Question about HP Pavilion dv2000t Notebook
Wireless Problems My wireless has been acting weird lately. I have an HP dv6000. The card is not able to turn on, it does not show up in device manager, and i have already tried to reinstall the drivers. I have gone to my HP wireless assistant, and it said to try going into the BIOS to enable the device. I've tried that and have no idea what to do there. Meanwhile i have been restricted to connecting my PC with an Ethernet cable, and the wireless seems to like to turn on at random times. It also stops working every time i shut down the PC
  • AJBandoy Oct 29, 2008
    yes there is and it is turned on, but still no wireless
  •  Andrew Smith
    Andrew Smith May 11, 2010
    Talk/Contact your ISP (Internet Service Provider). If you do not have a ISP then contact a Computer Technical Service.
    Thank You for Using FixYa!
    Sorry, I don't know how to fix it, but I can give you a advice.
    Problem Solver:
  • 5 Answers
Mate, this is an ongoing issue with hp:
http://www.asifism.com/hp-quickplay-windows-vista/trouble-with-hp-laptops-wireless-broadcom-cards/
There is no solution, except for a motherboard or laptop replacement. I had to get my laptop replaced.
Posted on Dec 16, 2008
    Problem Solver:
  • 16 Answers
If there is a switch on the front of the computer, is it turned on?
Posted on Oct 29, 2008
MY HP PAVILLION'S PORTS DON'T WORK, INTERNAL WIRELESS DOESN'T WORK AT ALL
Most of the laptops those are the common issues Wireless are not working, what i suggest is try to renistall the Driver for the wireless card then check it in the Device Manager, if it doesn't show in Device Manager the wireless card could be faulty.
How to check Device manager.
Start->Control Panel->Device Manager
Inside Device Manager look for Network Adapter and check if your wireless card is detected.
Apr 04, 2011 | HP Pavilion dv6000 Motherboard
Wireless problems on but light wont turn blue tried above solution pass words wont work so now what
Dear i have send some information of your problem.
Please read this and solve your problem.
Thanks.
Solution for HP dv6000 wireless problem. Fix it yourself.
Hi...
I am from Costa Rica and my hp dv6000 had a wireless problem just like everybody.
Because I am in Costa Rica, the HP FEDEX service for repair, does not apply for me.
This is the solution that worked for me.
Difficulty: easy for skilled people, medium for inexperienced people.
It is not risky but be common-sense careful.
1- Unplug the Power cable and take off the battery.
2- Unscrew the memory cover. It is the one placed in the middle (2 screws).
3- You will see the memory, the bios backup battery and the wireless card (the one that has 2 cables plugged: one white and the other black, those are the wireless antenna).
4- Carefully unplug the backup battery. Small coin-like battery with a white plug.
5- Carefully unscrew the wireless card and remove it from the card slot.
6- Unplug the antenna cables.
7- Wait 5 minutes.
8- Plug the power cable and turn on the computer. Then wait for the screen to ask you something and choose the F1 option by pressing it.
9- Wait for windows to load and shut down the computer. Unplug the power cable.
10- Now plug back the battery and the wireless card. No need to explain how.
11- Put covers back and screw, of course.
12- Turn on your computer and verify the wireless switch is on the on position, otherwise turn it on when Windows is already loaded. The blue light should be on. If not, go to Control Panel, Device manager and check that your wireless adaptor is present and drivers are properly installed.
13- Your wireless must be alive and functioning.
14- If wireless not present, then it did not work, if it is present but have some problems, reinstall wireless card drivers and do what it should be done when updating drivers. That is a different problem.
That’s it. However if you want to know some important details, read the following.
-I tested my HP dv6000 wireless card on an Acer pc that is compatible with the wireless card.
-I try to test back the HP dv6000 pc using the Acer PC wireless card and the HP system said WIRELESS CARD NO COMPATIBLE CHANGE IT.
-The only one way to reset BIOS is by unplugging the backup (BIOS) battery as explained above.
-People generally try to fix it by recovering the original pre installed system, but it would fail must of the times.
-It is possible that the Wireless adaptor is defective; in that case none of the steps above will work.
Hope it worked for you...
Mar 02, 2010 | HP Pavilion dv9000z Notebook
My wi fi is not working. How do I get it to work?
you go con device manager -> network adapter and check ur wireless have driver?? if have but dont work you change with new wireless and don't work that problem is from your motherboard because with hp dv6000 have a problem with chipset i meet case same to you
Jan 26, 2010 | HP Pavilion dv6000z Notebook
My wireless button broke on my HP Pavillion dv6000 laptop recently, leaving me without access to my wireless internet. I don't have enough money to get it fixed just yet, so in the mean time, is there any...
click on the start and then click on connect to. When you click on the arrow it will show your dfferent types of devices. Then click on the wireless one.and then right click and tell it enable.
Dec 12, 2009 | HP Computers & Internet
Help with internol wireless adopter for hp pavilion dv6000
I guess it could be just a coincidence with the service pack update, I would suspect a hardware failure.
If you got a bad driver or no driver at all - the blue light should still work, because it has nothing to do with the driver, it is controlled by hardware and simply shows if your WiFi card receives the power.
Check the wireless card status in the Windows device manager.
If you see no WiFi card there any more - yes, it has no power and it's a harware failure!
This is known problem with HP DV6000/DV9000, decribed here
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01087277
Check your model, call them, send it for free repair - worked like charm for me.
It is also extensively discussed in the following threed on this site:
http://www.fixya.com/support/t535891-hp_dv9000_wireless_card_not_working
Though there are many ways how to fix it yourself all of them are bull... hm,
let's say not working :) The only real way is to get it done by HP - I don't know if they replace the whole motherboard or just several SMD components which are getting burned out...
Mar 30, 2009 | HP Pavilion dv9000z Notebook
Network adapter
have you made any software/hardware changes off late?do look in the device manager..right click on the my computer icon on the desktop..go to properties..on the top left under taks u will see device manager and look for network adapters..anything with and yellow exclamation means its missing/corrupt..hope it helps..
Oct 30, 2008 | HP Pavilion Notebook
HP dv6000 and NetGear WG511T
try other PCMCIA slots...actually there 2 of them in every laptop.
Aug 10, 2008 | NetGear WG511T 108 Mbps Wireless 802.11g/b...
HP Wireless Assistant
I just had the same problem with my wife's HP Pavillion dv6000 laptop.
It was working fine, then just stopped recognizing the wireless card. My daughter had been using it, so I was in doubt as to what had/hadn't been done to it software-wise (virus?). So I ran the complete recover to restore everything to the state when it was new.
Still can't recognize the wireless. The indicator light stays orange no matter which position the switch is in.
So I google "HP dv6000" looking for a manual, and the FIRST thing I find is a Recall notice http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01087277 Yeah, I know, they're covering their butts by calling it a
"Limited Warranty Service Enhancement" but they basically know that these machines were defective from the date of manufacure. They told me that my machine didn't qualify for the free service because it was 9 months past the warranty extension and tried to get me to shell out $250 for a new mother board.
Maybe I'll try the external wireless card solution, but it sounds like the MB will probably go bad next. I've owned a bunch of HP computers (have four of them working in the house right now) but I'll probably be looking at Dell next time around.
Jul 27, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion dv2000t Notebook Logo
73 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
