Question about Philips Magnavox MT1905B 19" TV
TV plug came loose inside tv
My tv, was knocked over by one of my grandchildren. the power plug that connects to wall and tv, was knocked loose from inside the tv. Help where does it go? the end is a small white plastic with about 6 holes in it.
    Sergeant:
  • 337 Answers
The damage most be heavy for the power cord to come out with the conector that attaches to the main board,telling you where it goes will not help because most likely you have a broken main board,you shoud get an estimate from a qualified technician.
Posted on Sep 11, 2006
Why wont my sharp lcd LC-32D44U turn on?
Well, there could a be few issues. First thing is to verify the breaker that gives power to that wall has not tripped off in the home's break power panel. If it is not tripped then verify the wall outlet that the TV is plugged into has a reset button, like a GFI (ground fault interrupt) If it does then verify that it has not tripped. If the GFI on the wall plug is tripped simply push the reset button back in and then try plugging in your TV power plug again. Then if that checks out or does not have a GFI outlet, verify that the power plug going into the back of the TV is not loose. Unplug and replug power plug that plugs into the back of the TV in and verify it is securely connected. Lastly, the power supply in the TV might have gone out.
Aug 22, 2014 | Sharp AQUOS LC-32D44U 32 in. LCD TV
My 32inch lcd tv keeps flickering it started all the sudden
TRY THIS
    • 1 Turn the TV off with the front-mounted power button, not the remote. Unplug the TV's power cord from the wall outlet. Let an hour pass before plugging the cord back into the wall outlet. Turn the TV back on with the front-mounted power button and wait until it has fully restarted. Bring up a TV channel to see if the image being presented on the LCD screen is no longer flickering. A momentary power surge can cause the circuitry inside the LG-brand LCD TV to function erratically.
    • 2 Unplug the video cable from the video connection on the back or side panel of the LG TV. If more than one video cable is connected to the TV, disconnect all of them. Disconnect the other end of the video cable from the video source device that it's attached to -- a DVD or Blu-ray player, or a satellite receiver or cable box. Blow off the connections on the video source device and on the back or side panel of the TV with bursts of compressed air. Reinsert one end of the video cable into the video source device and the other end into the video input that it was connected to. Turn the TV back on with is remote to see if the picture is now free of flickering. A loose or partially connected video cable can cause the LCD TV's screen to flicker when presenting an image.
    • 3 Turn the TV off and unplug its power cord from the wall outlet. Place a power conditioner next to the wall outlet. Plug the power conditioner's power cord into the wall outlet. Plug the TV's power cord into one of the AC sockets on the power conditioner. Turn the power conditioner on. Turn the TV on to see if the picture is now free of flickering. The RF signals in the electric line that the LG TV is drawing power from can cause flicking through interference patterns being generated.
Oct 20, 2012 | Computers & Internet
TV randomly turns itself off and on
This issue is related to the TV's main board not seeing constant A/C power to unit so the board is turning off the TV.
When the TV's main board see A/C power back to the unit, the TV will try to turn back on.
This issue could be a loose power connection for the TV or a failing part inside the TV. Do other electrical devices work when plugged into the same wall outlet?
Try the following:
1. Remove the cord from the back of the TV and reinstall it (perhaps it's loose going into the TV and was not installed correctly).
2. Try putting the cord into a different wall outlet (perhaps it's not a good outlet).
3. Try using a new power cord for the TV. (Any matching cord will work for testing)
If the above did not resolve the issue, then it could be the switch mode power supply and or the main board inside the TV. Both items are easy to change out.
I can look up the LG part number for you.
Feb 16, 2010 | LG 22LG30 22 in. LCD HDTV
No power in surround sound system(DVD/subwoofer)
The key could be the word "move".
Electrical items can get knocked moving and something might have become loose or damaged inside the sub. So check it out. Inside too!
Feb 28, 2018 | JVC TH-C3 System
Television does not turn on
please check the ac plug at the wall and also behind the tv. most newer tv's have a cord like a computer that plugs in the back and they sometimes come loose. are the rest of your electronic components working ? if the ac cord is plugged in, your power supply inside the tv has gone bad. you cannot blame your 2 year old if this power supply has gone bad, this was "NOT" caused by playing with the remote control.
Jan 18, 2009 | Televison & Video
I BOUGHT A SAMSUNG 27" TV LAST CHRISTMAS IT WAS WORKING FINE UNTIL YESTERDAY. NOW IT SHUTS OFF BY ITSELF AND CANNOT BE TURNED BACK ON. I DO NOT HAVE THE RECEIPT AS MY GRANDCHILDREN BOUGHT IT FOR ME...
Remove the wall plug and count to 10, then plug it back in. If it still doesn't work ask your grandchildren to help you with a 'Warranty Repair'.
The warranty is 12 months.
Warranty Information
Nov 26, 2017 | Televison & Video
Daewoo DSP4210GM 42 in. EDTV Ready Plasma TV
what way did you set the tv in the transport vehicle. something has been knocked loose inside or the videomask has been damaged?
May 14, 2008 | Daewoo DSP4210GM 42 in. Plasma Television
Video Recording causing Picture interference
When you are recording, do you hear the vhs tape(motor) moving? Is the tv\vcr combo connected to the same power(electrical) plug with ANYTHING else ? On the SAME wall outlet with anything that generates noise?. Do you have ANYTHING ( electric clock ) WITH a motor connected to the same line\wall\outlet\power adapter?
2nd) Any loose ground [wires that go to any menal part inside TV\VCR will cause problems. Be very carful inside electronics parts and when they are alive [pluged in & turned on], Some times loose VHS rubber bands cause problems by slipping and jerking the tape recording.
Apr 29, 2008 | Televison & Video
Color TV
it might be due to
  • plug or socket loose where tv is connected.
  • loose connection in switch.
  • some connector loose in power supply
  •  switching transistor in power supply &horizontal section loose or wire open
  • some capacitor loose in oscilltor section in power supply.
  • if you are not tech. person please take help.
  • hope this will help
  • good luck
Oct 16, 2007 | Televison & Video
Philips Magnavox MT1905B 19" TV Logo
44 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
