Question about Samsung SyncMaster 920N 19" LCD Monitor
Any suggestions ?
My Samsung SyncMaster 2232bw will not turn on , the pilot light is on ( blue light around the power button) so i know the monitor is getting power .. but all i get when i power up the PC with this monitor hook up is a black screen. Any Thoughts ?
    New Friend:
Replace all of the bulging capacitors
Posted on Jan 26, 2013
  • 55 Answers
firstly you check this monitor to another pc. it the same problem accure then
i thinks this problem due to falure of power supply or dead of flurocent tube. or any the vga cable is faulty.
ok
bye
Posted on Nov 13, 2008
Have a Samsung SyncMaster 2232bw monitor that the power button flash is there a reset button on this monitor
I have another model of Samsung Syncmater monitors.
According to the manual, press the Source button then a key on the keyboard.
http://downloadcenter.samsung.com/content/UM/200707/20070721174815531_BN59-00585T-01Eng.pdf
According to http://www.tomshardware.com/forum/267699-33-samsung-syncmaster-906bw-display try pressing Source and Power or Power and Auto button at the same time.
Per Tomshardware.com, if these things don't work then the monitor needs an electronic repair(detailed in forum) or, if you are unable to get it fixed, replacement.
Please check http://www.fixya.com/support/t255653-syncmaster_paower_button_blinking_no for additional information.
Mar 24, 2016 | Samsung Computers & Internet
I have samsung syncmaster 940mw monitor. The monitor for the most part will not turn on. When the power button is pushed or attempt to turn on with the remote the little green pilot light will blink or...
That is a hell know problem with the 940MW tv/monitors. The power supply has failed because of parts called capacitors have shorted. If you can solder then you should be able to repair your monitor. Here is a link to the repair guide for this issue.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-940mw-lcd-tv/
I hope this helps, if so please rate my solution.
Oct 30, 2011 | Samsung SyncMaster 940MW 19" LCD Monitor
I have a SyncMaster 2232BW monitor hooked to my pc, the blue power button comes on when power on, my computer POST appears for about a second then vanishes leaving only bright lights on display, none of...
Seems that you may have the wrong type of video selection theres a button for auto sensing the type of connection. if your video cable is blue then you have an analog connection, white video cable is a digital connection you just need to ensure that the monitor is set to the proper selection.
Sep 05, 2011 | Samsung SyncMaster 2233BW 22" LCD Monitor
Monitor no longer works - all black
there is no reset button on lcd monitors, check power cable first, if the blue pilot led lights but no picture, you might need to bring the unit to the shop for servicing..
May 09, 2010 | Samsung SyncMaster 245BW Monitor
My samsung syncmaster 2232bw wont turn on at all, and the pilot light(blue light surrounding power button) is flashing repeatedly at a fast pace, much much faster than the norm?????????
Solution for Samsung SyncMaster 2232BWplus:
The problem is bad capacitors: 5 pcs. 820microFarad – 25v and 1 pc. 330microFarad -25v. Replace these capacitors. Then re-solder the two transformers of inverter side. Also re-solder the power transformer and the inductor coil.
To open the casing:
At the bottom of the stand just twist the knob to unlock. Then, use a small flat screw driver beginning from the bottom (left or right) then using a hard credit card (or alike) then slide/glide it in between the cover plastics.
Roan
Triangle Tech Whiz
Dec 01, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Monitor not wrking
Sounds like you may have had a power surge.??
Disconnect power and signal input.
Turn the unit off for 20 minutes or so. Check the outlet against another device. ( Light )
Turn unit on without connection to PC video.
If you get a no signal, you good to go . Reconnect. If you continue to get a flashing light on power button,
Check warranty, get it back to Samsung for repair.
Hope this has helped
Sep 02, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Blank screen, flashing led power light
this sounds exactly like what happened to my 2232BW. I took screenshots of the fix and posted them on my webpage:
http://www.alexdemo.site90.com/#samsung2232bw_fix
Jun 03, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Samsung Syncmaster 205BW power button lights up image will appear
Hold down the power button and the auto button. if that doesn't work try the power button and the source button.
Jun 24, 2017 | Samsung SyncMaster 213T 21.3" LCD Monitor
Samsung monitor and mac os
Please do not adjust RGB unless you know what you are doing.
For critical color work, you will need to use a photospectrometer and calibration software to analyze what your monitor is spitting out.
There are a million obvious reasons you should not trust your eye making arbitrary RGB adjustments off the hip.
Feb 15, 2008 | ViewSonic VX2255 Monitor
Samsung SyncMaster 920N 19" LCD Monitor Logo
721 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
