Question about LG CHOCOLATE VX8500 Cellular Phone
Lg vx8550b my phone is locked , i cant use any menu options, make any phone calls or any other phone options .all i can do is try to entry a four digit code to gain access. all i get when i try to make a call is phone is now locked or locked emergency #or special#calls only i need a code for my lg vx8550b
  • Anonymous Oct 30, 2008
    mine is da same thing
  • Anonymous Mar 30, 2014
    Cant do anything but emergency calls
    Champion:
  • 221 Answers
The lock code should be the last four digits of your phone number
Posted on Nov 11, 2008
How do I unblock a phone number on my uniden dect 6.0 phone
Call block entry options:
With the phone in standby, open the call block list and find the entry you want.
Press Menu/select to open the individual entry menu. Choose one of these options:
  1. Edit (Handset only) Edit this entry. The phone will prompt you to edit the name & phone number.
  2. Delete Erase this entry from the list & allow calls from this number.
May 22, 2015 | Uniden Lands Phones
Forgot lock code for lg vx3100
hi..
To lock the phone:
  1. Press the left soft key for Menu.
  2. Select Settings then press OK.
  3. Select Security then press OK.
  4. When prompted, enter the 4-digit lock code (the default code is the last four digits of the cell phone number).
  5. Select Lock Mode then press OK.
  6. Choose your preferred option then press OK:
    • Never
    • On Power Up
    • Always
To unlock the phone:
  1. Press the right soft key for Unlock.
  2. When prompted, enter the 4-digit lock code (the default code is the last four digits of the cell phone number)
thanks for rating
Jun 02, 2011 | LG VX3100
No manual and am receiving unwanted calls at night just became threatening how do i block them
Using Call Block
If you subscribe to Caller ID, you can save phone numbers to the call block list. When a call comes in, the phone compares the received phone number to the numbers on the call block list. If the phone number is on the list, the phone replaces the caller's name with Call Blocked and disconnects the call. (The caller hears a reject tone.)
The call block list holds 20 entries, and all stations share the same list. You can add entries through the Call Blocking menu, by selecting Add Call Block in the CID menu, or by blocking incoming calls. (Only one station can edit the call block list at a time.)
Blocking incoming calls
  1. When the phone rings, wait until the display shows the Caller ID information (usually after the second ring).
  2. If you want to block the call and add this number to the call block list, press Block.
  3. When the phone asks you to confirm, press Menu/select or Block. Blocking an incoming call from an "Unknown" or "Private" number is the same as selecting Unknown Number or Private Number from the Call Blocking menu.
Call Blocking menu options
  1. With the phone in standby, open the menu and select Call Blocking.
  2. Choose one of these options:
  • Create New(Handset only) - Add an entry to your call block list. The phone will prompt you to enter a name & phone number.
  • Private Number(Handset only) - Block all calls from numbers reported by CID as "Private." (This does not count as one of the 20 entries.)
  • Unknown Number(Handset only) - Block all calls from numbers reported by CID as "Unknown". (This does not count as one of the 20 entries.)
  1. With the phone in standby, open the call block list and find the entry you want.
  2. Press Menu/select to open the individual entry menu. Choose one of these options:
  • Edit(Handset only) - Edit this entry. The phone will prompt you to edit the name & phone number.
  • Delete - Erase this entry from the list & allow calls from this number.
Mar 20, 2011 | Uniden DECT21883 Trio Cordless Phone
I need to reset a LG rumor touch to factory settings. Forgot lock code. Is not last four of phone # or 0000. Is there a programming code to re set it?
If you have forgot the codes for your mobile you can unlock it by using the last four digits of your phone number or four zeros. If these codes are not working you can contact your network service provider to get the unlock codes.
If you need to reset your mobile then press the "Menu" button,from main menu scroll to "Settings/Tools" and select the option by pressing the center "Menu/OK" button.Scroll to "Settings" and select.Scroll and select "More". Scroll to "Security" and press your "Menu/OK" button.Enter in your phone's security code when prompted. Select "Reset/Erase", then "Reset". A warning message will appear. Press the "Menu/OK" button, then highlight and select "Yes" to confirm the reset.
Thank you !!
