Question about Audiovox FPE-1505 15 in. HD-Ready LCD Television
Cannot load dvd
When I try to load a ANY dvd it does not load the disc therefore cannot watch any dvd.
  • 52 Answers
Try to observe if the disc inside is spinning, if it doesn't there's a problem in your dvd player, and you should let it check for a technician.
Posted on Oct 29, 2008
How do I repair so I don't get "no disc" message?
Could be dirty or faulty laser, faulty decoder board or motor not spinning the disc.
Sep 06, 2014 | Pioneer Elite DV-46AV DVD Player
I purchased a toshiba portable dvd player and the disc is not spinning therefore reads no valid disc. I have put in a few discs still same reading? Any suggestions?
Hello
The Sled Motor is defective. this is the motor, whic spins the disc as it has been loaded properly. If the loader mechanism loads the disc properly into place and if the catch up magnet catches the disc in place, and still the dis do not spins, replace the sled motor. OK.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
Problem with 'loading'
that is the laser lens , it is dirty,
you will have to cleaned use a q tips with wood alcool
dont aply to much pressure on it while wiping it
its should works if it not
that is the laser it self replaced the laser assembly
hope that will help
regards Alan
May 16, 2010 | Spectroniq PD-1100 DVD Player
I HAVE A SAMSUNG DVD HR753 WHICH HAS 160 HARD DRIVE
Make sure you are using the right disk IE, DVD-R or DVD+R. Most Newer DVD player's will play DVD-R but very few play DVD+R
Jun 23, 2009 | Toshiba SD-6200 Multi-disc DVD Player
Every disc i insert into mschine takes ages to load and then says disc error, even movies I have previously watched on this machine
That happens when the lens are dirty or defective.
You can try using a cleaner DVD to clean the lens, that may not work.
Being the unit only 6 months old this is probably a fault concerning the lens, rather than dirt and dust on the lens.
I think the best thing to do is contacting Pioneer at the number listed on the owner manual, since there is one year factory warranty cover on all Pioneer products.
Apr 19, 2009 | Televison & Video
Phillips pet 706/05 dvd player wont dvd-r-rw
  • Disc not loaded. Load a disc into the player, close the door and press PLAY.
  • The disc used may be defective. The disc used may be defective, try another disc.
  • The disc is placed improperly in the tray. Make sure the disc is properly placed and centered in the tray and if the disc has a label on one side, make sure the label is facing up.
  • The disc is dirty. Use a soft cloth to clean the disc by wiping in a straight line from the center of the disc to the outside edge.
  • Use of DualDisc or Flip Disc which does not meet the Compact Disc Digital Audio Standard. Some music labels have recently introduced the DualDisc for pre-recorded audio and video content. The DualDisc bonds DVD content on one side 'back-to-back' with digital audio content on the other side. However, the digital audio side does not meet the technical specifications specified in the Compact Disc Digital Audio Standard. For this Reason, DualDisc is not permitted to carry the CD logo. Philips DVD and CD players and disc drives fully comply with the CD specifications and therefore may not recognize the DualDisc. Attempting to use DualDisc may lead to playback problems or jamming in the slot loader or drive.
    The DVD video content on the DVD side of the DualDisc should play on Philips DVD players and DVD drives. However, Philips DVD players and drives do not support DVD Audio, and will not play any DVD Audio content present on the DVD side of a DualDisc. Philips will further investigate DualDisc and update this notice accordingly.
Jul 18, 2008 | Philips Televison & Video
DVD load problem
run a lens cleaner thru it to clean the lens. use the NON liquid type ... its a disc with little brushes on it you can get from radio shack for a few bucks.
May 26, 2008 | Emerson EWD2203 DVD Player/VCR
Audiovox fpe1506dv
The problem that I'm having is that when I put a dvd into the player it tries to load the disc but never does. Therefore I cannot watch any dvd.
Dec 31, 2007 | Audiovox FPE-1505 15 in. HD-Ready LCD...
Dvd video player
Your DVD player is having a problem reading the disc. This is what is accounting for the pausing and the slow loading times...especially if it plays other movies without hitches. Even if the DVD is cleaned, some scratching on the disc will prevent it from being viewed properly. Blockbuster shoudl give you another disc to try of the same movie if you ask. Also, you can try getting a cleaner for your DVD player to remove dust and help it read discs better.
Dec 26, 2007 | Toshiba SD-3980 DVD Player
Audiovox FPE-1505 15 in. HD-Ready LCD Television Logo
205 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
