Question about Kenmore Elite 45986 Front Load Washer
F02 error on Kenmore front load, followed solution, problem still exist, What next?
We had a F02 error this morning. Found the "solution" on line from Guru...so drained, cleaned and ran diagnostics.....didn't drain after canceling diagnostic when tumbling started....tried procedure again and let the diagnostics run to the very end. Got the F02 error again. What next? are there other things we can check?
  • ccp94521 Oct 29, 2008
    what is the "button trap" ? We removed the filter cover and cleaned everything. Did find one toothpick. The impeller does spin.
  • Anonymous Mar 27, 2014
    run diagnostics
The button trap is the "filter asssy" are you moving water tought the drain cycle at all, ive seeen that the pump assy has been damaged in such a way that the impeller has disloged form pump and no loneger pumps water effectivly, usually soundslike its working though perhaps a little louder.i would also check perhaps theres a blockage in the hose that connects the tub to the pump assy. there shoudl be a soft ball sized plastic ball within the hose( just pointing that out so you dont remove it)
Posted on Oct 29, 2008
    President:
  • Kenmore Master
  • 2,651 Answers
Cant see what you tried to repair problem (dont see original post) but F02 is a long drain time. or innaddaquate drain. usually from a clogged, drain pump/button trap. ill assume you were told to remove the lower access panel, gain acess to the drain pump assy, clean the "button trap" of foreign derbis. if thats been done and your still having draining issues iehter theres something i nthe drain hose, or perhaps the drain pump impeller has been damaged preventing proper flow of water.
Front load washer, F02 error is flashing on board. What does error code mean?
F02 error means if the drain time has exceeded more than 8 minutes. After four minutes suds will be displayed on the screen and again after 4 minutes the F02 error code appears.
Check the drain line for any clogs or blocks which hinder the draining procedure..Use of more detergent can even cause this condition..Be sure you are using only 2 tablespoons of HE soap and not more than that.
Check your drain filter also and replace them if needed. Remove the 3 Torx head screws (located left, center, and right) from the front bottom kick panel of the washer. The drain/filter/pump is right in front.
Mar 11, 2011 | Kenmore Washing Machines
I have the Kenmore Elite HE3t. It was flashing F02, I have found solutions to get washer to stop beeping and flashing code. husband checked pump and put back together. Tried to wash a load of clothes and...
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 14, 2010 | Kenmore Elite 45986 Front Load Washer
F02 error code
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!$!$
Jul 24, 2010 | Kenmore 42822 Front Load Washer
Drain issue on front load Kenmore He3t
Jul 07, 2010 | Kenmore Elite 45986 Front Load Washer
Showing f02 error code
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^^^^
May 19, 2010 | Kenmore Elite 45986 Front Load Washer
Persistent F02 / SUD error. Tried all the tricks!
how about the line from pump to bottom of tank?not excess suds?might be bad control bd..f code is generated when control bd senses incorrect current draw by drain motor ..could be glitch in readings or a misread
Nov 02, 2008 | Kenmore 4292x Front Load Washer
Have "sud" code and"f 02" code
I don't have a solution but I feel your pain.
I had an F02 error flashing so I got brave and took off the front panel and opened up the drain thing. What a mess! Water everywhere and OMG,the filter was caked with goop, a popsicle stick and a piece of metal.
I still get a Sud error so I am having the Sears guy out in the morning.
Oct 25, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
F02 Error on Front Load Kenmore HE3
F 02 Is your key pad user interface that has failed. I would call back and get some free service from a different technician.
Oct 23, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Front Loading Washer
Please click on the following link for an explanation of the "F02" error.
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
Generally this problem is attributed to either a clogged, or failed drain pump. If you have questions, or require assistance locating any failed parts, please let me know. I hope this helps you.
Jul 06, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Front Load Washer...F02 and SUD not draining!!!!
Probably something caught in pump. Remove lower panel if this one has it and you will see the pump. Loosen the round cover in middle to access clean-out.
Nov 08, 2007 | Kenmore 46462 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
366 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