Jun 10, 2010 | LG RUMOR Cellular Phone
HOW CAN I USE A CODE SO NO BODY CAN SEE MY STUFF ON MY LGVX1000 VOYAGER
using phone lock is the simplest method which meet urrequirement
please follow the steps below
1.Open the flip and press the OK Key [M ENU] .
  • 2. Press the Navigation Key to
    scroll to the Settings & Tools
    menu and press the OK Key .
    3. Press Phone Settings.(6)
    4. Press Security.(6)
    5. Enter the four-digit lock code.
    6. Press Phone Lock.(3)
    7. Scroll to an option then press the
    OK Key .
Lock Phone Now
Using the Internal Keypad
1. Open the flip and press the OK
Key [MENU].
6. Press Lock Phone Now.(4)
May 19, 2010 | LG VOYAGER VX10000 Cellular Phone
I want to lock my LG Neon
You can use the access codes described in
this section to avoid unauthorized use of your
phone. The access codes can be changed by
using the Change Codes menu (Menu #.2.6).
Security code (4 digits)
The security code protects the unauthorized
use of your phone. The default security
code is set to ‘0000’ and the security code
is required to delete all phone entries and
to activate the Reset Settings menu. The
security code default setting can be modified
from the Security Settings menu.
Feb 04, 2010 | LG Neon GT365 Cell Phone
It unlocks easy in my pocket and calls people
ENV3 right? two options: option 1:go to settings and tool from the main menu (flipped open and pressed ok) Go to 6: Phone settings. Click security. Type in the last four digits of your cellphone #. Go to 4: Lock phone now. To unlock it: type the last four digits again. If you want to lock it on power up. Go to 3: Phone Lock on that same menu
2nd option: Click over on the keypad surrounding the ok button. Key guard will have a picture of a lock. Click OK on key gaurd. Go to 3: Unlock options. Go to press once or press twice. Then it will unlikely to dial numbers in your pocket. Go to 2: Keygaurd Timer. Set it for 7 seconds. Then, click cancel. Go to 1: Lock Now on the same menu for instance results.
Dec 02, 2009 | LG enV3 VX9200 Cell Phone
How do i set password to access my phone (V9)?? I want to set a password on my phone so that no one else could just open it and start fiddling with my personal stuff. I can easilydo that on a nokia but i...
usually your able to go into the menu and the either options or settings and click on security! but some phones are so dang complicated. lol here is what ive found its a razr 2 v9 right?its from the motorola website
codes & passwords
Your phone’s four-digit unlock code is originally set to
1234. The six-digit security code is originally set to
000000. If your service provider didn’t change these
codes, you should change them:
Find it: s >wSettings > Security > New Passwords
You can also change your SIM PIN or call barring
passwords.
If you forget your unlock code: At the Enter Unlock Code
prompt, try entering 1234 or the last four digits of your
phone number. If that doesn’t work, press s and
enter your six-digit security code instead.
If you forget other codes: If you forget your security
code, SIM PIN code, PIN2 code, or call barring
password, contact your service provider.
lock & unlock phone
You can lock your phone to keep others from using it.
To lock or unlock your phone, you need the four-digit
unlock code.
To manually lock your phone: Presss>
wSettings > Security > Phone Lock > Lock Now, then enter
your four-digit unlock code.
To automatically lock your phone whenever you
turn it off: Presss>wSettings > Security > Phone Lock >
Automatic Lock > On, then enter your four-digit unlock
code.
Oct 02, 2009 | Cell Phones
Forgot my lock code
The default lock code for any Verizon Wireless phone is the last four digits of your phone number. If you've changed the lock code, then you have two options:
1. LG phones can be reprogrammed even when locked, so dial *228 and press Send. When you hear the woman's voice choose option 1. When the call ends the phone will reboot and your lock code will be changed back to the last four of your phone number.
2. Bring the phone into a Verizon Wireless store, where they can read the lock code off the phone using their computers.
In the case of the original poster - if your phone isn't activated at all, as in it is not currently active on any phone number, then go with the second option. You could, if you really wanted to, call Customer Service and have them put that phone onto your phone number, then when you activate it (*228, send, option 1) the lock code will be the last four of your phone number.
Sep 26, 2008 | LG VOYAGER VX10000 Cellular Phone
LG CHOCOLATE VX8500 Cellular Phone Logo
213 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
