Canon PowerShot SD300 / IXUS 40 Digital Camera
Problem for Canon PowerShot SD300 / IXUS 40 Digital Camera
Problem with my camera
By helencb on Sep 04, 2006
When I turn my camera on, all that happens is that the lens comes out, the camera makes a buzzing sound followed by 6 rapid bleeps, the bird picture appears on the screen then the screen goes black, and all that is displayed on the screen in the bottom left hand corner is the number E18. The camera then switches off but the lenses does not recoil.
Hope you can help.
Helen
Solution #1
posted on Dec 22, 2006
Somewhat Helpful)
toothy
Rank: Guide
Rating: 88%, 90 votes
Your lens is jammed, and needs to be repaired or replaced.
Was this helpful?
Yes
No
Solution #2
posted on Mar 07, 2007
Somewhat Helpful)
raster44
Rank: Master
Rating: 73%, 30 votes
Go here and search knowledge base for E18: http://www.usa.canon.com/consumer/contro...
Issue: Lens will not move and camera may display an E18 or "Lens" error.
Solution: Possible solutions for an E18 or Lens Error message PowerShot SD300
The "E18" or "Lens" error message indicates an error that involves the lens unit or lens cover.
This error may appear where the lens is prevented from properly extending or retracting such as, for example, when pressure is applied to the lens or the area surrounding the lens while handling the camera. The error may also be displayed if the lens unit/camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera.
Solution
Check the following when you operate the camera to avoid applying pressure to the lens and surrounding area:
* Hold the camera so that your fingers do not touch the lens unit when you are shooting.
* Make sure the camera is off before the camera is placed back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.
If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred.
Was this helpful?
Yes
No
Solution #3
posted on Sep 26, 2008
Not Rated)
darntoothysa
Rank: Wiz  Canon Expert
Rating: 85%, 131 votes
Hi
What you are seeing is a generic stuck lens error message.
Your lens needs to be cleaned, repaired or replaced. There are online places that will do it for a decent price and there are others that overcharge by way too much.
I know, because I own one that charges a reasonable price to do the repair! (Google 'darntoothysam')
Just let us know if we can help! Good luck from
Darntoothysam com
Thomas
Was this helpful?
Yes
No
Solution #4
posted on Dec 23, 2007
Not Rated)
t00nz
Rank: Guru  Canon Cameras & Camcorders  Expert
Rating: 91%, 2074 votes
Know this is an old post, but it might be of help to others with this problem. The following blog outlines some simple repair options for a lens error:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Was this helpful?
Yes
No
Solution #5
posted on Dec 17, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
not really helpful at all. i dont abuse my camera and this happened to it.
Popular Solutions for Canon PowerShot SD300 / IXUS
Questions and Unsolved Problems for Canon PowerShot SD300 / IXUS
Do you recommend Canon PowerShot SD300 / IXUS 40 Digital Camera?
Answer
Answer
canon powershot SD300 ditigal ELPH when the camera is turned on, it powers on then beeps and shows... (More)
Answer
Canon sd300 no zoom out would just zoom in. Once re-started again would only zoom in but not out.
Answer
camera was dropped the lens does not retract and will not work
Answer
HI! i can turn my ixus40 on, and look at the foto i ve made but if i turn to foto/video mode, the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Digital Camera Experts
Top Camera & Camcorder Repairmen
in New York, NY
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
