Question about Sony KP-57WS500 57" Rear Projection Television
57 in.sony projection tv
Half of tv clear the other half of tv not focused
My stnby light is blinking of and on and the tv will not power up
Posted on Nov 06, 2008
Where is the magic focus button?
Most Sony Rear Projection TV have a small door under the screen with some manual controls. Push on spring loaded door to open. Magic Focus is near the bottom and labeled.
If Magic Focus does not restore for correct operation, check the Convergence Gallery to confirm if you have a convergence fault that needs repair. #8 is the Sony menu.
easyab@hotmail.com
Feb 11, 2011 | Sony KP-57WS500 57" Rear Projection...
I have recently moved my Sony 57" projection tv and the image is now blurry. I have tried adjusting the convergence manually but I'm no longer able to line up the crosses.
Adjust focus block, then adjust each of 3 lenses. loosen w/ thumbscrew, then turn cylinder to focus onto screen. Focus each by covering the others w/ typing paper, then tighten.
Jan 18, 2011 | Sony KP-57WS510 57" Rear Projection HDTV
Colors are separated red, yellow and green so picture is blurred
lgray1010,
Try using the Flash Focus to/or manually try to dial in the convergence. If you are unable to focus the TV using its convergence adjustment it's time to call the TV repair guy. Figure on between $250.00 and $400.00 USD.
-Chris
Aug 24, 2010 | Sony KP-57WS500 57" Rear Projection...
I have a 57" sony kp-57ws500 rear projection t.v.
the tv he mentioned is not plasma or LCD, it's rear projection with tubes.
brad, you'll have to take off the front panel. there are two phillips head screws behind two small round plastic covers, one at each end of the bottom of the speaker covers. remove those, lift the cover slightly, then pull down. be careful because the plugs for the front panel controls don't have much slack. unplug those and set the cover aside.
there is a rectangular cover to the tubes and focus panel. remove that, set it aside and you'll have access to the focus and alignment controls. the white markings on the knobs are factory reference marks. IIRC, the top is the focus and the bottom is the alignment. use a flashlight to check because it's marked.
make the adjustment as necessary to get a clear picture. =)
Jan 07, 2010 | Sony KP-57WS500 57" Rear Projection...
Sony rear projection tv will no longer focus. tried flash focus & manual focus
Convergence issue. The sony type 1 convergence kit from www.tvrepairworld.com should repair that issue. The kit contains the parts and CD with instructions.
Dec 31, 2009 | Sony KP-57WS500 57" Rear Projection...
Picture goes out of focus
besides using a bigger hammer you need to adjust the focus controls under the speaker cover from the front
Feb 25, 2009 | Sony KP-57WS500 57" Rear Projection...
Sony Projection TV turning blue
SOUNDS LIKE YOU NEED A NEW FLYBACK COMMON ON THIS MODEL COST AROUND 70.00 FROM SONY PARTS...PART NUMBER #145328521 LOCATED ON THE d-BOARD
Nov 30, 2008 | Sony KP-57HW40 57" Rear Projection...
CONVERGENCE
replaced the CRT socket this might fixed the problem...
Aug 01, 2008 | Sony KP-57HW40 57" Rear Projection...
QUEStion About Sony KDP57XBR2 57" rear projection High Def PiP 1080 TV>>>>
5 flashes is IK or current to cathode. check the IC's on the crt boards, check the focus block, check the vertcal deflection IC since the IK pulses come from the verticl cicuit.
Mar 16, 2008 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Sony tv KP-57XBR10W
Correct ! One set is for RGB focus and the other set is for
RGB screen voltage............................T.
Oct 05, 2007 | Sony KP-57HW40 57" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
69 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
