Question about Refrigerators
Franklin ice maker hdim35
All lights are blinking how do you reset
  • sgilly Dec 28, 2008
    ice maker beeping and lights flashing no ice
Dinoza
  • 112 Answers
SOURCE: Ice Maker
Catriver, as always your solution is great!
Posted on May 30, 2007
  • 42 Answers
SOURCE: Light blinking on ice maker control switch
The red light on the right side of the freezer at the on off slide mechanism is normal and ok. I indicates the ice maker is not in a cycle at the time. It is not meant to tell the customer the unit is ok or it is not ok. Ignore the light.
If I helped enough please don't forget to rate as a FixYa if you need more information please request more help.
Thanks, supertechks
Posted on Feb 14, 2008
  • 11 Answers
SOURCE: Kenmore Elite ice maker is not working & red light is blinking
Most likely a problem with the main ice making unit itself. I bought mine at ebay for $49 including shipping. Very simple to replace. You just swap the wiring harness and bottom plate. Takes about 20 minutes to do.
Make sure you do the IR led test. If you think you IR sender and receiver are bad to, $57 on ebay for the set. Most likely not your water solenoid in the lower back of frig (it gets the signal to turn on from the receiver module of the IR board.
Probably not your water filter (cuz the front water dispenser still probably works right?)
And probably not a clogged or frozen line.
Good luck. When it doubt, trust ebay!
Posted on Mar 16, 2009
  • 523 Answers
SOURCE: ice maker wont make ice, light blinks twice in a
the eyes are bad
Posted on Jul 09, 2009
  • 39 Answers
SOURCE: red light blinking on ice maker
the red blinking light is normal . it sounds like you have a whrilpool,kitchenaid or kenmore made by whirlpool. if your ice-mkr fingers are not resting in the 2 o'clock position, then your
I/M motor/module is broken. use part#8201515
Posted on Jul 16, 2009
Bin light on no ice water running bin warm
Check the ice-full probe if bad replace this is what tells machine that the ice bin is full. the bin is not refrigerated just a storage bin.
Jan 20, 2014 | Franklin Industries Franklin Chef Ice Cube...
Fim120 flashing green light
is there any pause in the blinking light if so count the blinks and the pause and the seconds blinks this will tell you the error code
Dec 11, 2013 | Franklin Chef 120lb. Ice Maker FIM120
How do I clean my FLM70 ice maker
Google Franklin chef FIM70 Ice maker- compactAppliance.com, click on page scroll down page until you see Download product owner's manual ( PDF ) this will give you step by step instructions on how to clean your machine, The machine should be cleaned every 6 months. If cleaning dose not help with the problem than you need to look into a harvest problem.
Dec 04, 2013 | Franklin Industries Franklin Chef FIM200...
The Ice maker stop making ice after been clean.
The water is running but know Ice is being produced after 1 hour running.
Nov 04, 2009 | Franklin Industries Franklin Chef Ice Cube...
FranklinChef FIM35 Not making ice
I drained the water from the plug on mine and it started to work. The black plastic crew plug about 2 inches from the bottom of the unit, there is a rubber stopper you have to pull out.
Jun 27, 2009 | Franklin Industries Franklin Chef Ice Cube...
Ice maker will not make ice
This is a Franklin ice maker and here is a link to the manual http://www.franklinchef.com/pdf_info_phase_4/FIM35%20C%20Manual.pdf.
Nov 14, 2007 | Carrier Beverage Air DD68C Commercial...
Refrigerators Logo
354 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
