to another komputer and back again. During tonight the monitor starts totally out of focus and after 15 min it becomes normal, and after it has that it go from normal to unnormal(out of focus) look.
  • 36 Answers
To adjust the focus control(s), some monitors have a set of focus controls, some are on the pcb, some are on the circuit board and some have both.(gosub warning message)
while KEEPING ONE HAND IN YOUR POCKET use an INSULATED SCREWDRIVER to adjust the focus controls if there are 2, do one then the other and go back and forth until the correct focus is obtained, if you can not see the screen easily work from directly behind the monitor and place a mirror in front so you can see the monitor from there.
after getting the focus correct use a small drop of nail polish between its adjustment shaft and the housing to lock it in place.
warning message:
THE HAND IN YOUR POCKET IS TO KEEP YOU FROM GETTING A SHOCK THAT COULD GO ACROSS YOUR CHEST AND DO DAMMAGE TO YOUR HEART!!!!!! THERE IS A LOT OF VOLTAGE ON THE ANODE CAP OF THE PICTURE TUBE, AS WELL AS A FEW OTHER PLACES IN ANYTHING WITH A CRT.
return
Posted on Oct 17, 2007
  • 105 Answers
Focus controls are on the back of the flyback transformer. You may have bumped one while the back was off. Due to dangers working on live circuits I recommend you have a service professional adjust the focus.
Posted on Sep 04, 2006
My samsung magic cdp17s monitor starting focus out after 5min is ok
Posted on Mar 17, 2008
4 Suggested Answers
Sahill
  • 23 Answers
SOURCE: Removing the back cover of a Samsung SyncMaster 753s
there is 2 lock on front side first remove back side lock or scrow then insert small pin pull up back cover your monitor will get open
ashok
Posted on Jan 21, 2008
  • 563 Answers
SOURCE: How to open the back cover of Samsung SyncMaster 794mg CRT .
"Don't kill yourself just to save some bucks"
Here are the instructions:
http://www.josepino.com/?open-samsung-back-cover
Posted on Aug 29, 2009
Testimonial: "very thanks...."
  • 563 Answers
SOURCE: how to open monitor samsung syncmaster 753s?
CRT monitor screen is out of focus.text and other images looks blurry
This kind of symptoms can be correct by the focus adjustment at the flyback transformer. FBT mostly has two control knob (Focus and Screen), focus is usually at the top one like in the sample picture below.
Open the back cover of your unit and then locate the FBT. Power on the unit and try to adjust the focus knob.
If the symptoms can't be cured by the this step, this is an indication that the CRT socket is already faulty. You have to replaced this parts and then make some adjustment at the focus knob of the FBT and your unit will back to normal again.
CRT(picture tube) socket
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Jdvillanueva
Jul 14, 2011 | Samsung SyncMaster 753S 17" CRT Monitor
Samsung sync master 753s i want size in inches
Hi, The Samsung SyncMaster 753s is a 17" CRT Monitor that has a native resolution of 1280x1024 and with exterior dimensions of: (WxHxD) 16.2"x16.4"16.5"
Hope this helps. If it does, please accept and rate the solution! Contact me with any more questions you may have. Thanks for using FixYa!
May 22, 2011 | Samsung SyncMaster 753S 17" CRT Monitor
Monitor control panel locked
your flyback transformer inside the monitor is failing, you can have the focus adjusted inside by a qualified monitor repair center..
May 09, 2010 | Samsung SyncMaster 753S 17" CRT Monitor
I AM USING A SYNCMASTER 753S MODEL MONITOR NOW THE LETTERS ON THE SCREEN ARE NOT CLEAR (FOCUS OUT) WHAT IS THE SOLUTION
your CRT is need to be recharged ..It can be done in any electronics workshop..Its basically due to aging of monitor...
Thank You For using FIXYA!!
Dec 01, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
How to open monitor samsung syncmaster 753s?
Aug 11, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Diaplay Letters not cleard
Open your monitor's back cover and on the circuit laid underneath the CRT you will find a big black object. Check it, there will be two knobs having H- focus and V- focus, control them and your CRT will focus correctly. If still problem persists on the CRT there is a white box with three control knobs, adjust them.
Jul 24, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Focus on monitor
Try replacing the filter capacitors on the video circuit.
Apr 28, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
SYNCMASTER 753S
I would say your monitor is toast. However, you could test this theory by hooking up another monitor to it and see if it does the same thing.
Mar 25, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
ashok
Jan 20, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Samsung SyncMaster 753S 17" CRT Monitor Logo
950 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
