Question about Singer Quantum XL-6000 Computerized Sewing Machine
Designs are not sent to the machine
My software will not work on my computer. I have tried three different computers. I went back to my husband's laptop which I used before and it worked fine. I cannot get it to communicate with the machine. I have changed cables, set the settings on my computer as one lady suggested. I cannot get anything to work. Diana
  • 11 more comments
  • bardiana Oct 29, 2008
    the laptop that I used is the exact same one that I used before and it worked. thanks diana
    I HAD ALREADY DONE THIS. BUT I DID IT AGAIN ANYHOW. STILL WILL NOT WORK. THANKS
    DIANA
    YES, I HAVE DONE THE UNINSTALL REINSTALL RESTART TWICE. THANK YOU
    I HAVE THE 9 PIN NULL CABLE THAT CAME WITH THE MACHINE. THANKS I ALSO HAVE ANOTHER ONE THAT I CHECKED AND THE SAME THING HAPPENED.
    I DID ALL OF THE THINGS YOU SUGGESTED THEN I WENT TO THE DOWNLOAD. IT WON'T INSTALL. I GET THIS MESSAGE. PSW 1.0 IS NOT INSTALLED IN YOUR COMPUTER. DIANA
    nothing is working so far
    I don't understand. What do I remove after I have run the above.
    still nothing
    It just says sew ware conversion tool V.1. When I try to download I get the message that I don't have psw. It has worked before but I can't get anything to work now. Thanks. Diana
    I cannot download the patch.
  • bardiana Oct 30, 2008
    When you say install psw.1, are you referring to the sew wear program? If you are, I have done this and I still cannot download the patch. Thanks. Diana
    I'm not the best with computers, but I don't think the connection is usb. It is the nine prong. Where would I find this under my computer? Thanks. Diana
  • bardiana Oct 31, 2008
    This didn't help either.
    Guru:
  • 558 Answers
You can download the Latest Version of PC Doc from the following location:
http://www.pcdocpro.com/update.php
Please save the program as a download, before proceeding to install it. It will remove all the problem in running the program you wish to run.
Hope it help you out from this problem
SCOTT
Posted on Nov 08, 2008
  • 19,396 Answers
Right your cable is not USB , it is a com port serial cable, (male or female) and you can buy it at any computer shop for a couple of dollars. Take with you the old cable to buy a new one.
Try buying a replacement cable, if the cable is defective the software won't work.
Here is an example:
NULL MODEM CABLE 9 PIN FEMALE TO 9 PIN FEMALE
Posted on Nov 02, 2008
    Master:
    Sergeant:
  • 449 Answers
Hi!!!
may the usb port try check it!!!
Posted on Oct 31, 2008
  • 52 Answers
There may be a conflict in your PC, because all the thing you have try to do.
Go to control panel and erase the program. Be sure that everything is erase, sometimes files may remain, go to the explorer and erase them manually.
Turn off the pc an re start it. Re install the software again, this will work.
evelasco
Posted on Oct 30, 2008
  • 728 Answers
The usb port of the machine may be messed up which will not allow it to communicate with the computer or let you get any patterns for your machine. Check to see if it will communicate with your computer to make sure by plugging it in and seeing if you can find it in my computer. If it doesn't appear, then there is probably something wrong with the port of the machine. You will need to get it checked up at a shop to confirm the suspicion and to get it fixed.
Posted on Oct 29, 2008
  • Jazz Boyce
    Jazz Boyce Oct 30, 2008
    Oh, yours is a nine pin port. It still should show up under my computer. Make sure the hardware is installed by going to my computer, clicking on the c hard drive, and going to program files and see if the software is on there.
    President:
  • 2,712 Answers
Install PSW1.0 on the computer where you want to use the software (not laptop). Next, download and install this:
PSW1.1WindowsCompatibilityPatch.exe
That will make it compatible and fully functional on all Windows platforms including Windows ME, Windows 2000 and Windows XP.
