Question about GE Spacemaker JVM1640SJ Microwave Oven
Microwave Turns on but doesn't heat
Kitchenaid kehc309jss05
  • baumer868 Nov 01, 2008
    I have this problem too. For a while it was making a strange sound but that has stopped. It seems to work fine but does not heat at all. Display and other stuff is fine. I unplugged an replugged, but the same thing is happening.
  • ninervic55 Nov 02, 2008
    GE spacemaker microwave oven doesn't heat. Motor, interior light, & auto carousel all work fine. Checked fuse behind front panel on right side & fuse is good. Don't no where to go from here.
  • GE Master
  • 19,396 Answers
Test the high voltage capacitor, the rectifier diode.or the magnetron.
If it additionally does not spin and no light, then check also the door switch.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Posted on Apr 27, 2009
Kitchenaide Superba #4450786A unit turns on but will not heat at any setting. What can I do to fix?
Magnetron needs replaced.
CAUTION: Your microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. We strongly suggest you seek the assistance of an appliance repair technician when conducting any microwave oven repair.
Cheaper to buy a new Microwave oven.
Jul 11, 2014 | KitchenAid KCMS185J Microwave Oven
Not heating efficiently; works but doesn;t heat as well
If it is taking longer to heat things than normal then it would appear the Magnetron to starting to wear out, this is a normal sign of inefficient power from the magnetron & would need to be replaced.
Dec 26, 2012 | KitchenAid Microwave Ovens
GE Profile Spacemaker 2004 JVM3670BF02 doesn't Heat up
Ensure that you have select the correct range of temperature.
Sep 11, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave turns on but no heat and turntable doesn't turn
It is one of two things, a defective door switch, "most likely" or the keypad control board is faulty.
Apr 22, 2012 | GE Spacemaker JVM1540 Microwave Oven
The letter d on screen.turns on but doesnt heat
Your microwave is in demo mode, which means it will not heat. To turn it off touch and hold TIMER SET/OFF for 5 seconds until 2 tones sound and the "d" disappears on the display.
Aug 27, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
My unit turns on by itself and recently it stopped heating up anything you put in
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Aug 31, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
The microwave comes on and tray turns but not cooking/heating. Anything I can do?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101
Apr 20, 2010 | KitchenAid KBMC140HSS Convection/Microwave...
KITCHENAID KEHC309JSS05 NO POWER
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open. Then when it cools, it closes the circuit and allows power through again.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again. If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There may also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 07, 2008 | Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
674 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
