Question about Frigidaire FDB1050REM Dishwasher
Frigidaire control panel not working
Frigidaire dishwasher won't work unless i turn circuit breaker on and then off (which resets the lights to blinking and then I can use any of the buttons.) After each load the green light is stuck on Clean and it won't let me press on any other buttons. My husband opened the control panel and unconnected the connector and one of the "sockets"? (holes) is browned. Does this have something to do with moisture and why it may not be working? I am worried about continuing to use i t if it might be a fire hazard? Any help is appreciated to help me figure out what to do to make my dishwasher back to normal and tell me what is wrong with it. Thanks much, Diana
  • 35 Answers
SOURCE: frigidaire gallery dishwasher fdb949gfb2
it looks as tho.you have a touchpad problem.the touchpad is malfuntioning.
Posted on Jun 25, 2007
SOURCE: Er message on panel of Frigidaire GLD3450RD
So should we be making sure they are aware of this and if its a common issue they should be fixing it free of charge....
Posted on Oct 29, 2008
SOURCE: Washing light flashes on Frigidaire FDB1050REM dishwasher
1) Turn off the breaker to the machine.
2) Wait 30 seconds and then turn it back on.
3) All the lights will be flashing. At this point turn the dial to "rinse only" and then press "Heat dry" and "Start/Cancel" at the same time.
4) The Machine will go into maintenance mode going through all the cycles quickly.
5) After this is finished the problem should be solved.
Posted on Jan 28, 2009
SOURCE: Frigadaire Dishwasher PADLOCK Icon lit, dishwasher won;t run
I have an FDB1502RGB0 model but had the same problem. I reset the circuit breaker and its working fine now. I'm not sure what caused the problem but it seems to be fine now.
Posted on Feb 11, 2009
SOURCE: frigidaire dishwasher FDB1050REB0 flashing washing light but doesn't start
I unplugged it and then plugged it back in and it worked, Whew! Didn't want to wash all those dished by hand!
Posted on Mar 02, 2010
Hi, I have a Frigidaire dishwasher, it has stopped working, when I put it on normal mode the "washing" light flashes but the machine does not start. Can anyone give some advice on how to fix? thanks,
Hello FJ, thank you for your inquiry!
I understand that your Frigidaire dishwasher is not working and all it does is flash the "washing" light. It sounds like a possible problem with your keypad or control panel. I would suggest performing a reset on your dishwasher and you can do that by flipping the household circuit breaker off for at least ten minutes. If that does not correct your issue I would recommend seeking assistance from a professional technician for proper diagnosis and repair. This will help you from purchasing unnecessary parts. -Matt
Jun 08, 2015 | Frigidaire Dishwashers
What is an i30 error code for frigidaire dishwasher
Hello friend, thanks for your inquiry!
On your Frigidaire dishwasher "i30" stands for aqua control. You should perform a reset on your dishwasher and that could clear any false error codes. To reset your dishwasher you can flip the household circuit breaker off for ten minutes. If that does not work you could be experiencing an issue with your water inlet valve or control panel. I hope this information has been helpful. -Matt
Oct 10, 2014 | Frigidaire 24 in. FDB1050REC Stainless...
Lights flash on my Frigidaire dish washer model #FFBD2407LW0A when trying run it through a cycle. will not start. When I turn power off and back on the heat lights flah.
Good Morning friend, thanks for your post!
Based off the information you have provided your Frigidaire dishwasher is not starting properly. I would recommend performing a reset on your dishwasher and you can do that by flipping the household circuit breaker off for ten minutes. If you continue to experience this issue it could mean that your control panel or keypad need to be replaced and I would recommend reaching out to a professional technician for proper diagnosis. Hope this helps. -Matt
Oct 06, 2014 | Frigidaire Dishwashers
My Frigidaire Dishwasher Model #FFBD2411NWOA won't turn on at all. I flipped the breaker switch and also checked the disposal which is on the same breaker. That is working. The dishwasher was working
Good Afternoon Friend, this is Z. Thank you for your post!
I understand your Frigidaire dishwasher (FFBD2411NW0A) will not start. Let's try resetting your dishwasher by flipping the household circuit breaker to the off position once again. It is necessary to wait roughly ten minutes and then turn on your dishwasher. Confirm that the door is securely closed and select a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: a potential wiring failure, damaged cord, faulty door latch assembly or control board. Because it could be a number of any one of several underlying causes, I would personally contact a professional to accurately diagnose your dishwasher to determine the root cause to reduce the risk of unnecessary parts. Best!
Aug 26, 2014 | Frigidaire Dishwashers
Frigidair 1000 series dishwasher clean light staying on and not able to operate until I turn circuit breaker off and on.
Good Morning Edward,
I see that you are having trouble with running your Frigidaire dishwasher, model# FDB1050REC, due to the "Clean" light being stuck on. I also see that regardless of you trying to reset the appliance, it might run through one cycle and then you're back to showing the "clean" light, and not being able to clear that light. It sounds to me like your control panel is having issues and might need to be replaced. I do suggest contacting a local authorized technician to diagnose the appliance, this way you're not just purchasing random parts.
-Best Regards-
WP
Mar 26, 2014 | Frigidaire 24 in. FDB1050REC Stainless...
40 duel fuel frigidaire/electrolux convection oven doesnot work self cleaner doesnot work .
Hello Walter Buford - Try resetting the range by either unplugging it or flipping the household circuit breaker off. Wait approximately 30 seconds and turn on the unit. Select the self-clean option or bake/broil option. If it does not turn on, then the temperature may have tripped the internal sensor of the unit and needs to be reset. This usually has to be done by a professional since the back panel needs to be taken off and the power reset inside. Possibly the unit may have a communication problem with the EOC (Electronic Oven Control) or faulty element(s). Personally, I would recommend contacting a professional for further evaluation.
Apr 14, 2013 | Electrolux Frigidaire Professional Series...
My frigidaire dishwasher model fdb641ras1 controle lights dont light and soap despser dosent open but machean runs
Hi glennjorgens - Try resetting the dishwasher by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and if it proves to be ineffective contact a professional to move forward accurately. Unit could possibly be experiencing a communication issue with the control panel or wiring failure which would need further diagnosing.
Nov 08, 2012 | Frigidaire Dishwashers
Frigidaire Dishwasher not working at all PF light on panel
PF is a general power failure error code. Reset the unit at the household circuit breaker for about 10-15 minutes, and retry.
Sep 03, 2012 | Frigidaire Dishwashers
My frigidaire dishwasher wont start
Reset the unit from the household circuit breaker. If nothing changes with that button function, contact a professional - the control panel may need to be replaced.
Jul 27, 2012 | Frigidaire Dishwashers
Jan 04, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwashers Logo
332 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
