Question about Dell Inspiron E1505 Notebook
Volume dropping in and out while recording audio.
Whenever I try to record live audio into any sound editing software (Cooledit, Audacity, Ableton Live, etc.), the volume fluctuates and sometimes goes out completely. I thought that this could've been due to problems with virtual memory, but I moved the bulk of my programs and files onto an external hard drive and the problem persists. Also, music playing through my external speakers sometimes cuts out, but if I jiggle the audio cable near the sound card input it usually fixes the problem. This leads me to believe that the problem lies somewhere with the soundcard.
If that is the problem, is it possible for me to install a new sound card myself? What kind of sound card would be compatible with E1505?
If that is not the problem, I would greatly appreciate any help figuring this out.
Thanks in advance.
  • kehrtiss Oct 29, 2008
    Damn, I was afraid of that. Thanks for the quick response Walter.
  • Dell Master
  • 998 Answers
If you jiggle the cable and it starts working, then you probably have a cold or broken solder connection on the audio jack. The sound card is not a card but integrated into the motherboard. You could have a technician re-solder the connections on the motherboard but if that doesn’t work the motherboard will have to be replaced.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Oct 29, 2008
How to transfer vinyl to cd-simply-I have manual but very confusing-simple step by step needed-thank you-Al B
The popular recording software known as Audacity is a good choice for getting all sorts of sounds saved in a digital format. The easy-to-use features of this program will help you to create complex musical compositions, or just record incoming audio streams. One of the basic things you can do with Audacity is to record sound from vinyl records. Many people still keep vinyls on hand, though the production of this medium has diminished. Here are the basic steps that will help you to use Audacity to record vinyl.
Steps
  1. Get your phonograph or record player. Assemble your collection of records and make sure that your record player is in good functioning condition.
  2. Use a cable to connect your record player to the computer with Audacity installed on it. In order to record from vinyl, you'll need to make sure you have accurately connected your record player as an incoming audio stream into the microphone jack of your computer.
    • Use hardware adapters to secure your cable connection. Many older record players utilize a 1/4-sized input jack. The modern laptop computer, as well as many desktop models, use a smaller, 1/8-sized input jack. You can buy simple adapters at your local electronics store to fix this problem.
    • Make sure that your cables and adapters support stereo.
  3. Open the Audacity program on your computer. You will see the signature Audacity screen, with controls at the top, and an empty space to accommodate created tracks.
  4. Start playing the record on your record player.
  5. Hit the red circle that represents the "record" button in Audacity.
  6. Observe the sound coming into Audacity. You should see the track being populated with sound, represented by a fluctuating line as the cursor moves along.
  7. Hit "Stop" to stop the recording.
  8. Stop the record player.
  9. Repeat this process with the entire track. Reset the record player, start playing and hit the Audacity "Record" button again, allowing the entire track to populate with the sound of the vinyl record.
  10. Save your project in your desired format. Audacity supports a number of file formats for the finished product. You can select one of these when you have recorded the entire track. Make every song its own track, or simply record the entire side of the record on one track.
Aug 26, 2015 | Audio Players & Recorders
Ring tones, and volumes are not loud enough
Check your phone's setting if it's on maximum volume. Actually you can change your ringtone or edit it with an audio editor, increasing the natural volume. Some ringrones are recorded at a very low volume.
You can use AUDACITY for Windows audio editor on your computer
Audacity
Audacity Portable PortableApps com Portable software for USB portable and...
Aug 16, 2015 | Motorola DROID Turbo
Oxygen 49 midi controller switches itself off when pressing "record" button on Ableton Live
Make sure only the midi input is set, not the output, and that the channel your using is armed. Otherwise the signal won't get through in record mode.
