Question about Whirlpool GGQ8831L Gas Dryer
ELCTRIC DRYER NO HEAT JUST COLD AIR
My Whirlpool Ultimate Care II electric dryer purchased 2002 is not producing hot air only cold air is blowing. Element recently replaced 1 year ago is there a fuse I should check and if so where might it be located.
    New Friend:
  • 88 Answers
There is a thermal fuse its location depends on the dryer if the filter is on the top then you have to take off the back panel and check the white fuse. If the filter is inside the dryer you have to take off the bottom panel. a flathead screw driver for the 2 clips the check the white fuse behind the lint trap (where the filter goes).
Posted on Jan 08, 2009
Will not get hot. just blows cold air. was wondering how many heating eliments are in the dryer?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 30, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My Whirlpool Super Duty Imperial drier won't produce heat. I made sure the outside vent was unclogged; it is blowing cold air.
When a dryer doesn't heat, either the heating element is bad, or the flap inside the venting of the dryer is opened allowing air to bypass the dryer instead of blowing the air into the dryer.
Jun 24, 2010 | Dryers
No longer blows hot air, only cold air
when a dryer does'ny blow hot air,it's normally either the element or the stats on the element.
Nov 01, 2009 | Dryers
Dryer blowing cold air only
Check your heat sensors, one or more must be OPEN.
Mar 26, 2009 | Kenmore 84052 Dryer
Whirlpool ultimate care II dryer will not dry clothes
does dryer heats up if yes take hose out from back of your dryer run dryer if you have good power air coming out from your dryer i think your dryer is fine you need to clean your air vent. system.
Feb 28, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Dryer blows cold air when starting no heat
Did the fuse blow out? If so then the heating element is shorted out. This happens frequently when they fail. If the fuse is blown check the condition of or change out the heating element.
Dec 29, 2008 | Weather King 12AJA4801AH Air Conditioner
Whirlpool dryer will not stay on, no heat, and timer acts weird
sounds like the motor or the even heat board is out i would say the even heat board is more likely
Dec 09, 2008 | Kenmore 62602 Electric Dryer
Ultimate care II Whirlpool dryer
yes its located on the houseing where the heating element is and is a small round disc with two wires get a putty knife and push in between the top panel and body of the drier about 2-3inches of the edge lifting the top as you do remove the front panel by removing the two 5/16 in screws and pull the panel the locate the heating coil and check the thermal limiter
May 24, 2008 | Dryers
Whirlpool Gold Ultimate Care II: No heat
didc, on a gas dryer, if the thermal fuse blows it will still rotate, but will not heat. Since this is a gas dryer, see if the ignitor is glowing. If it is, then you know the thermal fuse is good. If not, the thermal fuse may be blown or the ignitor itself and thus the reason for no heat. Catriver.7152136.jpg
Jan 01, 2008 | Whirlpool GGQ8831L Gas Dryer
Whirlpool GGQ8831L Gas Dryer Logo
209 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
