Question about Sony Computers & Internet
Laptop turning off
I have a sony vaio model-r505el. after 10-15 minutes of use, it turns off by itself. even if i plug it from the wall outlet, it still turns of on me.
  • 33 Answers
This may be caused by processoroverheating.
It's possible the heat sink is clogged with dust and has to be cleaned.You can clean the heat sink with compressed air, blow off the heat sinkthrough the grill on the bottom of your laptops. Some people usevacuums for removing dust from the heat sink. Or you can open the laptop case to clean the heatsink:
Alternately, click delete, F1, or F10 when your computer starts to gointo your BIOS and look for PC Health > Temperature (or similar).This should show you the current temperature of the computer andthe emergency shutdown temperature. The emergency shutdown temperatureis a safeguard that shuts your computer down to prevent damage when it gets to hot. If this setting shows that your processor is too hot, you should consider replacing the fan. Or you can either raise the shutdown temperature or switch it off completely, however be warned that you may damage your computer if the computer gets too hot.
Posted on Oct 29, 2008
  • 89 Answers
Often, if a system turns off every time at roughly the same time, it's a hardware problem. System gets too hot, shuts down, restart it and it'll run again for a while, but not quite as long, and continue like that. Can you feel/hear the fan moving air? Possibly clogged, see what you can do to get it cleaned up a bit. Does it make any difference what surface it's on? May be covering a vent on the bottom or back.
I hadn't charged my Sony Vaio model PCG-61611L for a couple days. Then when I finally plugged it in to charge, it won't turn on. I even left it plugged in for a few days and still nothing. It has...
Try A Hard Reset
Remove the battery and charger/ac adapter/power cord from your Sony Vaio laptop, press and hold the power button for 20 seconds to discharge any residual current inside the laptop.
This clears your RAM and is like a hardware reset.
Replace the battery and charger/ac adapter/power cord
and turn your laptop on.
If that does't work try removing ram and reinstall. Sometime this works with these laptops.
Sep 11, 2017 | Sony VAIO VGN-AW330J/H Notebook
Plugged it in to a wall outlet, turned on the computer, the microsoft screen scene appeared, the jingle played, then it turned itself off and won't turn back on.
Unassemble the battery and after 5 minutes reassemble it, then plug it in another wall outlet and when the charging light turn on, turn on the notebook.
Jul 21, 2011 | Dell Lattitude D610
Hi, I have a Sony VGC-JS160J Desktop yesterday my kids were play and it turn off and don't turn on again
Disconnect the power from wall outlet for about five minutes also disconnect video cable from the PC.
Connect the cable to PC and power to known working wall outlet and see if it turns on.
Try a known working monitor and see if that works.
I hope this helps.
Good Luck and have a pleasent day.
May 21, 2011 | Sony VAIO VGC-JS160J/S 20.1-Inch...
How can i reboot my sony laptop tpye pcg-r505el
open command prompt and type shutdown then hit space button then -r then hit enter button your laptop will reboot
Feb 19, 2011 | Sony VAIO R505EL Notebook
My Sony Grand WEGA LCD rear projection 51" turns itself OFF every 20 sek and turns itself back ON after every 35 sek. ???
Try resetting the TV to the factory settings. Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 26, 2010 | Sony Televison & Video
Sony Vaio touch pad, mouse scroll and USB ports not working
Here is the required drivers for the Computer.
Touch pad, Mouse scroll=> Download
USB Ports=> Download
Hope this will help.
Sep 29, 2009 | Sony VAIO R505EL Notebook
Sony vaio pcg-r505el won't turn on
Vista or xp? I'm assuming Vista?
Apr 06, 2009 | Sony VAIO R505EL Notebook
Sony vaio pcgr505el disc read error
The Hard drive is giving the error.Try reseating the HDD.Remove it and put it back.See whether if it works.If it doesnt then have to get a hdd replacement
Mar 17, 2009 | Sony VAIO R505EL Notebook
What is the Sony Vaio VGN-N250N battery life expectancy.
nope..that's just what happens with batteries that are older, tired, and dried out..
Mar 11, 2008 | Sony VAIO VGN-N250N/B Notebook
Computers & Internet Logo
319 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