Apr 28, 2017 | M-Audio Music
Alesis io2 guitar inpu and mute playback for backing track in audacity
Audacity is a copyrighted audio source and does not permit you to record tracks or playback of any kind. you will need to D/L the audio file you are trying to record in tangent and then play them together through an audio remixing app, like Ableton live or FL Studio
Jan 28, 2014 | Alesis iO 26 Sound Card
Got record and it is not loud. never had any problems with other vinyl records sound quality. I want the songs to be converted to MP3 but the sound on them is so flat. other records I have converted sound...
Hi, maybe the record is worn and that's why the sound is low. By using third party audio editing software (i.e. cool edit [paid] or audacity [free]) you can improve quality and volume of digital sound.
Aug 11, 2011 | ION Audio Vinyl Recording Turntable
I am only getting one channel when recording from Numark Ion Usb turntable, using Audacity software. The software is configured for stereo, but left track is not recording (and no sound from speaker...
Set your Audacity software to STEREO MIX on the main window. Go into EDIT, Preferences and set the recording device to your sound card and the channels to 2 stereo.
Mar 07, 2011 | ION Audio iTTUSB Turntable
I have a Sony ICD-BX800 IC Recorder. I have purchased and hooked up the Audio Cable to transfer the recordings to my computer (I need to email them to someone.) However, I did a test recording, and the...
Sony IC RECORDER ICD BX-800 (!without USB connection!)
What you need:
- newests audio drivers in Windows 7 (updated audio-drivers)
- audio cable 3,5 M (male) both ends M-M (male-male)
- freeware application Audacity for Windows (with LAME)
Howto step by step:
- one end of audio cable connect to dictaphon's headset (earphones) jack in recorder Sony IC RECORDER ICD BX-800
- other end of audio cable connect to PC/notebook microphone (or LINE IN)
- nothing special setup (adjust) regarding Audio in Windows 7, the device for record Audio keep Microphone (default)
- in Audacity set very little volume "Input Volume Slider" and "Output Volume Slider" (for example both 0,1)
- in Audacity like Input Device set "Input (Audio device High Definition Audio)": !Don't set in Audacity like Input Device "Microphone"!
- Audio Host: MME
- Output Device set "Speakers (Audio device)"
- Input Channels set "2 (Stereo) Input"
- Sampling (Hz) set 44100
Dec 26, 2010 | Audio Players & Recorders
I cant install the software that comes with the product. should i download something else online? Sorry, im new with recordings.
Make sure you have Administrative privileges to install software, in the User account settings. you can download Ableton live lite here. I always used Fruity Loops to record, it takes a little time to understand how the software works but it's really intricate, great software to record music and you should be able to use this hardware with it.
Here are system requirements:
Compatibility
ASIO 2
MME
Sound Manager
DirectX
Mac OS X Core Audio / Core MIDI
Minimum System Requirements (PC)
Windows 98SE / Me / 2000 (SP4) / XP (SP2)*
Pentium II 350 w/ 64MB RAM
* Home and Professional Edition only. Windows Media Center Edition is not supported.
** M-Audio suggests you also check the minimum system requirements for your software, as they may be greater than the above.
Minimum System Requirements (Mac)
G3* 300MHz/G4* 350MHz
OS 9.2.2, 64MB RAM;
OS X 10.2.6, 10.3.6, 10.4, 10.5.1 w/ 128MB RAM**
* native USB port required; G3/G4 accelerator cards not supported
Jan 02, 2010 | M-Audio Mobilepre USB Bus-Powered Preamp...
How to use
the best way is to connect your master output to the uca200 input and uca out to your amp. u have to use a sound editing software to record.suggestions-audacity.
Yours DjNicq
Jul 21, 2008 | Behringer (UCA202) Sound Card
Recording live d.j. mixes ,
Audacity and Krystal (free windows based programs)
What about an LE version of Cubase or Sonar (little hard to learn if your just want to record something light and not edit).
May 28, 2008 | M-Audio Fast Track Pro External Sound...
Dell Inspiron E1505 Notebook Logo
131 people viewed this question
Alun Cox
