Question about Vertex iTECH iQfive iQplus Yeasu--VX800 Compatible Two Way Adapters 2-Way Radio
Vertex VX800u Radio
How do I program 2 new (used)radios to the same one I already have that works? I know it needs to be cloned but what exactly do I need and how to do it And where is the best place to purchase cables? they seem expensive.
  • 55 Answers
Don't you know how to read the instruction manual?
Posted on Nov 05, 2008
I bought a baofeng uv5r and want to link it to my work radio which is a vertex standard vx160u..I can transmit from the work radio to the baofeng but cant figure out how to transmit back to the vertex
First of all, technically, you can't use this radio to talk to anyone other than ham radio- that being said, if you want to proceed at your own risk. Ok, is your work radio an analog radio? Is it narrowband FM? Is it digital MOTOTRBO? Last two will make if difficult. Digital is impossible. Next, find out the exact transmit and receive frequencies for your radio. They may not be both the same if you have a radio 'repeater' your input frequency could be 5MHz higher than your receive frequency. And last- you need to know if your system has a "PL" tone (CTCSS, or DCS) subaudible tone that will break the squelch. So there are several variables that you will need your plant supervisor to relay to you. Good luck. You can probably get much of this info on line from radio reference.
Apr 30, 2017 | Vertex Radio Communications
Vertex 231 set to receive an alert tone will not trip while pagers set the same way do. They used to, 8 radios stopped performing properly within 1 1/2 months of each other
It is most likely the encoder. It sends the signal to make the radios act like pagers. Two tone radios and pagers use almost the same exact format for programming. Has anyone worked on the base station or encoder? That is where I would start. Do you have the Vertex software and cables? It could be called a timing setting. This may not be a simple fix. Is there a service shop nearby? We've worked on pagers over 30 years and VX 231's for 12 years. They simply do not stop working unless someone adjusted something.
Feb 10, 2017 | Vertex Radio Communications
Clone Motorola BPR40 with PMDN4060AR, but I'm getting a low continual tone from the slave radio from Ch 2 above
Even with a cloning cable, you cannot always clone. The source radio and receiving radio must (1) be the same exact model, (2) have cloning enabled in the software a dealer used when they were programmed the first time. It sounds like you are doing the correct procedure.
Nov 18, 2015 | Motorola Radio Communications
Will transmit but will not receive
I have programmed hundreds of these. The radio may be receiving, but the speaker may be muted. If using a hand mic, have the mic "off hook" or ungrounded and try again. Does the front light flash while the radio is receiving? This indicates the radio is "hearing", just not passing the audio to the speaker. Is there something plugged into the audio jack in the back? Let me know. In 20-30 minutes most shops familiar with Vertex will know exactly what is happening.
Oct 01, 2015 | Vertex Standard VX-2100-G7-45-PKG-1 UHF...
Icom ic fr5000 clone NG whats is solution for this?
Clone means that you are copying radio program from one radio to another of the exact same radio. For some reason the other radio did not take the information. The radio may now need to be re programmed and not cloned in order to work.
May 20, 2014 | Radio Communications
Hi I have a vertex vx2100 radio and I need to know if I can use it as a police radio scanner
Yes. The Vertex VX2100 is a VHF radio which can be programmed to frequencies between 134-174 MHz. You would need to program in the frequencies you are wanting to scan as receive only (no transmit) into the 8 channels of the radio. You would need to acquire the frequencies you need, as well as programming equipment, or take the radio to a dealer for programming.
Best regards.
Mar 31, 2014 | Vertex Radio Communications
Help with Vertex VX-3200 Programming
You may have to find a windows XP or earlier machine. That software doesn't always play well with WIN7
Mar 06, 2014 | Vertex Vx-3200 / Vx-2500 Series Programing...
How do i put a program in to my Vertex Standard VX-929 VHF 136-174 Mhz radio handheld portable transceiver
Nice commercial quality radio. You will need a commercial radio shop to program it. Otherwise you need the particular programming cable and software for that radio to do the job. The fact that you are asking this means that it more than likely it is beyond your area of expertise. If you searched the web for programming software and also programming cable you might succeed . Otherwise order both from Vertex USA, Much easier to go to a shop, BTW you need a valid FCC business or GMRS radio license to transmit.
Dec 03, 2013 | Vertex Radio Communications
Need to know how to program a Ritron RTX-450
One of the three following remedies should help you: 1) Contact your local Ritron dealer and they can program the radio via programming cable and computer, using the appropriate software. 2) Clone the radio using a cloning cable, from a master radio. 3) Contact Ritron at 800-872-1872. They can assist you with locating a place to get the radio programmed, or you can purchase software and cables through them.
Feb 19, 2009 | Ritron PX80AM, ,JBX-151,RTX-450,PATRIOT,...
Vertex 180 cloning
from my own experience, vertex customer service in california has been excellent. try giving them a call. 714-827-7600
Feb 20, 2008 | Radio Communications
Vertex iTECH iQfive iQplus Yeasu--VX800 Compatible Two Way Adapters 2-Way Radio Logo
440 people viewed this question
Top Vertex Radio Communications Experts
Level 1 Expert
Are you a Vertex Radio Communication Expert? Answer questions, earn points and help others
