Question about HP Photosmart C7180 All-In-One InkJet Printer
HP Photosmart C7280 wireless connection
How do I get a wireless connection between the PC and the printer? We've tried the wizard set up from the printer with no results.
  • JaiH Nov 16, 2008
    My HP C7280 will print through USB but won't print when using wireless connection. Instead, it shows the printer as "off-line". After spending hours trying to fix, I have resolved to using USB connection. It seems this is a major issue with this printer.
  • Anonymous Dec 30, 2008
    I have to re-install the driver, then it gets recognized as online. Hokey!
My experience is different. My DSL router died in the night and I had to install the old one. I just changed the wireless settings on my C7280, and now all three connections work. If no wire (ethernet or USB) is connected, the wireless connection works. If the Ethernet cable is connected, it works via Ethernet, and if the USB cable is connected, it works via USB. It seems to default in that order.
Posted on May 01, 2010
  • 3 Answers
I discussed this with an HP tech & worked on the solution myself to verify his answer &, of course, he was right!
Your printer will only recognize one connection: either wireless or hardwired but NOT both. That is why it keeps switching back to hardwired mode.
Jack
Posted on Jan 09, 2009
How do i set up my printer to print wirless after setting up the wireless wizard with my router
Presumably, the wizard helped you choose an SSID and a password.
On the controls on the HP printer, enter the SSID and the password,
and then the HP will try to connect to the wireless interface on the router.
Nov 17, 2010 | HP Photosmart C7280 Printer
My HP C7280 wireless printer is "ofline" how do I
Go to printer folder ( printer and faxes ) right click on the printer and choose " USE PRINTER ONLINE"
Nov 14, 2010 | HP Photosmart C7280 Printer
I have a hp photosmart c7200 all-in-printer and have a desktop which it is setup to. I also have a laptop which I'm tring to setup up wirelessly but having trobule. Any suggestions.
Have you run the Wireless setup wizard from Printer ? If No, Press Setup button on printer front panel - Scroll till Wireless/Network settings - Choose Wireless setup Wizard and follow the directions.
After you have setup printer on network - Run the Printer s/w disk and Choose Add a Device and Choose Wired/Wireless network and continue with the Installation screen.
Jun 24, 2010 | HP Photosmart C7280 Laser Printer
HP c7280 Stuck in print que...
Please click here and follow the instructions to clear the print queue manually.
Oct 07, 2009 | HP Photosmart C7280 Printer
How can I connect my wireless laptop to print wirelessly?
run the wireless setup wizard on the printer from the front panel menus of the printer...this would assign an IP address to the printer from the router...then use the s/w cd that came along with the printer and get the drivers and s/w installed on your computer....if you want a wireless connection it would give you approprite options
Jun 21, 2009 | HP Photosmart C7280 Printer
Will not scan
you will have to uninstall the scanner drivers from the computer in the control
panel>scanners..then uninstall the printer drivers from the printer in the control
panel and then run the wireless setup wizard on the printer then try reinstalling the
drivers and the s/w using the disc that came with the printer......see if works
May 16, 2009 | HP Photosmart C7280 Printer
Can't scan to computer
I am not an expert, only a c7280 user. I use my printer wirelessly and was having problem scanning when using the controls directly on the printer (scan menu). By trial and error, I tried scanning by going to HP solution center on my computer and just followed the directions from the scan menu. That worked. If you can print wirelessly, you can scan wirelessly. I agree the HP support is a huge waste of time. I only get mad talking to them.
Apr 16, 2009 | HP Photosmart C7280 Printer
Scanner
Hi, try updating your printer drivers:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop. Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done
anaanymous
Oct 13, 2008 | HP Photosmart C7280 Laser Printer
HP Photosmart C7180 All-In-One InkJet Printer Logo
1,556 people viewed this question
Seeker5211
Seeker5211
