Question about Onkyo Audio Players & Recorders
Greetings FixYa, First off, I own an ONKYO TX-DS939 Receiver. The first thing I noticed that was happening was it would get hot, VERY hot and the fan wasn't coming on for some reason unless I had the volume turned up FULL BLAST. As a result from it getting so hot if I would turned it off then BACK ON (right away) there would be no sound coming from the speakers, just a LOUD POPPING and CRACKLING sound. (like my speakers were blown or I was getting some feedback) Eventually there was NO sound at all. When I turn it on now, it powers up fine but if I turn the volume up even the SLIGHTEST bit the speakers just POP and crackle. Also, I DID check to make sure the speakers weren't blown by hooking them up to my brother in laws receiver. Anyway, the speakers are in mint shape and I am at a loss of what to do. I paid 2300.00 for this receiver and the thought of not being able to use it makes me want to throw up. Any help with this would be greatly appreciated. Thank you. Mike
  • Onkyo Master
  • 5,342 Answers
I suspect that due to that heat your main power amp section has failed. Whatever drives your speakers has given up completely.
Posted on Mar 08, 2017
2 Suggested Answers
  • 4234 Answers
SOURCE: ONKYO TX-DS939 (sound and heat/fan issues)
This sounds like the amp is seeing too small an impedence load. In other words, the amp is expecting to see an 8ohm load and is being presented a 4 or 2 ohm load. This will force the amp to work really hard and generate excessive heat. Does the amp generate sound at all? ever? If not, then you probable have a situation with high frequency oscuillations that you can not hear. This means that the amp is sending out a lot of power to the speakers that the crossovers are shunting to ground. Without seeing the output of the amp with a scope, I can not confirm this. This is not a problem that will be solved remotely. Bring the unit to a shop and request that the output be examined using a scope to check the waveforms. I suspect that a bad feedback look internally is causing the generation of the high frequency signals.
Keep us posted.
Dan
Posted on Oct 29, 2008
Connecting Airport Express to my Onkyo Receiver
Plug it into the cd input, with the two rca cables. We've had this set up for years. No longer use a cd player at all.
Mar 24, 2009 | Onkyo TX-SR803 Receiver
Problem with onkyo tx 919 unit
Hi...
If you've had it "fixed" 3 times and the problem comes back either you have the wrong impedance (ohms) speakers connected or the power supply in the unit is the actual problem.
Happy new years,
Scott
Jan 01, 2009 | Onkyo TX-DS939 Receiver
Keep us posted.
Dan
Oct 29, 2008 | Onkyo TX-DS939 Receiver
Onkyo TX-DS939
I have to ask the obvoius, did you get the manual, have you used the onscreen menu to set up the speakers, you can calibrate the speaker levels on the TV screen if you use the S video or RCA vidoe connection .have you turned off tape monitor?
Apr 27, 2008 | Onkyo TX-DS939 Receiver
Onkyo TX-DS939 optical selection problem help!
That coaxial, opt-1 and opt-2 are available only if they are not selected to some other channel. So you have to check if opt-2 is selected to Video-1,2,3,4,5,6,7,CD or DAT. Change that to Analog and then opt-2 is free to another device.
Mar 24, 2008 | Onkyo TX-DS939 Receiver
Onkyo TX-DS939 Receiver Problem
+22v line is missing. Check for 22v at R9207, not present check R9201,2 0.22ohm, R9203-6 1 ohm. Check also Q9201 12v reg ic, it supplies the led in the volume ctl. While your in there, solder up any cracked solder joints, bad connections.
Nov 04, 2007 | Onkyo TX-DS939 Receiver
Need to buy the jumper plug
What do you mean by a jumper plug. Are you referring to the preamp jumper plugs?
Sep 01, 2007 | Onkyo TX-DS939 Receiver
44 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
