Question about Kenwood KDC-MP235 CD Player
Kenwood dont know how to turn on the switchable subwoofer output. have everything hooked up but it doesnt work.
In the manual in the troubleshooting sections it describes how to set the preout mode and that fixed my problem even after I had disconnected my battery.
Posted on Aug 01, 2010
The maunal states the if you press the display knob down towards am for at least 2 seconds it will turn on. However, for me it did work, but i recently disconnected my battery and now it doesnt work so good luck.
Posted on Dec 29, 2009
I have a pioneer ts-w304r 12" subwoofer with a Dual Xpr520 400 watt amp, and a kenwood kdc-bt742u head unit. everything is hooked up properly. i know for a fact, and the head unit has all subwoofer options...
bad sub or amp. test your sub with a 9-12 volt battery not a car battery!!! more like a drill battery with low amp rating (don't leave power to it very long or could wreck your sub coil). if that work. then test your amp with a working output if you have a friend with a system hook it up in there car to see if it will work. pawn shops test amps tell them you want to sell it and they will test it and then decline their offer. lol just thought of that on the spot.
Mar 11, 2015 | Pioneer Car Audio & Video
My ksc-sw800 kenwood subwoofer doesnt have audio output,i conected the power,+ to posite of battery and GND to negative of battery,..conected audio to input while my i pod is palying audio but no sound...
The P.Con is the terminal that is connected to the (blue with white stripe) cable on the back of your head unit. If there is no (blue with white stripe) cable then there will be a (solid blue colored cable). This connection is used to turn the amplifier on and off when you turn your head unit on or off. The power cable from the battery is to provide power and not to turn it on or off. Think of the P.Con as the ON / OFF of your amplifier. If you are unsure of how everything else should be connected, then send me a list of what you have (models please) and i will help you out. Hope this will help.
dreamsystems
Feb 12, 2011 | Kenwood Car Audio & Video
I have a Kenwood kdc-mp342u car cd player installed in my truck. I have subs hooked up to it and everything was working fine until i had to reset my radio and when i reset it the "sub Level...
Subwoofer output: Hold the (AM-) button down for at least two seconds. You can do this function when "SWPRE" in is set to . The SWPRE (Switching Preout) Switches the preout between rear output ("R") and subwoofer output ("SW").
Nov 10, 2010 | Kenwood KDC-MP342U Car CD Player
Just stopped working
please check if the supply is still present in your amp using a multimeter. if you dont have a multimeter, check the fuse that supply the amp. a broken fuse will not turn the amp. let us know.
Apr 15, 2009 | Kenwood Car Audio & Video
Kenwood KVT-512 subwoofer
put it in standby mode first.. then switch the rear av-out to sub.. then you can turn the sub on/off
Apr 04, 2009 | Kenwood KVT-512 Car DVD Player
Any help you may give.....
try using diffrent rf leads. also check diffrent channels and if it still dont work try it on a diffrent head unit
Oct 03, 2008 | Kenwood KAC-7202 Car Audio Amplifier
Subwoofer Output Not Working...
first check that the subwoofer function on the actual head unit is turned up,second check that the gain on the amp is at bout half way then check that it is on a lp (low pass setting)
then check that the boost on the amp is turned up.
please leave feedback.
cheers
Jul 02, 2008 | Eclipse CD5405
Car sound system. only sub is giving off sound. other 4 speakers dont work at all
Could be bad outputs from the back of your head unit or also could be bad rca cables. Make sure the amp is on and powered.
Dec 13, 2007 | Kicker CompVT CVT654 Car Subwoofer
Sub-woofer output not working
"Sub-woofer output not working" problem, and notify you when a new solution is offered.
Press the setup key on the front of the receiver
Select the subw setting
Move the multicontrol knob until the sub woofer is on
Turn off the receiver and turn back on- the subwoofer should be on
The operator manual can be downloaded on the web site--- free
http://www.retrevo.com/support/Kenwood-VR-507-Receivers-manual/id/480ag219/t/2/
Sep 22, 2007 | Kenwood VR-507 Receiver
Kenwood KDC-MP235 CD Player Logo
262 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
