Question about Samsung DVD-P230 DVD Player
Player's settings messed up probably.
Hi, I suspect I will be buying a new DVD player soon, but I would like to hear from a knowledgable tech if I should even consider trying to find a correction to this problem. To-day my wife got confused between getting our VCR set up to play a tape and her DVD player to play a disk. She thought she had to call up a channel on the TV in order to access the DVD player, such as one would call up 3, in order to access the VCR to use it separate from the TV. Only problem here is that she tried several times to call up channel Zero on the TV then called me when her DVD wouldn't play. I suspect her button pushing has interfered with the 'firmware' coding in the DVD deck. I find it has no problem recognising & playing a CD but with a DVD in, it says it is Loading for quite some time, and then says 'No Disk". Am I close to the truth of the problem do you think? And should I expect that service people or anyone would have easy access to firmware repair disks? It's an interesting problem and I'm probably going shopping. Thank you. George
5 Suggested Answers
SOURCE: DVD will not load/format new disk
my samsung dvd writter does not open the tray were you put the disc
Posted on Dec 30, 2007
SOURCE: Samsung DVD-4600 DVD/VCR Player
My Smasung DVD/VCR Combo stopped reading DVDs because of a dirty read head. It started by only playing disks sometimes, and progressed to never playing disks. I assumed it was a dirty laser lens so I bought a lens cleaner set. Unfortunately my player wouldn't play the cleaner disk.
So I took it apart and cleaned the laser lens manually with some isopropyl alcohol (the clenser that came with my cleaning disk), and a lens cloth (that came with my glasses). Just open the case (starting with the screws in the back) and remove the snap in cross panel that obscures the lens of the DVD portion. Put a drop of cleanser on the lens and gently wipe it with the cloth.
Oh and by the way, I take no responsibility if you break your own player while following my instructions. My own DVD player was far out of warranty at the time I cracked it open.
Posted on Jan 17, 2008
  • 6 Answers
SOURCE: Recording on DVD-R with Samsung DVD-R155
Heating issue. If you remove the cover and touch the processor chip - you will not be able to keep your finger there for more than a second (that is if your really want to use this crude method to test the temp).
I have taken measurement and its around 50C. Thats a lot for no heatsink or cooling fan.
If you have the unit in a cabinet with no air flow - you will not be able to use this unit for more than 3 months and up to a year. Best to have it on top of a cabinet or in one with an open front and back to allow some airflow - or just anywhere where its in the open.
Samsung has another unit - the AR650, which I believe is discontinued - which for some strange reason has realized this concern. My guess its a whole different team of designers (or at least some folks with some brains) and added a cooling fan into the unit. Its the same exact case and motherboard as the 135, and 155. There are absolutely no issues with it rejecting disc's - even after a year of use for some users.
In Summary:
Solution 1 - Place it in the open
Solution 2 - Remove case and drill holes to the topside
Solution 3 - Remove case and add a fan
Solution 4 - Remove case and add a heatsink over proc (will still need to drill holes over heatsink..
Solution 5 - We can all complain to Samsung and have them recall the units
Posted on Aug 22, 2008
  • 48 Answers
SOURCE: I have a samsung dvd player combo. It's ab out 5
the eye wears out on them. if the eye gets damaged the lens will only read certain movies
Posted on Nov 30, 2009
Testimonial: "Thank you. I appreciate the input and it souns very logical. This was better information that I got from Samsung's tech."
  • 6 Answers
SOURCE: trouble with samsung bp-3600
Its probably the update. Samsung has had a history of pushing updates then having to send a new one to fix the last one. Sites like AVS forums are full of good info. If there's alot of people having the same issue it helps you identify the culprit. In these situations there's only 2 possible culprits the update or the player itself. If its still under warranty take it back and confirm its the update. Or, wait for the fix.
Posted on Jan 10, 2010
0 characters
1 Points
Our DVD player stops several time during a movie. This even happens on new movies. What can we do about this?
