Question about APC AP5017 (Black) 17" LCD Monitor
LCD lost colours
The display unit has lost some colours, consequently, the background has turned allitle more blue. The text colour is black though.
0 characters
1 Points
How to fix my Benq Monitor which is scrolling full screens of different colours.
all modern LCDs have ONE and ONE only native screen size. since you did not tell us the model number we have to tell you maybe you are setting the wrong size. if the monitor has worked before then you are sending it the wrong signal.
Jul 25, 2016 | BenQ FP91V (Silver, Black) 19 inch LCD...
What your describing is a major video problem, poor color and it is blurr, It would be far cheaper to replace the monitor with a new one.
Mar 08, 2012 | Samsung SyncMaster Computer Monitors
My Acer AL1717 Screen has turned Blue......I just want to know how to Turn it back to normal colour.....Anyone can Help??
reset your monitor color setting by the following setting
Press the menu button
Select Reset
press enter
this will reset the monitors color setting to factory default
Jan 19, 2011 | Acer AL1717 17" LCD Monitor
White colour displaying as blue, and red colour displaying as black
It's simple i had the same problem the solution is u go to the settings menu in the monitor and reset the options and settings.
Sep 29, 2010 | ViewSonic E50C 15" CRT Monitor
Monitor turned pink
Video-cards generate "primary" colours (red, green, blue), and "mix" those colours to produce millions of "secondary" colours.
First, try replacing the "data' cable between the LCD and the video-card.
Second, if your LCD works correctly when connected to some other desktop or laptop computer, then the video-card in your computer is not working properly -- not sending one of the "primary" colours to the LCD. Replace the video-card.
Jul 17, 2010 | Samsung SyncMaster 931B 19" LCD Monitor
LCD monitor have Vertical lines and black colour become greenish
normally the 19" resolution can support up to 1280*1024, but if it comes with vertical lines in full screen, it might indicate the panel is no longer to work and probably it's time to replace new one.
Aug 12, 2009 | Neovo S 19 19 in. Flat Panel LCD Monitor
Black colour displaying become greenish and narrow vertical lines
Most LCD monitors have a default refresh rate of 60 Hz. Older monitors also have limited resolution. Please check your display settings and ensure you're not using a refresh rate higher than 60, or a resolution higher than what it supports. If either one is the case, you're lucky the LCD still works.
Aug 12, 2009 | Computer Monitors
My monitor displays bright green pixcells in the black areas of text and pictures .I have tried a different monitor (lcd also, no problem ) to isolate the fault back to the monitor.
some time we can see that of problem as screen convert in to voilat and green colour. it is called colour fade. assambaling parts is lose of bord and other. it can be correct by soilding by expert tech. it is more seen in old crt monitor. thanks
Jun 14, 2009 | ASUS LCD Monitor
Screen colour error
Recommend to go to the color settings and change it to the use settings and adjust accordingly.
Oct 17, 2007 | ViewSonic VA1930WM LCD Monitor
White colour is displaying as yellow
Your monitor is missing blue drive. Most likely a component failure on the CRT board. Bad color ICs, bad solder connections or defective capacitors can cause the problem.
Aug 25, 2006 | ViewSonic E50C 15" CRT Monitor
APC AP5017 (Black) 17" LCD Monitor Logo
Top APC Computer Monitors Experts
Brian Sullivan
Brian Sullivan
Are you an APC Computer Monitor Expert? Answer questions, earn points and help others
