Question about EliteGroup NFORCE4-A939 (NFORCE4A93910) Motherboard
Computer Freezing I am not sure if this is a motherboard problem or possibly a graphics card problem or what, I am quite the noob when it comes to this stuff. I play a few online games WoW and Warhammer. I would occasionally have problems with lock ups on WoW (have been playing for over 3 years) but now it locks up almost instantly when I begin playing. Also I have not been able to play Warhammer for more than 3 min at a time without lock up. Tried all the fixes suggested by the support for both games except, one suggested I upgrade my video card. They feel that it may not be advanced enough for all the graphics in the game. I guess my real question is how do I figure out what new cards my motherboard will accept? Any other advice would be greatly appreciated also.
  • boodit Oct 29, 2008
    Thanks *****, I will try the memory stick first if no success I will try a new graphics card. I forgot to include the current card/type in my last post: PCI-Express GeForce 6600 512MB DVI/TVOut. If I try to up grade my graphics card as long as it is a pci card with additional memory I don't have to worry about too much else? Thanks for the prompt responce and I will let you know how it goes.
  • 147 Answers
I have built several gaming computers and if I had your problem, the first thing I would try is to add a stick of memory.Then I would get me a graphics card with some memory built on the board (256 meg). You motherboard should run a pci graphics card with no problem.
Posted on Oct 29, 2008
  • butch welch Oct 29, 2008
    Ahaaaa man, Being a pcix card with 500 meg, It should run just about anything you throw at it.. Good choice.
What are some mid to high end compatible GPUs for this motherboard
instead of assuming a comparability issue, have you considered a power supply issue?
have you disabled the onboard video?
have you exchanged the card? have you tried a different brand
according to your boards tech support:
  • Some PCI Express graphics cards require more power.
  • Remove and reinstall the new card to make sure it is fully seated in the slot.
  • Try the card in a different slot, if possible.
  • Make sure other devices and cables inside the chassis were not disturbed or loosened when you installed the new card.
Desktop Boards Computer Does Not Boot After Installing New Hardware or...
additionally, you need to make sure that you have more than 2 gigabytes of system ram; although, wwith an i7, i would expect yo have that already covered.
Oct 15, 2014 | Intel Motherboard BLKDX58SO Core I7 X58...
Will a DDR3 graphic card work as it should work on a DDR2 motherboard or ram
Add more RAM
If you're not sure if a module is right for your system, use the
Crucial Memory Advisor tool for a list of guaranteed compatible modules.
First you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system.
You should always ask for a guarantee on the compatibilitybefore making any purchase and try to buy for working pairs if possible.
computer users often get confused when assembling or upgrading their first computer. While the most common error is made when distinguishing system memory, RAM, from hard drive space, gaming computers have an extra wrinkle to worry about.
Graphics cards use memory separately from the system memory mounted on the motherboard. Some graphics cards use the more typical DDR standard, though it's permanently attached to the graphics card circuitboard, while others use the new GDDR standard.
For the most part, the internals of the graphics card aren't relevant to the rest of the computer it's all about the connection slot.What Is DDR Memory?
DDR, or "Double Data Rate," is the standardized random access memory format for most desktop and laptop computers.
DDR RAM comes in different generational standards: DDR, DDR2, DDR3 and the newer DDR4.
RAM chips, known as DIMMs, come in only one format, as do the DIMM slots on motherboards, so a DDR3-compatible motherboard memory slot can accept only DDR3 RAM DIMMs RAM that uses an earlier or later standard is incompatible.
GDDR Memory and Graphics Cards
Modern graphics cards use a modified memory standard called GDDR, short for Graphics Double Data Rate. While similar, GDDR and DDR memory is not the same:
Most importantly, GDDR memory is integrated into the graphics card and cannot be removed. Some older graphics cards use DDR, DDR2 and DDR3 memory, but this is also integrated into the card.