Tries websites like, buy a set that call a DVD or CD disc laser eye cleaner.Used it might help.If still happening than the laser eye itself it is dying and to be dead soon.DVD players that are having laser eyes are dying or don't read DVD or CD disc like say no disc all the time.Are not repairable except replaced the whole laser eye data's reader itself not practical,because u can a whole new basic DVD player just the same prices or even cheaper.These day a basic DVD players u can buy it like $40 brand new at any major box retailers stores like Walmart,Target..extra.
Sep 03, 2011 | Dynex DXUPDVD2 Player
My CyberHome CH-DVD 300 Player Not working CD, Only Disply "CyberHome DVD appear in Screen". I am in Near Tambaram. Please send Nearst Service centre Contact No. and Address.
Not reading anymore DVD movies disc or CD musics disc.The DVD laser eye head reader it is dead.Can't be repair must be replaced,not worth it well cost the same price as a new DVD player unit,if repair by a tech and have to buy parts for it.Basic DVD player unit are very cheap these day.U can buy a new one just a basic DVD player only will cost u like $40.
Aug 22, 2011 | Cyberhome CH-DVD 300 DVD Player
Don't read some of the dvd?
Try cleaning the laser with a lense cleaning kit, also make sure the disc you are playing is not scratched or dirty, you can buy disc cleaners also. If these are not issues, then I suspect the laser in your unit is wearing out and it is time to get a new player. Some of these cheaper Chinese made lasers work fine for a while but they soon give out.
Nov 17, 2010 | Ace Sonic DGX-106 DVD Player
My dvd player screen got broken i would like to fix it how much will it cost or just buy new one
hi there.
i would just buy another one.screens are expensive to buy,probably as much as a new unit.
and not too easy to fit if you havent done one before!
Oct 22, 2010 | RCA DRC622N Portable DVD Player with...
Hi there,i have a c-tech urc-10 remote control
I have a C TECH URC 10, and while doing the set up my TV(telefunken) whent blank and just the red standby light flashes.
Now I do not have any control,and cannot reset anything.
May 04, 2010 | Wharfedale DVD-M3 DVD Player
DVD not spinning
I would buy a new one, it will probably cost you about the same or more to have it fixed.
Jan 24, 2010 | Yamaha DVR-S120 DVD Player
Dvd wont play just spins
Usual suspects (I have seen each one of these):
1. Home-made DVD defective
a- bad blank
b- bad burn (software settings incorrect)
c- not finalized
d- bad DVD recorder
2. Commercial DVDs - very scratched near center hole where startup data lives
3. Dirty laser lens on DVD player
4. Bad circuitry in DVD player (repairs almost always cost more than a new player)
Jun 24, 2009 | Daewoo DV-6T834 DVD Player/VCR
I have a Pioneer DV 585A DVD player that happily plays DVDs and the background sounds seems to be fine, but on some of the DVDs you can hear the voices of the characters speaking and then on another you...
Hi edwardm1,
If you are only hearing part of the audio from your DVD player, I would suggest you check your audio settings before seeking repairs.
Audio can be encoded to a DVD in several ways. If the audio on the disc is different than the settings on your DVD player, you may not hear all of the audio layers. For example, if your DVD is encoded in 5.1 Surround Sound, but your DVD player is set only to play basic Stereo, you may only hear portions of the audio.
Try accessing the menu on your DVD player, and look for the audio settings. If there is a higher setting available than is currently selected, try a higher audio setting. A higher setting should also be compatible with lower types of audio encoding.
If this does not improve your audio, or if you need help navigating your product menus, I would recommend giving Pioneer's toll-free support line a call at (800) 421-1404.
Thank you,
Go Ahead. Use Us.
Jun 13, 2008 | DVD & Blu-Ray Players
Yamaha dvr-c300 dvd playeer
Hi sponge your lens is the problem call a tech to look at your set.good luck.
Apr 26, 2007 | Yamaha DVR-S200 DVD Player
Samsung DVD-P230 DVD Player Logo
15 people viewed this question
Top Samsung DVD & Blu-Ray Players Experts
Are you a Samsung DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
