Question about HP Designjet 110plus nr InkJet Printer
A belt fell off on the inside of my printer and i dont know where it goes
  • bluegoose32 Dec 11, 2008
    A belt fell off my DesignJet 110nr plus. The belt is about 3" in diameter and 1/8" wide. Facing the front of the printer, the belt is located on the extreme left end of the carriage. The belt is around what appears to be the shaft that moves the paper. There is a plastic gear attached to the shaft that is probably one half of the belt path, but I cannot see another gear that would complete the belt path. The printer still prints on roll feed paper; I have not tried sheet feed paper. If anyone has a drawing or description that would tell me where this belt belongs, I would appreciate a posting that includes the info.
    Dewitt
  • bluegoose32 Dec 15, 2008
    The Output Belt was off my printer. The Raceway Holder is located in the center of the printer. The Raceway Holder is a guide for the Ink Supply Tubes. The Raceway Holder comes off easily. We had recently moved the printer. I suspect the Raceway Holder was jarred out of the hole where it was seated and the printer carriage pushed it to the left end of the printer where it pushed the Output Belt off its gear. My initial symptom was an error 86-11. I found the Raceway Holder lying on the left end of the carriage. After I removed the Raceway Holder from the carriage path, seated it in its hole, and threaded the Ink Supply Tubes through the loop on the end of the Raceway Holder, the error 86-11 went away. When retrieving the Raceway Holder from the left end of the carriage, I noticed the Output Belt was dangling from the paper drive shaft. That is when I had to find a manual to determine how to take the cover off the printer. The center cover and the left-hand cover must be removed to access the gears for the Output Belt. Bottom line: To avoid headaches after moving the printer, check to make sure the Raceway Holder is properly seated before using the printer.
The spring has fell out of the head when i was changing top i dont know how it goes back together
pull the black thing with the little blades until it detach, put the spring inside the hole, reassemble
May 09, 2010 | Braun Silk-epil 3370 Epilator
When I clean the inside of my clippers a metal o-ring fell out and I dont know where to put it. I dont have a clue where it goes
This may be the hanger to the trimmer, if this the part I think you are writing about it place at the electrical cord between the cord and the trimmer housing
Mar 30, 2010 | Andis Edjer 15515 Beard Trimmer
Part fell out of gun dont know where it goes
is it the carrier support spring or the trigger spring?
go to www.winchester.com look for owners manual for model 94 come times the site dont work well.you may have to call them and ask for a schematic parts break down they will send it to you or e-mail it.
Oct 28, 2009 | Sport & Outdoor - Others
The belt fell off of the drum, i have the front off but i dont know where the disconnected pulley goes.
Unplug dryer or disconnect power.
Locate mounting slots in front of motor. (In some cabinets, there are two sets of slots for mounting the idler assembly. In this case, mount the idler assembly in the slots that line up under the grooves in the motor pulley.)
Install idler assembly into cabinet base by hooking mounting tab (A) into 1⁄4" wide mounting slots and setting mounting tabs (B) into the 3⁄16" wide mounting slot.
Make sure belt is around drum, with grooves down.
Route belt through the idler and around the motor pulley.
Sep 12, 2009 | Whirlpool Dryers
The belt fell of the gears on my turntable.
Hi dont know the model but normally like so:
Take the platter of the turntable, it should just lift of, but there could be a circlip in the middle that needs to come off first. Just lift the mat first.
Place the belt back onto the platter first, should see where it goes, then put the platter back on. There are holes in the paltter which you can then grab the belt and pull it over the motor spindle.
Hope that helps
Jul 27, 2009 | Sony PS-LX250H Turntable
My belt fell off, and I dont have a manual. I just need to know how it goes back on.
there should be a belt routing diagam under the hood somewhere, if not, auto zone dot com had pictures of it........
Jun 29, 2009 | Oldsmobile 98 Cars & Trucks
Mechanism, belt came off.
Turn your machine upside down and give it a shake. Most likely, a small spring will fell out. The same thing happened to us and sure enough, it was the spring. This spring will give the tension you need to hold the belt on the plastic piece.
Sep 23, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Foam fell out of printer now printer jams
There are no foams inside the printer for normal operation. Unless this is the one that was inside it during shipping but you were not able to remove it. In any case if you are not having any problems then you are good to go. dont worry about it.
Aug 26, 2008 | Canon Pixma MP500 All-In-One InkJet...
HP Designjet 110plus nr InkJet Printer Logo
150 people viewed this question
Seeker5211
Seeker5211