Graphics cards of varying power come with different kinds of RAM as of the date of publication, most cards feature GDDR4 or GDDR5 memory
Graphics Card Motherboard Connections
Discrete desktop graphics cards are mounted inside a computer case and plugged directly into the motherboard.
Three standard connections are used for graphics cards: PCI-Express (the most common and powerful), PCI and AGP.
It is this connection that determines how much data can be shared between the graphics card and the other system components, such as the CPU, the system RAM and the hard drive.
The expansion slot standard is the primary function for determining whether or not a graphics card is compatible with any given computer:
If your motherboard has a PCI-E slot, it's compatible, if not ideally so, with all PCI-E graphics cards.
Graphics Card Memory and System Memory Compatability
Memory is an important part of game performance, but graphics memory and system memory are two different things.
For better performance, it's best to have as much graphics memory AND system memory as possible, but the different standards used by the graphics card and the motherboard are largely irrelevant.
As long as the graphics card uses the correct expansion slot standard, it will work with the corresponding motherboard, regardless of its DDR version.
Mar 10, 2014 | IBM Lenovo ThinkCentre M55e PC Desktop
I have a home PC that was built by a computer shop a few years back, I moved and when I tried to start the computer, the monitor will not come on. says monitor going to sleep.
Make sure that all expansion cards, especially the graphics card is seated fully in its slot on the motherboard. If it is using onboard graphics (usually VGA on the motherboard) then the graphics may have gone bad.
Jan 29, 2014 | PC Chips : PC-Chips M811LU Socket...
Hi there,This is quite likely the fact that your graphics card is not inserted correctly into your motherboard,You should power down your pc,And try and re-fit your video card,(or even try and use anotehr PCI slot if possible) and make sure that it is firmly positioned into the motherboard..
This should fix your issue,good luck
Jan 15, 2011 | XFX NVIDIA GeForce 8600 Graphics Card
Keeps telling me no signal
The motherboard is not telling you there is no signal, the monitor is..
In this order:
  1. Test the connection from graphics card to monitor, try a different monitor to eliminate this from the issues.
  2. If other monitor works, the old one is causing the problems
  3. If new monitor does not work:
  • Check the graphics card is seated properly, if possible, test with another graphics card, if this works, the issue is with the graphics card
  • If this does not work, check the fan on the cpu, is it spinning? If not, make sure the fan is connected to the motherboard
  • If the fan is spinning, remove all the ram, reboot, you should get a series of beeps, make note of these and repost them (computer will not boot)
  • If you get NO beeps with ram removed, the CPU or motherboard are possibly dead, if possible, replace CPU with known working one and retest with and without ram in, make sure you have thermal grease on the CPU>heatsink. Replace the Ram (or one module)
  • If you get a single beep and the motherboard powers the monitor, the CPU was your issue
  • If you get no beeps, confirmed death of motherboard.
Possible other solutions: Remove CMOS battery, leave for 1 minute and then replace, see if it boots
Check the power switch from the computer front panel is not sticking
Jan 07, 2011 | Computers & Internet
Was wondering if it can be replaced with a better graphics card
This depends, mspolar1.
Depends on;
1) If it's a Desktop computer, or a Laptop computer.
Desktop computers may, or may not, come with Integrated Graphics.
For those desktop computers that do Not, a graphics adapter card is used.
(Graphics adapter card is also referred to as a Graphics Card, or Video Card)
Desktop computers that Do come with Integrated Graphics, will also have a graphics expansion slot to install a graphics card in.
2) Laptops generally just have Integrated Graphics, BUT there are some models that Do have a Graphics Card, and there is the possibility of upgrading to a better one.
The above relates directly to Toshiba desktop computers, and laptops, as well as a reference to all desktop, and laptop computers.
To explain Integrated Graphics:
Another name for Integrated Graphics is OnBoard Graphics.
ON the motherBOARD.
The graphics chip is soldered directly to the motherboard.
[ Chip and Chipset are slang terms for I.C.
