MSI 915P Neo2 Platinum Motherboard
Problem for MSI 915P Neo2 Platinum Motherboard
Beep sounds and their meaning
By AndersO on Sep 04, 2006
Hello, I got this MSI 915P Neo2 motherboard and getting beepsounds at startup. Not the usual one "beep" but either "beep bop beep" or "beep beep". Silly to explain in writing but anyway, it sounds like that :)
I've been to the MSI site looking for info on what it could mean but unsuccesfull.
The computer runs fine except some bluescreen now and then usually when alt tabbing "out" to windows from some game. My guess is that it is the memory that is faulty somehow. Or what do you think?
Same Problem
Jul 31, 2008
-   upgrading ram from 512 of pc 2100 to 2 512s of 3200 wen i try to turn on just get bleeps got to 54 bleeps then i got bored of counting and turned it off wen i put old ram back in it worked ok have tried other ram and same problem -   Guest
Jun 27, 2008
-   sir my mother board same problem pls halp me-   Guest
Nov 26, 2007
-   it's already black-out then i heard a long beep sounds on my board-   Guest
Best Solution
posted on Sep 04, 2006
Helpful)
Samsung
Rank: Apprentice
Rating: 83%, 21 votes
Hi
All PC do what is called a POST a Power On Self Test and emit different beeps according to the make and model of the BIOS loaded. You can check out what they mean for different BIOSes here http://www.xmission.com/~comphope/beep.h...
This site lists the different post codes etc by the different bioses. So you will need to know what BIOS your PC is running just check the black screen at starup before any windows info comes up and look for something like AMIBIOS or AWARD etc, you can pause the screen so that you can read it more easily by pressing the pause button on your keyboard, this is normally the last key on the top row on the right.
Hope that helps
Was this helpful?
Yes
No
Solution #2
posted on Nov 13, 2007
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
This is normal behavior for that motherboard. The reason is something like: It beeps for each USB device plugged in. I believe the manual describes this.
Solution #3
posted on Aug 12, 2007
Not Helpful)
CanDo
Rank: Wiz
Rating: 81%, 175 votes
Check the wires around the switch plugs to make sure you wired them correctly. This often causes this problem.Double check every plug you have had to plug up to make sure it is correct including the USB plugs.
Was this helpful?
Yes
No
Popular Solutions for MSI 915P Neo2 Platinum
Questions and Unsolved Problems for MSI 915P Neo2 Platinum
Do you recommend MSI 915P Neo2 Platinum Motherboard?
Answer
Answer
gigabyte ep45ud3p will not boot just installed
Answer
Motherboard is P5PE-VM, OS is Windows7: no Sound, but Message: Audiodriver is not installed What's... (More)
Answer
when mother board is proper connected,then restart the board.also i check my ram,amd... (More)
Answer
Replaced the photodeveloper cartridget last week and now I'm getting a grinding sound as it prepares... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Motherboards Experts
Top Computer & Laptop Repairmen
in , CA
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