If you are running Windows XP SP2, then download this as well:
PSW11_WinXpSP2_Patch.exe
Once you have downloaded and installed the PSW1.0 on the computer, try to run an update to download the latest version of the software PSW2.0. Once done, install this as well:
That should resolve the issue.
  • Swilin Sampson
    Swilin Sampson Oct 30, 2008
    I think what you need is direct phone support, so that someone can walk you through the process real-time. Perhaps its best you contact Singer customer support:
    1-800-4-SINGER
    Monday through Friday, 8:00 a.m. to 4:00 p.m. C.T.
    Singer Sewing Company
    1224 Heil Quaker Blvd.
    P.O. Box 7017
    LaVergne, TN 37086
    Customer Service: 1-800-4-SINGER
    Customer Service Fax: (615) 213-0994
    Hope that helps!
  • 13,433 Answers
Is psw on the cd you got with the singer? if you can find the program from the cd, install it and after that get a update from this webpage
http://www.psw-support.com/Downloads/cpatch10.htm
I can also help you with remote support, maybe I could get your program working. Let me know if your intrested, use the add a comment button in that case.
    Sergeant:
  • 306 Answers
The problem is either compatibility; try right clicking on the icon and selecting Properties and then Compatibility tab. Click on run this program in compatibility mode for: and try the different options. by selecting, clicking ok and trying to run the program and if it does not work then select the next one.
Or it could be a failed install either your ant virus picked up something and corrupted the install or the computer must have been running a lot of programs at the same time.
These kinds of problems are usually solved by switching off any constantly running programs such as antiques, firewalls etc until the program has been installed and then enabling them when installed.
    Sergeant:
  • 213 Answers
the software that you are running is i think for designing
which is not running on your computer
now listen you saying that soft ware is running on your husband laptop and it worked fine right
i"ll give you an example ok
suppose you have a software ok
1. it contains so many files when you install it
2. but in the mean time when you install other applications
3 then their drivers and files overlap each other so some files stop working
in that case
it can't uninstall completely
you have to clear its registry first
go to start> run > type regedit> then search it and delete it
my friend have the same problem
now it is fixed
thanks
golu_fixya
for any doubt post comment
    President:
  • 1,952 Answers
Uninstall both programs. Reinstall only the Professional Sew Ware™2.00a and see if it will work. , the PSW doesn’t wantto share a port with another program. Perhaps there is another portthat you can use with your Palm Pilot.
A. Apatch is available to correct the compatibility issue with PSW 1.1& 1.0 and the newest versions of Windows®. Click here to download: Windows Compatibility patch for PSW.
  • 1 more comment
  • mohammed marika thambi
    mohammed marika thambi Oct 29, 2008
    • Place the card into the slot of the converter
      box (writing facing up).
    • From the tool bar, Click on File.
    • From the drop-down menu, Click on "Write
      to Card Writer".
    • If you are using the card for the first
      time the program automatically saves your design to the first
      empty space.
    • Click on "Write".
    • You may also select the desired space
      by clicking on it and then click on "Write".
    As long as the green light is flashing on the converter
    box, this is an indication that data is still being transferred.
    The card or the transfer should not be disturbed; to do so can cause
    a malfunction of the card
    These directions are to be used if you have
    purchased a USB/Serial cable to connect your converter or XL-6000®
    to the computer. You must also connect the nine-pin serial cable
    (this is a Null Modem cable) that came with the PSW� or the XL-6000®
    to the USB/Serial adapter.
    When trying to open the PSW® you will receive
    a message - "Card Writer Not Found" or if using the Sew-Ware Conversion
    Tool® the transmission will not go through.
    Once this procedure is completed, it may be necessary
    to re-install the software (especially the PSW).
    In the Conversion Tool in the "Transmit to Machine
    dialog" box be sure to set the COM port setting to the same number
    that the cable has been set.
    Configuring USB/Serial Converter Cable.
    After installing your cable's drivers from the
    CD provided, you will need to change the COM port setting.