Integrated Circuit,
A graphics chip has a GPU on it, ]
Integrated Graphics borrows some of the system's resources.
The Processor and Ram Memory.
The Processor and Ram Memory are trying to take care of the Operating System, and the program that is being ran.
Two Operating System examples are Windows XP, and Windows 7. An example of a program that may be borrowing system resources heavily, is a game.
If an intense game is being played, the system resources cannot keep up with the demand for graphics, when Integrated Graphics is installed.
(Slow frame rates, or freezing. Poor graphics. Even with low settings)
A dedicated graphics card borrows very little of the system resources, or none at all.
A graphics card has it's own Processor, and Ram Memory.
(GPU and graphics ram memory)
In direct reference to Toshiba laptop's, post the laptop Model Number to see if the graphics can be upgraded.
There are some Toshiba laptops where this is possible, and some that are not.
(Post in a Comment)
The one's that use Integrated Graphics, and no dedicated graphics card, are the ones that cannot be upgraded.
Oct 29, 2010 | Toshiba Computers & Internet
White screen "
Your display problem may be in the graphics controller on the motherboard. It might also be in the display itself, which contains a lot electronics. Yet another possibility is that the system is freezing up completely, and the white screen is the result.
Since it takes a while for the screen to go white, the trouble is most likely due to something heating up. I've fixed a lot of laptops that freeze up because the processor chip overheats. Sometimes it's because the fan isn't working, or the screws holding the fan assembly down work loose.
Hook up an external monitor to the laptop for testing. You might need to enable the external VGA connector with a function key before you'll see anything. If the motherboard is freezing up, the external monitor will quit as well when the laptop display goes white. If the computer keeps working normally with the external monitor, though, you know the trouble is in the graphics circuitry or display.
Unfortunately, it's hard to say for sure whether the motherboard or display is at fault. My experience has been that a completely blank display is usually a motherboard failure, but not always. Failures in the display itself usually cause lines or other problems with the image, but you still see something.
Replacement motherboards are often available at reasonable prices, but displays often are not. You may want to take this computer to a service shop and let them figure it out and give you a repair estimate. That way you won't wind up buying a part that may be costly and not fix the trouble.
I hope this helps you decide what to do. Thanks for using Fixya!
Feb 10, 2010 | Acer (9005210464), (64 MB) Graphic Card
Upgrade graphics on a Asus psgc mx 1333
I remember the days when I was noobin' it up w/ my PC, and I also wanted a new video card. But that was 4 years ago. I know a lot more now lol.
To keep things simple, I'll say this:
You can fit any video card in there as long as it's for a PCI-E x16 slot, which is a lot better than say, the old school AGP slots.
The possible not-so-good news is that it's not PCI-E 2.0 x16 compatible, which rules out most of the newer cards. Is a great place to buy computer parts, as they usually have some nice deals on there. I built the computer I'm typing this on from there, so I've been a customer.
One of the great things about the site is the way you can filter things down, and by slot type is one of your choices that video card is probably the best one they have, and it's pretty cheap compared to newer cards. Don't expect to play the newest games on there, as this isn't all too great of a card.
If you really want to get into some good gaming, you'll need a new rig, which you can either build or buy (I recommend build....saves A LOT of dough)
Hope this helps ya out bud,
Good Luck :)
Nov 26, 2009 | Computers & Internet
Graphic Card Problem
there could be many things besides the graphics card. To start however, make sure your laptop recognizes your card and its drivers installed. Make sure your card is compatible with your motherboard. what is the model of your graphics card?
Dec 12, 2008 | Intel D101GGC Motherboard
Graphics card
OK, Your motherboard has a 'PCI Express* x16 bus add-in card connector'. It should be the closest connector to your processor. You can buy a card from ebay quite cheaply. A card like this would be suitable ->EBay UK Auction<- You will find like cards on EBay US if stateside.
Nov 02, 2008 | Computers & Internet
EliteGroup NFORCE4-A939 (NFORCE4A93910) Motherboard Logo
113 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
