Question about Panasonic KX-P1131 Matrix Printer
PANASONIC KP-1131 CAN NOT TEAR OFF HALF PAPER
Hi
i recently facing a problem of loading half paper after finished printing. i custom the paper size into 8.50*5.50 inch but the printer kx-1131 keeps loading to the position of letter size bottom insteads of loading to the position of half page as press the tear off button. i don't have alternative to solve this problem. I tried to use KX-1121 driver to solve such a problem but still cannot get through.
Need help urgent!
Tony Tang
4 Suggested Answers
dodgecharger
  • 254 Answers
SOURCE: Tear off
First, if you have your manual, look it at for possible solution. Does this printer have a "load" or "top of form" function? There may be a "programmable" setting which will back the paper back down to the correct spot. The college where I'm employed used to have several Panasonic dot matrix printers, but almost all are now long gone.
Posted on Sep 19, 2007
SOURCE: driver panasonic kx p 1121 muti mode printer
hi kindly download the drivers for ur printer from the follwoing link.....
http://www.printcountry.com/drivers/PANASONIC_KX_P_1121_DRIVER_DOWNLOAD.htm
you wud be required to provide ur OS details and select ur model number from the list....
kindly rate my service..... good luck
Posted on Jun 20, 2009
  • 9 Answers
SOURCE: wants to get drivers to run in win 7
EPSON LQ Series 1(80) INBOX Driver
This driver is in the Windows 7 default driver data base
Just let windows 7 install the driver for itself.
Posted on Feb 01, 2010
Printmaster half-fold printing on epson printer
Before printing you need to select the size and orientation and it's a good idea to look at the preview before printing. That saves a lot of paper.
Nov 19, 2017 | Epson Office Equipment & Supplies
My copier canon ir2525 legal size paper jamming problem half paper exit unit out half paper exit assembly in A4 size and A3size 100%perfect exit plz solution this problem
Most common jam problems are caused by using thin paper 80g density or less. Recycled paper is the worst as it tends to tear easier as the their is only 20% new cellulose fibre in it and 80& is paper mache'. When using recycled paper, use min 100-120g weight papers and your jams will disappear.
May 29, 2015 | Canon Office Equipment & Supplies
Hi there! I would like to set my paper to 8.5 x 5.5 or half of the letter page but i don't know how to set it up. I can't find the proper paper size for that. I am developing a system that is using 8.5 x...
Could you possibly print 2 to the page. You may have to change the top margin so it wouldn't take more than half sheet. Just a though. Hope this helps!
Aug 05, 2017 | Epson LX-300+ II Matrix Printer
How to set half half size paper
Look for a latch on the right side tractor drive. This will unlock it so you can slide it sideways on its rail. Set it approximately where it should be, load the paper, then adjust it so you have a slight amount of tension across the paper. I think the rest is software.
Jun 25, 2009 | Epson LX-300+ II Matrix Printer
Printing a custom size card with a C7280,
There is a workaround for this problem by tricking the printer.
The paper sensor, on my printer model hp4500 seems to only sense the paper at the beggining of the print job.
What I did to trick the printer to print on odd size paper is slide the paper adjuster to 8.5 and put a regular white sheet in. Then put your odd size paper under it. When you print your document set the number of copies to 2 and print. The printer is going to sense that the paper is correct, and start the job.
Here is the tricky part... once the first 8.5x11 sheet is almost all the way through quickly slide the paper adjuster over to match the size of your odd width paper. The printer should pick up the odd paper and print the second copy. Fool you printa! You should be able to do batches of odd paper size under the first 8.5X11. I hope this helps.
Deny
Jun 05, 2009 | HP Photosmart C5180 All-In-One InkJet...
Mismatch paper size error
Click on Print, then Properties, then features.
About half way down there is a drop down box under sizing options.
Click on custom
Create a name, and put your width and height in.
Click Save and then OK
Completely X out of the print options.
Then Click
File, print
on the bottom of that screen there should be a scale to paper size drop down box. Scroll to the bottom and your saved name and dimensions should be there.
You will have to setup each individual sized template ones and then just scale to fit each time. Hope this helps
Mar 26, 2009 | HP Photosmart C4480 All-In-One InkJet...
Thank you for taking my question: HP laserjet print using Vista
go to printer propeties and check paper size ther'l be a custom size click on that n feed what u wnt
Dec 11, 2008 | HP DeskJet 880c InkJet Printer
I have installed the HP Photosmart C7280 All-in-One and tried to print an article off the computer. I have paper loaded in the tray-I get a message Out of Paper. Load paper face down in Main Tray. What's...
I experienced the same problem on a HP Photosmart C7280 All-in-one printer. The problem was that the light-blue plastic piece, which covers half of the printing paper tray, had gotten out of alignment with the gray piece which covers the other half of the paper stack. Pull the blue plastic tray out and align it properly.
Apr 11, 2008 | Office Equipment & Supplies
Paper size..
In WIN98 with WordPerfect9 we had set up dot matrix printer Epson LQ1050 on which to print 8.5" wide by 5.5" long (half page) multipart invoices. In XP apparently MSFT changed this and there is no custom paper size in windows printers. Instead one must use the program's (Word Perfect) page setup where the page size can be entered. Problem is the Epson drivers have not been rewritten to incorporate this change. The optional paper sizes are builtin to the printer drivers. Some folks with the same situation as you have had success using the Forms menu in MS Fax to set different paper sizes. Third party programs such as FinePrint (www.fineprint.com) can also help with this. I hope you work it out ;]
Apr 23, 2006 | Epson TM U210A Matrix Label Printer
Panasonic KX-P1131 Matrix Printer Logo
779 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