    Find "My Computer" either under the Start Menu
    or on the desktop. Right click. From the menu left click on "Properties"
    In the "System Properties" dialog box left click
    on "Hardware".
    Then left click on Device Manager.
    This will open up a list of devices found on the
    computer. They are listed alphabetically. You will see a heading
    "Ports (Com & LPT)". Left click on the "+" beside it.
    Double left click on the name of your cable.
    This will open up the "Properties" dialog box.
    Then left click on "Port Settings".
    Left click on "Advanced".
    This will take you to the Advanced Settings.
    Left click on the drop down arrow next to the COM
    port number. Select the lowest numbered comport that is not in use,
    preferably 1 or 2.
    Then move the Receive Buffer down to "8" and the
    Transmit Buffer down to "11" by left clicking and dragging. This
    last step isn't always necessary.
    After this last step click OK or close all screens
    until you are back to the Desktop. In some instances it may be necessary
    to delete and then re-install your Singer® software.
    Remember to have both the Null Modem Serial cable
    that was included with your PSW 2.00a connected to the serial side
    of the new USB/Adapter cable. The Null Modem cable will then be
    connected to the #1 port of the PSW 2.00a converterbox
  • 3,037 Answers
The program loads fine I assume, what operating system is on the two computers (the one that does work and the one that doesn't). Try disabling all of the security on your computer while you try to get it to work. Possibly something is blocking it but please let me know if the OS is different between the two computers and if so, what is it on each as that may be the reason that it isn't working.
  • Benjamin Patri
    Benjamin Patri Oct 29, 2008
    I'm sorry, I'm confused, which computer won't it download onto now? If it is your husband's computer, have you tried doing a system restore back to when it was working. and would you mind directing comments to me with my name. thanks
  • Benjamin Patri
    and where are you trying to get the patch from?
    Scholar:
  • 64 Answers
I think this is a port settings issue with the computers you?re trying to use....and or? you need to update the other computers with the PSW Communications patch that is located at this link http://psw-support.com/Downloads/downloads.htm Please make sure you are using the correct port on your computer when you have the Conversion Tool Cable connected. To check to see what port you are using connect the Conversion Tool Cable to you computer and Quantum XL-6000 Computerized Sewing Machine then right click on MYCOMPUTER and select Manage then select Device Manager the look under ports and see what port number you computer is wanting to use?then make sure your PSW software is using the same one??Should be a quick fix either way?..I hope this helps let me know if you need me to walk you through it? cbinny1
    Scholar:
  • 89 Answers
From the Singer Support page:
Q. Can I use a USB cable with the Conversion Software? A. A USB cable may be used with a USB-to-Serial (9-pin) conversion cable. For Window® 98, NT, 2000 & ME these conversion cables usually require that an software program (included with the cable) be installed on the PC in order for the computer to recognize the cable. Window® XP (or higher) usually does not require the cable software.
Q. How does the Conversion Software communicate with the Quantum® XL-6000? A. The Conversion Software and the PC communicate with the Quantum® XL-6000 through a special serial port cable called a Null Modem Cable, (Singer Part # 270-10D1-20206 for 6-foot cable, Part # 270-10D1-20210 for 10-foot cable). This special cable is a 9-pin cable with both a male and female end, one for the PC and one for the sewing machine. The wiring in a Null Modem cable is configured in a way to allow communication to flow both ways between the two devices, the PC and the machine. A straight serial port cable will not allow the information to flow back and forth. However, a Null Modem Adapter may be added to a straight serial port cable, creating the same effect.
So, looks like the XL-6000 is a serial device. You'll have the best luck using an actual serial cable. If you're using a USB to serial adaptor, it may or not work for no good reason. We've had overall lousy luck with the adaptors and tell people we have no idea if it'll work for your particular purpose/system. It very well may work with one setup and not at all with the other.
However, if you're using the correct null modem cable (ie, your computer has a serial port, the other 2 computers have serial ports, his laptop had serial port) then you've got another problem. I'd try uninstalling everything that has to do with the software and the machine, do a fresh install and see what happens.
