Question about Panasonic CT-36D32 36" TV
Faulty TV I have a panasonic TV. Mod: TX36PF10 (EURO 5L) chassis the problem is a blank raster, no on screen display, the sound is ok, and EHT. and tube heaters are fine, when the set is turned off you get a white flash on screen while the EHT discharges. Can you Help Thanks
  • 81 Answers
Check the ABL at the flyback. sould be at least 185+ volts on the G2 at the crt socket
Posted on Jun 11, 2007
Panasonic TC-P50VT20 blank screen with vertical lines
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apr 05, 2017 | Panasonic Televison & Video
Sound on but no pitcher
Sound on means audio section is ok. No picture is video board problem. Pl check input cables. Or give Hdmi cable input. Disconnect all inputs switch on u should get plain raster that is only dots on screen, or blue back screen, if nothing contact authorised dealer,
Feb 08, 2015 | Panasonic TH-L32C20X 32 inch Multi-System...
HP Pavillion 500series to Panasonic TV with DMI port, hooked the HDMI cable from it to the tv, blank screen, made sure the tv was on HDMI, blank screen, unhooked the monitor, blank screen, hooked the...
Most laptops have a "toggle":
* output video only to internal LCD screen,
* output video only to external HDMI port,
* output video to both internal & external.
Set the "toggle" to the best value.
Jun 15, 2011 | HP Pavilion dv9000z Notebook
Rca truflat tv goes blank after 30 minutes, then I can't get a
When this goes off is there a loud crack? If so perhaps the B+ supply is increasing increasing the the EHT to the CRT and the crack is the voltage across the spark gap in the crt base jumping to chassis/earth shutting down the TV. Or perhaps just a dusty/dirty eht cap, again EHT discharge, or could be a eht tripler being faulty. Further investigation with the aid of a service manual is required I am afraid.
Sep 12, 2009 | RCA 32F531T 32" TV
Has sound and high voltage,but no raster
that is the problem of eht if the sound is from eht then eht must be faulty replace it
Oct 28, 2008 | Computers & Internet
Rca projection tv has no picture or osd
Check the bulbs. If one is burned out, you will get this problem. The bulb is easy to change but will run you about $300.
Feb 10, 2008 | Televison & Video
Sound problem
  1. no picture &no sound raster ok.
  1. your problem is in tuner to vif section.
  2. check supply to TUNER & VIF section .
  3. check loose contact in above section.
  4. check components in VIF section.
  5. for ckt open the web site & download it fron there as given here.
  6. hope this will help.
  7. good luck.
http://www.eserviceinfo.com/index.php?what=search2
Oct 11, 2007 | Televison & Video
No raster no audio,Zenith SJ 2065S5
as horizontal transistor gets very hot so no eht so no raster &no sound due to nosupply to vif & tuner. as hor output is getting hot please isolate supply to hor. section & check power supply output is ok as due to high voltage h/outout may get hot & demaged. if supply is ok check for leaky or short parts in hor output. 1 hor. output transistor itself if it is replaced that may not be of proper matching. 2 diode& cap.in eht section. 3 clean print near eht. 4 moisture near yoke due to rain in rainy season only. so keep it hot for few hours. 5 at last if all are ok eht or fly back transformer. re connect power to hor output after rectification
Sep 18, 2007 | Televison & Video
Panasonic CT-36D32 36" TV Logo
123 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
