Question about Sewing Machines
How to installing the bobbin Kenmore sewing machine, model 385.12812690 Thanks!!!!!!
SOURCE: Kenmore Sewing Machine model # c877.15
I have an old Kenmore and here are the directions from my manual: 1. Draw thread from spool through bobbin winder tension discs. 2. Wind thread around an empty bobbin several times. 3. Place bobbin onto bobbin winder shaft with thread coming from rear of bobbin. Push bobbin winder latch against bobbin until it clicks. 4. Release clutch by turning clutch knob toward you. Start machine.
Posted on Aug 09, 2007
SOURCE: reverse on kenmore sewing machine 385
I recommend that the machine be serviced by a professional but if you're handy it may simply need cleaning around the reverse cam. To do this place the machine on it's back. You'll need to access the rod that drives the feed dogs and cam mechanism by removing all screws holding the bottom plate of the machine. Remove the bottom plate. Note that when you push the reverse button, while turning the wheel a thin rod moves left which allows a plastic cam mounted to the cam rod to also move left and engages the feed dogs in reverse. If the cam is not moving enough or if too slow, it may be that the rod and cam need cleaning and lubrication. Clean out all lint and lubricate the cam where it moves on the shaft. Try to get it to move more freely without forcing it. When done replace the bottom plate. I just repaired my wifes machine and this solved the problem. Hope it helps.
Posted on Feb 17, 2008
  • 323 Answers
SOURCE: instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Sewman7
Posted on Jun 05, 2008
SOURCE: Kenmore 10 Sewing Machine
kenmore sewing machines relics
Posted on Jul 13, 2008
SOURCE: kenmore sewing machine model 385 16764
There's a website called managemyhome.com which is sponsored by Sears. It's free to join. Go to the Home Manager column and choose Owner's Manuals from the drop down menu.
You can type in the brand name (Kenmore) and model number of your machine. Not all of them are in there but, I did find the one for the 1950280 question. It's a pdf file.
For the 38516764 question, please double check your model number. I received either no response or a Kenmore Elite dishwasher manual in response to my query.
Posted on Feb 04, 2009
Why won't bobbin winder spindle turn?
Bobbin winder spindle will not spin - YouTube
? 1:24
https://www.youtube.com/watch?v=Fh52_ndkSKs
Jun 12, 2013 - Uploaded by djc472
Thread caught between spindle shaft shoulder and bearing. ... Sewing machine won't pick up bobbin thread ...
Why won't the bobbin winder work on my Kenmore sewing ...
www.shopyourway.com > Manage My Life > Questions
The bobbin winder doesn't spin and I can't wind the bobbin. ... What will release thebobbin winder that is stuck to the right on my Kenmore sewing machine model 385.17826690? Why won't my bobbin holder thread to the top on my Sears Kenmore sewing machine model 385.17928?
Sewing machine bobbin winder won't turn ' ShopYourWay
Dec 29, 2015 | Sewing Machines
What bobbins to order? I need more!
Shop for sewing machine bobbins... on Google
Plastic Bobbins for Kenmore S...
$3.99
Sears Singer Transparent P...
$8.99
Google Trusted StoreOverstock.... Brother SA156 Top Load Bob...
$5.10
Walmart Sewing Machine Bobb...
$3.89
Sears Parts D... Janome Style J Plastic Bobbin...
$6.00
Sew Vac Direct Search Results
    Bobbin Style Information for Sewing Machines - The Thread ...
    www.thethreadexchange.com/.../merchant.mvc?...sewing-machine-bobbi...
    We have bobbin style information for over 1600 sewing machine makes and models. Please start by selecting a sewing machine make from this list.
    Sewing Bobbins : SewingMachinesPlus.com
Dec 08, 2015 | Sewing Machines
How do I refill the thread bobbin on a Kenmore sewing maching,,model 148-19371
You can try a couple of YouTube videos:
Loading thread on the bobbin old Kenmore sewing machine
(do not wind the bobbin as fast as he does as it tends to stretch the thread and also could cause the spool to fly off the machine!)
How to wind Bobbin Winder Sears Kenmore Sewing Machine 158 12270 158
or order an Owner's Manual for your machine:
... Sewing Parts Online Search
Sep 04, 2015 | Kenmore Sewing Machines
Can't wind bobbin kenmore 16221 sewing machine, no manual
On the right side of the machine there is a large knob at the top. Pull that out and you can wind your bobbin. Don't forget to push it back in so you can sew :)
Dec 22, 2008 | Kenmore Drop-In Bobbin 16231 Mechanical...
Thread is bunching up around the bobbin casing
On the bobbin case is a small screw if it is to loose the thread won't feed like it should make sure that screw is tight but not so tight you can't get the thread through it. Also check to make sure you have threaded the top right. hope that helps
Oct 14, 2008 | Kenmore 15208 Mechanical Sewing Machine
Kenmore sewing machine manual for model # 148 12080. (older)
i have a older kenmore sewing machine model #148.19370
Aug 15, 2008 | Sewing Machines
i have a kenmore10 model 1249180 ehwn i sew it squeeks i oil it i dont know where the squeek is coming from
Dec 05, 2007 | Kenmore 744-08BH Mechanical Sewing Machine
I have a Kenmore as well ,I hope that this will work for you ,too bad that I don't live close to you otherwise I would give a hand. This is the way I fill the bobbin on mine. Mine is located on the top right ,I put the thread into the bobbin hole leaving a small piece of thread hanging for me to hold when I begin the winding, I pull the wheele out to stop the needle from moving while winding, when I am done just push it back in .I run the thread from the spool into the top left it looks like a U turn with a screw go around that without winding just pull it into the bobbin hole. press the foot control and it will begin winding .
Jul 17, 2007 | Kenmore 15208 Mechanical Sewing Machine
Kenmore Model 16221 sewing machine
your machine needs to be clean take it down clean and oil it up and you will have that problem no more.good luck.
Jun 03, 2007 | Kenmore 16622 Mechanical Sewing Machine
Sewing Machines Logo
272 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