  • dcomputerman Oct 29, 2008
    From another post, maybe useful:
  • 905 Answers
Have you tried to unistall the software , restart the computer , reinstall the software , restart the computer? and then try?
  • 3 more comments
  • jason Oct 29, 2008
    did you change anything? like in the firewall settings or did you check to see if your protection software changed the access setting? allow , this time only , block , check and make sure its not bieng blocked
    you can use this guide to retrace the steps and mke sure the settings are correct
    say what results you have encountered
    here is a guide that should help understand the complete setup
    http://www.psw-support.com/faq/index.htm...
    if you uninstalled it , then go to C:/ program files , and look for the program folder if it still exsists delete it , as it may still hold inacurate info, which then every time you reinstall it will use that info for reference, so make sure there is no file left for it after uninstall
    also make sure that any other files created by the program don't exsist either
  • jason Oct 30, 2008
    thats why you have to make sure the com port is set up , please follow those directions and make sure you have everything set up properly
  • 1,800 Answers
Look diana i want u to one thing follow me:
first of all remove and uninstall the software from
my computer/ control panel/remove and add programs and u will fine it listed there and remove it or uninstall it
after that restart computer and and install the software fom the cd that u got..
then connect the machine and the new material wizard will apear click on next, next ,continue anyway, then finish.
enjoy
plz do rate this post as good as u can
  • Jalal Sordo
    Jalal Sordo Oct 29, 2008
    i want to knw if pc get recongnize the machine
    Genius:
  • 1,226 Answers
Maybe the software you use is not compatible to your new computer. Is the machine detected by computer? and the computer cannot load to the system? in that case the operating system could not recognize the softwares. please try go to the machine website if they have an updates of the for your system. windowsxp xp drivers is not compatible in vista so you need a software for vista. else consult your vendor for the compatibility or in your machine documentation.
melnavz
  • Emelio Navaja
    Emelio Navaja Oct 29, 2008
    Be sure the connection port is still functioning and no fault.
    Scholar:
  • 155 Answers
Check wheather your software is compitable with the operating system you r using at your home.
is the laptop and the 1 which you r using at home have same operating system.
reply.
  • 1 more comment
  • fixexpert Oct 29, 2008
    not the compitability of the laptop but the other machines in which you tried at your home are they having the same operating system as your laptop has.for example(windows--98--or xp or vista.)
    both at home and office are u using the same operating system.
    some times if at home u r using the operating system that is not compitable/suitable with the software you r using so it did not worked.but at the laptop in the office you have the operating system which is suitable for that software so it is working in the laptop.
    thanks.
    keep updated
    this is the anti virus software which your system requires .if it is saying "PSW 1.0 IS NOT INSTALLED IN YOUR COMPUTER" you install it in your pc.and then try loading the software .
    thanks.
    Genius:
  • 1,847 Answers
What is the software that you are talking about.?
  • Legin Varghese
    Legin Varghese Oct 29, 2008
    let me know the name of the software, and how are you tiring to connect?
    Is there any driver required or the computer have recognized the machine?
    Let me know the details
    Thanks
    Kevin
I have a brother embroidery machine, and pe-design life software on my computer, I purchased a brother pes design cd from eBay which had really good reviews, but when I click on a design it says ( par
PE Design versions require certain OS'es, later versions work on newest WIndows 8. The PE Design software requires the right operating system and a CARD READER that also serves as a security device which allows the software to work.
Cheers,
Kelly
Embroidery Services
San Diego,CA
Jan 15, 2015 | Brother Sewing Machines
Does the Deco 340 Embroidery Machine use .ART or .EXP?
According to the manual for the Bernette Deco 340, the machine only reads .EXP+ files. ART files need to be converted to the EXP file type using the Bernina Embroider Software. (Even the designs on the Studio Bernina CD need the ART files converted to EXP.)
