HP OfficeJet 6110 All-In-One InkJet Printer Logo
Posted on Oct 29, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Continually says align print cartridges
I continually get the message align print cartridges even though I've pushed the button mulitple times and replace both the black and color cartridges. I can print the black ink but the color only prints red and then fades out about a quarter of he page down.
  • dubj Nov 06, 2008
    The solution fixed the problem! Thank you
Anonymous
Level 1:
Problem Solver:
  • Contributor 11 Answers
  • Posted on Nov 05, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
11
Questions
0
Helped
15337
Points
16
Replace the print heads
Anonymous
Level 2:
Novelist:
Scholar:
  • Expert 111 Answers
  • Posted on Nov 04, 2008
Anonymous
Expert
Level 2:
Novelist:
Scholar:
Answers
111
Questions
0
Helped
34043
Points
139
My guess is that the color cartridge is either defective or not inserted correctly. I have a 6110 and know that inserting a print cartridge is a little tricky. If it isn't completely inserted and the top latch fastened correctly, the cartridge either won't work or produce errors.
Try reseating the color cartridge so it's inserted in exactly the same way as the black cartridge and run a print job again.
Open the following web page and go to Step three to see the instructions for cleaning the electronic contacts on the cartridge and print carriage.
Ink Cartridge Alignment Fails
Those seem the most likely causes and solutions to me. Good luck.
Error message "to print in color, install the following cartridges:" continually comes up after installing new cartridge.
on ours the cartridges click twice to be fully seated..there are 4 cartridges in this one.. if one is not all the way down, it will error..in extreme cases if all the cartridges are in place..unplug the unit and reboot it..
Hp 1315 printer alignment message comes on computer screen each time computer is turned on
you have to complete the alignment steps by scanning the page after it prints (put the printed page on glass and press scan button) . i hope that is helpful
2helpful
My printer window on the HP PSC 2175 continues to read: 'Press Enter to align cartridges' I have done this 5 or 6 times and the message will not go away. How do I fix this problem so it will print?
Perform the following steps to align the ink cartridges:
  1. Disconnect the power cord from the unit, wait five seconds, and then plug it back in. This will reinitialize the unit.
  2. Print another alignment test page. If the Press Enter to align message is not currently on the front panel display, complete the following steps to print an alignment page:
    1. Press Setup or Menu on the front panel (depending on the model).
    2. Press the right arrow button (>) until Maintenance or Tools is displayed, and then press Enter or OK (depending on the model).
    3. Press the right arrow button (>) until Align Print Cartridges is displayed, and then press Enter or OK (depending on the model).
  3. To determine if the automatic alignment is functioning correctly, look into the output tray as the alignment page is printing; a blue light should be visible periodically on the page as the cartridges move back and forth. If this light is not visible, the product will not be able to align the cartridges and will require service. Service the product.
  4. If the blue light is visible and the alignment pages are printing correctly, but the alignment pages still fails, there still may be a hardware problem with the unit.
    • If there are no other printing problems and you wish to continue, use the information in the Bypassing the ink cartridge alignment section below to bypass the alignment. The information from last successful alignment will be used.
    • If the message keeps reappearing or other print quality problems occur, service the product.
Models with a semi-automatic print cartridge alignment Some HP products have a semi-automatic alignment process. These models do not have an additional sensor and will print two pages for the alignment process instead of one. The alignment page must be placed on the scanner glass or into the automatic document feeder (HP Officejet V series) and scanned.
  1. Disconnect the power cord, wait five seconds, and then plug it in. This reinitializes the product and forces the scanner to calibrate again.
  2. Examine the scanner glass and white scan backing. Clean the scanner glass and scan backing if they are not clean. To clean the scanner glass and scan backing, use a soft cloth towel slightly dampened with clean water.
  3. With the product turned on, open the scanner cover and check the bulb assembly. If the scanner bulb is not lit, the product must be serviced.
  4. Verify that the alignment page is placed correctly on the scanner glass or in the ADF (if the product has one). Place the printed side down.
  5. 5. Make a copy of the alignment page. The unit will make a copy even if the alignment message is displayed. Compare the copy to the original. If vertical lines appear in the copy, check to see if the scanner assembly requires cleaning. If cleaning the scanner assembly does not correct the problem, service the product.
  6. 6. Use the information in the Bypassing the ink cartridge alignment section below to bypass the alignment. Operate the HP All-in-One to determine if there are other problems. The unit should be serviced if other error messages or problems occur or if alignment problems occur every time the ink cartridges are changed.
To bypass the ink cartridge alignment: Press and hold the Setup button, and then press Options (or Copy Options ).
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
2answers
Printer keeps showing : Press enter to align cartridges. After doing this it then prints out an alignment page and shows: Alignment failed please: Press enter Alignment failed. This goes on and on. I have...
I have found that if I put in an old aligned page the printer reads it as and the alignment is accepted. As for the cancelled message being in the window, I have had this problem too. I've ignored it and selected the copy button and it took the command. The only problem with hitting cancel is that you cannot turn off your printer. Every time you do you have to repeat the aligning and cancellation process.
Changed black cartridge. Machine works fine, but
To align the cartridge from the control panel:
Please follow the steps given below:
1. Please Load a plain paper.
2. Press and hold the "Scan" button for three seconds.
3. An alignment page prints.
4. Place the alignment page onto the scanner glass.
5. Press the "Scan" button.
6. Once scanning is complete, the cartridge has been aligned for optimal print quality. Alignment must be complete before continuing with any print jobs.
Keep getting message Press Enter to Align Cartridges
after each alignment you press enter key or start key not cancel key,
Printer won't print color only black and white
Reinsert the color cartridge. Give print command for page. Open Preferences in print window. Open the Color tab. Click on Print in Color. (It may have been set for black only.) Try printing.
1helpful
5answers
HP OfficeJet K60 Printer
you can bypass when asked and use last good settings by..Press and hold the Enter button, and then press Menu
This problem is caused by incorrect alignment page print out caused by faulty cartridges, ideal fix is replacement of all ink carts
HP have a webpage dedicated to this...h10025.www1.hp.com
Also get on your gloves get out your vac and suck on the carts till a little ink comes out, make sure colour cart releases all 3 colours then reinstall, can get messy.
HP 2210 xi printing problem - alignment
Try your question here http://www.techsupportforum.com/hardware-support/printer-support/49664-hp-psc-2210xi-problem.html
k24674
Grand Canyon Tech
Grand Canyon Tech
