Question about LG 700M 17" CRT Monitor
Computer screen faultering
I have a monitor of lg.whenever i start the computer the screen has a orange hue to it .no matter what i try on the panels it does please help me.thanks in advance
  • 99 Answers
SOURCE: LG 194wt
This is most likely not a problem with the monitor but rather a problem with the computer. do you hear the fans running in the computer? If so then the Power Supply seems to be working which would leave the most likely things are CPU or motherboard and the only way to determine which one it is would be to try the CPU on a different motherboard or try a different CPU in that motherboard.
If the fans do not run then the problem is most likely the Power Supply. The biggest problem here is that although what I have outlined is the most likely problems there are other things that could cause this and whether the fans are running or not it could still be the CPU motherboard or Power Supply. If you can I would check the voltages from the Power Supply or at least get a power supply tester to see what that shows and work from there.
Posted on Nov 13, 2007
  • 220 Answers
SOURCE: LG 1710b tft monitor - no picture. screen shows 4 hozizontal line
Problem with Interface board or panel.
Also maybe due to defective powersupply filters.
Posted on Dec 10, 2008
  • 115 Answers
SOURCE: Monitor does not start .. orange color lights up
Possibly the Memory (RAM) is faulty.
Posted on Dec 18, 2008
SOURCE: opening an LG computer monitor
i have same problem
Posted on Jan 29, 2009
  • 92 Answers
SOURCE: How to unlock LG monitor controls?
BODY { FONT-FAMILY:Tahoma; FONT-SIZE:10pt } P { FONT-FAMILY:Tahoma; FONT-SIZE:10pt } DIV { FONT-FAMILY:Tahoma; FONT-SIZE:10pt } TD { FONT-FAMILY:Tahoma; FONT-SIZE:10pt } Try pushing the menu button and the right arrow button on the monitor together for about three seconds. The message "controls unlocked" should appear.
Please don't forget to rate this solution.
Posted on Jun 09, 2009
  • 2185 Answers
SOURCE: lg monitor studioworks e 700, ligh is blinking
Seems that its not detecting the output of your PC. First, you need to make sure that the PC is turned on. Can check also that the VGA cable fits tightly on the video card socket. This cable is the one connected to your Monitor and then straight at the back of your PC.
If it still does not work after this, try to check and test other monitors. Connect it to your pc. Note the current resolution. If its on a high rate, try to set to it at minimum only.If it works with other monitors, then it's a problem with the LG. If you still see the blinking lights even after replacing the monitor, check if its an issue with the Video card already.
Posted on Aug 17, 2009
0 characters
1 Points
LG E1940S Monitor displays with a pink hue. I am using with a T40 ThinkPad and XP
A pink hue is a sign the CCFL lamp is about to fail.
The CCFL lamp is a fluro like tube approx. 2mm in diameter that is located on the bottom edge of the LCD screen that supplies the back light to the screen.
Replacement CCFL lamp is available from this WEB site.
Jun 04, 2011 | LG E1940S 19" LCD Monitor
Monitor color changes to an orange hue periodically
check VGA/DVI cable connecting it to your PC for any loose ends (most likely at your pc VGA/DVI port)
Mar 24, 2010 | TDV Vison TDV FV19B 19" Flat Panel LCD...
LG 710s monitor problem screen turns green
Your AUTO settings button is stuck in! Try tapping on it a few times. Otherwise you may have to take the frame apart so you can get at the button.
Dec 28, 2008 | Amptron AMV 17V5 17" LCD Flat Panel...
LG FLATRON L1732S Problem
Well, It's time to retired this LCD... Your panel it busted! Treat yourself a new monitor... Happy holidays!
Dec 05, 2008 | LG Flatron L1750S 17" LCD Monitor
Digital Power Saving Mode
Go to your monitor power settings and turn off Hibernation and other monitor power schemes.
If this problem persist, request for more technical assistance from the manufacturers website
Nov 30, 2008 | LG W2252TQ Monitor
Screen is now a weird color
The problem might be in the cable. Try to reconnect it to your machine. Also try to set your color settings on the monitor itself, so that all the colors are equal.
Sep 26, 2008 | LG Flatron L1750S 17" LCD Monitor
LG Flatron problem
i get a black screen and an orange light in my lg lcd flatron whenever i turn it on.. i cnt use my pc because of this problem.. i hope u would answer my question...
u can email me at
tnx man :)
Apr 09, 2008 | LG Flatron L1710S 17" LCD Monitor
Monitor gets a blue hue
Hey Tricky Cat!
My first advice would have been the cable...since that did not resolve it it can only be 1 of two other things...the video card (might be intregrated on your motherboard)...or the monitor.
To test plug in another monitor if you have one. If the problem resolves it is the monitor...if not then the video card.
You will have to way your expenses to fix...usually a monitor is cheaper to well as a video card. If it is integrated the cheapest route is to buy a new video card and turn off the old one in the BIOS.
Good luck my friend.
Seek PC Repair
Feb 09, 2008 | LG L1520B 15" LCD Monitor
Im having monitor problems
have you tried replacing the video card?
Oct 01, 2007 | AOC CT720G 17" CRT Monitor
LG 700M 17" CRT Monitor Logo
23 people viewed this question
Top LG Computer Monitors Experts
Lawrence Oravetz
Level 1 Expert
Are you a LG Computer Monitor Expert? Answer questions, earn points and help others