The manual is available from the Bernina support site: http://www.bernina.com/en-US/Support-5/Machines-en/bernette-deco-en . The direct link to the manual is http://www.bernina.com/getdoc/c6cc51e0-d5e9-4cb1-a7be-f164c0f4fdff/deco340_EN_GZD . (Note: you will need Adobe Reader or a similar program to access the manual.)
I'm surprised that you were able to get any .art files to work until recently.
I hope this helps.
Feb 05, 2014 | Bernina Sewing Machines
My husband upgraded my cmputer but forgot to take the dongle off. Can I get a new one?
What did he do with the old computer? Can you get the dongle back? It would be useless for anyone else - you cannot even format them to use as regular USB sticks - and they are virtually irreplaceable. The replacement cost is the same as purchasing the software, I'm afraid. Either get new software or a new husband LOL! A cheaper alternative than the Husqvarna software is Embird. It's not my first choice personally, but is 1/10th the cost of the HV program and there's NO DONGLE!
Dec 20, 2010 | Husqvarna Designer I
When I bring up my design from my disk it does not show up on the design page however when I send it to the machine it the correct design. I am not sure how get fix the deisgn page back so that I can see...
Sorry, need a bit more information. Where does the design not show up? On the machine screen? On your computer software screen? What software are you using? What is it you are trying to do when the design is not showing?
Dec 12, 2010 | Husqvarna Designer I
USB drive does not regularly read the USB flash
I have a Designer I USB that suddenly started not reading the usb stick that came with the machine. I was terrified that my machine was going bad, but I always start with the cheapest solution first. I bought a new usb stick, loaded the designs from the old one into my software then loaded everything on the new usb stick. My machine reads it every time so far. I replaced the usb stick about 3 months ago and have not had another problem since. I don't know if this is your problem, but usb sticks can go bad and since they are so cheap, I would try this first.
Jul 11, 2010 | Husqvarna Designer I
My HP pavillion, window 7 cannot find the designer
You need to reinstall them, they will be on the communication disk that came with your machine or the 4D software cd if you purchased that.
May 21, 2010 | Husqvarna Designer I
I have purchased a Janome 9700 embroidery machine and it came with a disc of designs (jef format) . I have downloaded the designs on to the memory card and can view them via the computer but they do not...
Since you are able to view them from the ATA (Compact Flash) card on your computer and the designs are in *.jef format you should be able open them on your machine. Make sure you have selected to view designs from the ATA memory card and not the ones stored on the machine or from the External Card Reader box.
There is an additional program called Customizer that you can import designs, edit, and transfer them to your ATA card. Mine was part of my package deal when I purchased by 9700.
Oct 21, 2009 | Janome Memory Craft 9000 Computerized...
Have a Rose Husqvarna sewing machine and just purchased a Designer SE. Purchased a Rose reader writer for my cards and want to put them on the computer to use with my Designer. Can not find any...
If you bought your SE from a dealer they will be able to transfer those designs for you. If not, you need the Husqvarna Viking software so you can "read" the designs from your rose cards into your computer, then you will be able to send them to your USB stick for the SE.
The software really unlocks the potential for that machine. The first module of the software is about $400, comes with about 100 fonts and many designs and abilities to alter the text you want to sew. If you go up to the $900 option, you can cut designs apart and save different aspects of the design by themselves and also get an automatic digitizing option that works well. Husqvarna's web site shows their software in detail.
Oct 08, 2009 | Husqvarna Rose
Can not find the driver to desn designes from the computer to sew
Say me your Machine name, and serial code /MB-4 or???
Say me your PC system name - Wndows SP2, or Vista, or Linux????
Dec 04, 2008 | Janome Memory Craft 10000
Downloading
The Designer 1 needs the design in an shv format in order to read it. The floppy disk for an older machine may be created using several different programs but the Husqvarna Viking module is known as Disk Manager. It is included with many of the HV software packages. With a newer USB Designer 1, the program is Disk Manager USB.
May 09, 2008 | Husqvarna Designer I
Singer Quantum XL-6000 Computerized Sewing Machine Logo
299 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
