Question about Archos 605 WiFi Digital Media Player
Poewer on problem
I have the archos 605 it was fine now when i put it in the docking station the harge light goes on but wont turn on, when out of the statio the power is not there, i have not up dated it and have not sync to my pc????
  • 1 more comment
  • Anonymous Oct 29, 2008
    yes i have the same problem
  • luis-yvr Oct 30, 2008
    I called Archos and they say that I have to ship it to Colorado. The warranty expired just last week. I am so mad
  • rickpoacher Nov 08, 2008
    Any one else with a fix they have done???
No i just bought frome ebay and im reterning the item
im lucky
and good luck to you guys
Posted on Oct 30, 2008
Can I pre record on the archos 605 wi fi 30gb
You have posed a very good question with a very complicated answer. There are two things you MUST have in order to do what you are asking:
1) Your "docking station" cannot be the Archos mini-dock, b/c the mini dock has inputs only. Your docking station must be the Archos DVR Station - Gen 5.
2) You have to have a digital cable box, FIOS, or digital satellite box.
You will be recording from your cable, satellite, or FIOS box instead of directly from your TV. Hook the red, white, and yellow cable from one of the red, white and yellow outputs of your cable/sat/FIOS box to the specialized adapter of the DVR Station (make sure your Archos 605 is properly docked inside). Here is a link to the connection guide if you don't have it:
http://www.archos.com/support/download/manuals/connection_guide_dvr_station_v1.1.pdf
Once the connection is set up, you must follow the exact directions printed on pp.11-15 of the DVR Station user manual - it will require downloading several pieces of software. My only reccomendation is that you make sure that the Archos 605 is fully charged before proceeding, b/c if it loses power during the process, you may ruin your mp3 player. Here is a link to the DVR Station user manual:
http://www.archos.com/support/download/manuals/english_user_manual_dvr_station_gen5_v3.pdf
If you have followed the instructions exactly, you will be able to schedule your recordings to your Archos 605.
There are two catches that I noticed with this player - 1 major and one not-so major:
1) Not-so major: Your subscription to the TV guide that enables you to schedule recordings will only be free for 1 year
2) Major: The DVR Station forces you to choose between an NTSC and a PAL format when choosing a TV standard for playback. PAL is only for Europe, so never select it under any circumstances. NTSC is shutting down on February 17, 2009 - in a little more than a month. After that time, you may not be able to display the recordings that you have made to your TV itself.
-Tha Mp3 Doctor
Jan 07, 2009 | Archos 605 WiFi Digital Media Player
CAN I PRE RECORD PROGRAMMES ON THE 605 WI FI 30GB
Archos 605 Wifi w/ Archos DVR Station Gen 5
-Tha Mp3 Doctor
Archos 605 Dock station won't work with TV anymore
hi have you change the setting to component or rgb on the display settings
Dec 16, 2008 | Archos 605 WiFi Digital Media Player
CHARGING LIGHT DOESN'T COME ON WHEN THE DEVICE IS ON THE DOCKING STATION
The adapter that comes with the Archos 605 must be firmly fixed to the docking station by pressing very firmly with a loud click. It feels delicate so if you only click it lightly it wont connect properly. This is poor design but at least it is OK now.
Aug 27, 2008 | Archos 605 WiFi Digital Media Player
Archos 605 wifi 160gb
How are you charging it??
are you using the dvr docking station??
is the charge light flashing or steady??
Jun 30, 2008 | Archos 605 WiFi Digital Media Player
Archos 605 wifi freezes
Mine kept freezing alot, and now the on/off button wont work. I can only turn it on with the docking station.
Jun 14, 2008 | Archos 605 WiFi Digital Media Player
I CANT TURN ON MY ARCHOS 605 WIFI 20G WITHOUT THE DOCKING STATION.
Try reseting device by inserting a pin in the bottom reset hole
Jun 05, 2008 | Archos 605 WiFi Digital Media Player
Archos 605 wifi
I get it why people have to go around asking experts directly(your not the only one).
Can you tell me the connectors behind your television
Jun 01, 2008 | Archos 605 WiFi Digital Media Player
I have an Archos 605 WiFi. I haven't yet connected my Archos docking station to the TV and HDD. Meanwhile, I thought I would copy a programme from the HDD to a DVD, then put the DVD in the computer and...
What kind of HDD do you have, do you have any type of output on it. You stated that you haven't connected the docking station to it and the TV...? The best thing to do is to connect your Archos to the Docking station. Set the docking station up correctly, with cables coming out of the HDD (if it has some sort of output) to the station and out of the station to your TV. Once you set that up, you can use the Archos as a mini DVR or VCR. Go to the REC option on the main screen of Archos, you'll have an option for Video Recorder (tab on top). If you play any source on the HDD, then all you have to do is press the Rec option on the Archos. If you already have a file on the HDD, then try just moving it over into the Archos once you connect the Docking station to your computer via USB or just use the USB cable connected to the computer with the HDD. I use the USB preference as Windows Media Device. (found under menu/settings/system). Is is basically a HDD itself. Remember the Archos will only play certain videos without the purchase of any extra plugins.
Good Luck
Apr 14, 2008 | Archos 605 WiFi Digital Media Player
I own an Archos 504, i purhcased today a DVR Station GEN 5, the box states compatibility with the 405 and 605, is it compatibble with the 504 too? could you confirm this please before i open the box many...
yes it is compatible but the remote wont work for Archos 504. also, u'll require saddle for 504(usually comes as part of package). dont try to put your archos on the dock without a saddle.
Mar 18, 2008 | Archos 504 500870 Digital Media Player
Archos 605 WiFi Digital Media Player Logo
57 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
Jim Goldsmith
Jim Goldsmith
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
