Question about Rheem RTG-53XP Outdoor Liquid Propane Tankless Water Heater for 1-2 Bathroo
Installed during the summer,it turned cool unit will not light.
I installed the unit during the summer,no problems now that it has turned cooler unit will not light up.
I contacted rheem,they sent me a new board and a high altitude programming chip,i barely live above sea level,it fixed the problem.rheem said the board had lost it's program.
Posted on Nov 03, 2008
  • 104 Answers
Check power -ground- fuel- and for animals hiding our for winter(nests) squirrels?
Posted on Oct 31, 2008
Heat will not shut down, continues to get hotter
there might be a broken hot water pipe somewhere and so that might be causing the heater to stay on as its not getting to temperature.
Sep 26, 2016 | Water Water Heaters
After city changed water meter the water is not consistently hot.
There are two things to check. First, check the inlet water filter on the heater. The changing of the meter may have introduced debris in the line and partially clogged the filter, causing flow issues that affect turn-on/turn-off of the unit. Also, the new meter may have changed the water pressure/flow rate into the house, If the filter is not the problem, have the inlet water pressure/flow rate checked. If it is too low, there may be some adjustment that can be made, or the city may have to replace the meter with a different unit.
Dec 01, 2015 | Eemax EX280T2T Series 3 Whole House...
Electric GE Water Heater Not Heating Water
One possibility: Push in the reset button located on upper thermostat.
Copy following link for troubleshoot walk-thru, and DIY checks:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#new
Nov 04, 2012 | General Electric Water Heaters
Had three 50-gal American Standard water heaters installed Dec. 2009 Two upstairs in attic, one downstairs at ground level. Attic location used because heaters being replaced were up there. Upstairs...
Plumber is right.
Problem is not amount of air in attic. Problem is how hot the air is.
Oxygen molecules separate apart in very hot air and pilot light goes out since there is not enough oxygen density to support combustion.
http://waterheatertimer.org/images/Water-heater-in-attic-800.jpg
http://waterheatertimer.org/pdf/Attic-Ventilation-and-Pilot-Outage-in-Gas%20Water-Heaters.pdf
More ventilation is needed.
Plumber is not ventilating expert, and not responsible for attic ventilation that builder failed to install. Plumber should do a survey of location before installation to make sure gasoline vapors are not stored nearby, but summer attic ventilation is gray area until more general-public folks become aware of problem. Hotter summers temperatures will spread that information.
Hire local home center to install roof vents AND soffit vents.
Note: You also need soffit vents.
Remember a vent on the roof is like sucking air out of a coke bottle. The roof vent is no good unless air can also enter the attic from another vent located in the soffit.
Another solution is electric water heater for very hot locations.
Or install solar-assisted water heater.
http://www.hotwater.com/products/residential/cirrex_solar.html
Jul 28, 2011 | American Standard 40 G Natural Gas Water...
I'm tired of my tankless water heater after two years. We can't get it to stay on more than 30 seconds. I've taken it apart, and it is clean. Had a service guy come out and he offered to clean it for $228....
ok code 11 is a gas issue... i would take a guess that you dont have a 3/4 inch gas feed, from the meter to the unit, and if you do..you home gas furnace is close to the unit. I will also take a guess, that you did not have the problem during the summer
am I close.....
Dec 24, 2010 | Rheem Paloma Tankless Water Heaters...
How do you fix hot water shuts off during shower with Model N-069M-OD installed December 2006?
Try flowing more hot water with your shower. During the summer you end up mixing alot of cold water and very little hot water (because your cold ground water isn't so cold in the summer). When you get close the minimum flow rate of the appliance, it will start to short cycle (fire on and off). Here's some recommended things you can do:
1) Clean the shower head - remove scale deposits and or clogging
2) Widden flow restrictor - most shower heads have a flow restrictor on the back of the showerhead; It consists of a rubber washer with a hole in the center. You can widen the hole using a drill bit.
3) remove the flow restrictor - this should be a last resort
Jul 22, 2010 | Noritz 6.3 Gallon Residential Tankless...
Pacific water heater light dims and water does not heat up
sounds like an electrical problem, consult an electrician
Jul 12, 2010 | Pacific International Water Heater...
Heats up the rapidly decreases within in minutes.
Problem new or old? How long you have unit? Sounds like not enough flow to keep burner on. Tankless need at least .6 gpm to keep hot water flowing or else the burner fires then shuts fires then shuts and you get a sandwich effect...hot cold hot cold. If you have new diverter valve in shower -vs- old two handle type try turning hot water ALL the way ON and see if hot stays hot. If it does stay hot then slowly adjust to cool and see if you maintain a good MIX for proper temp. If it goes cold again try this......LOWER control pad setting to a comfortable 105 degrees (ladies) 100 degrees(men) and turn shower valve all the way to HOT. See if your temp remains consistant now and if it does then problem solved. Tankless mindset...set temp on control pad and stop trying to MIX at shower valve. Thats how these things work. Thats why I install a control pad in each bath and one in the kitchen for adjusting ash temp during dishwasher on time. ditto for wash machine. You should never need to turn on cold water if your unit is set to proper temp at controller. Hope this helps
May 17, 2010 | Rheem Tankless Hot Water Heater...
The hot water shuts off during a shower. All the
One of the problems with these has been that you must be using at least 1/2 gallon per minute for the burners to ignite. In the summer when the incoming water is already warm, we tend to not use enough hot water to keep it lit. Try turning on the hot water faucet in the sink and 'wasting' some hot water during the shower. If that fixes the problem you can find some other adjustments on the Aquastar website to help lower the temp some.
Jul 04, 2009 | Bosch AquaStar 2400ES-NG
Rinnai tankless water heater code 12
12 - Flame Failure or Poor Ground
1. Immediate code 12 is usually a defective gas valve, power supply problem, or defective fan motor wiring harness.
2. If code 12 occurs after a few seconds it indicates that proper operation was established, but then stopped unexpectedly.
3. Verify that fuel is being supplied to the unit.
4. Check for proper electrical ground. Unit must use a grounded power supply.
5. Check for flue blockage on inlet or exhaust.
http://www.foreverhotwater.com/service-codes.php
Dec 31, 2008 | Rinnai Webstone The isolator EXP tankless...
Rheem RTG-53XP Outdoor Liquid Propane Tankless Water Heater for 1-2 Bathroo Logo
87 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
