Question about Panasonic PV-DF2035 20 in. TV/VCR/DVD Combo
Sound on all channels except 2 network channels
The TV is fully "auto programed" for all channels. The sound works on all channels except for 4 and 5. The cable is working fine for those channels with all of the other TV's in the house.
5 Suggested Answers
  • 277 Answers
SOURCE: auto channel programming
The desgin of this unit is such that only the channel being recorded can be viewed. Try to manualy program channel 3 - p.25 in the user guide.. Good luck.
Posted on Jan 15, 2006
  • 8 Answers
SOURCE: No audio
are u using av cables for cable box or cable tv cable
Posted on May 04, 2007
  • 93 Answers
SOURCE: cannot program cable to tv
if your are using a cable box,all of your channels will be control only on the cable, what you are going to do is use the remote control of the cable box.
Posted on Nov 07, 2007
Universal remotes don't like combo units.If your original reomte worked before you lost it you are going to have to buy the original remote to solve your problem.
Posted on Jun 12, 2009
SOURCE: TV was receiving all channels offered by cable
Make sure the tv is set to "std cable". You can find this in the menu under antenna settings.
Posted on Jun 13, 2010
0 characters
1 Points
Can't get sound on channel 4 only. Any ideas? The sound is fine on all other channels and there is sound on channel 4 on my other TV sets. I've tried pushing the mute on the remote to see if it was muted...
You might try resetting the TV to the default (look in the Menus for a Options or Tools menu and a command like Restore Default or Memory Recall). Then exit the menu (and save the settings). Return to the menu and rescan all channels.
I do not know if this will help in your case but it is a simple thing to try. I have a tv (a different manufacturer) that had a similar problem. When my outdoor antenna was pointing directly at transmitter, the closest station gave me no audio on one sub-channel and no video on the other. All the other stations were fine. Doing the reset and subsequent rescan resynched the audio and video for the sub-channels.
I hope this helps.
May 22, 2010 | Zenith TVBR2742Z 27 in. TV/VCR Combo
Sound problem
when you mail me,i have an service manual for you
Apr 02, 2010 | Philips 20DV6942 20 in. TV/DVD Combo
Sound quit while watching TV
Try to do fine tuning with all tv chanels
Sep 28, 2009 | Initial DTV-322 32 in. TV/DVD Combo
Volume lock of philips vardan tv
I hv philips 21RF vardaan TV ,there is sound on AV channel. and the picture is blinking. even some menu setting have changed.. i tried using the service menu but cudnt understand anything. 2 new av channels have come.. av2 and front which were not present before. sound is not coming even on the other channels but picture is fine on them. only on the av1 channel it is blinking., the philips technision had solved this prob once by pressing some code by remote and i don't know the system code
Sep 10, 2009 | Philips 20DV6942 20 in. TV/DVD Combo
Sylvania 6719DC + E Circuit 6 in 1 Remote Control
I bought this at a Dollar Store and it works great.
1) Turn TV on. Do not worry about what channel.
2) Press and release TV1 button on remote. Depending on what unit your trying to sync.
3) Press and hold SET and ON buttons together for about three seconds until light begins to flash.
4) Release buttons, light will continue to flash and search.
5) Be prepared to immediatly press SET button when Television Set turns off. Be patient this may take a few minutes.
I wasn't able to find information on this. Just got lucky. Hope this information helps. Good Luck!
Nov 09, 2008 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
My Quasar VV8220
According to the manual, follow the steps below to program channels on your Quasar VV8220 TV:
1) Hold the CHANNEL MEMORY Button on your remote in and press the 1 key
(a box will come up where you can shift between TV & CATV --
you will want to be on CATV (for cable channels).
2) Press the 4 key which will change from TV to CATV -- make sure it is
on CATV or if it is already on CATV, press the 5 key.
3) Press the 4 key (the auto set guide will engage and go through the channels).
Hope this is helpful.
Aug 14, 2008 | Combination Televisions
Can I use another remote?
I have the same model TV, also without a remote. I found a Philips universal remote model CL019 at Big Lots and it works just fine. However, for some reason when I tried to program in the channels it would only program in up to channel 23, and then after about 15 seconds add channel 60. Can anyone help?
Jan 19, 2008 | Philips CCB092AT 9 in. TV/VCR Combo
Poor tv reception on my new lcd screen
Hi, sounds like the antenna. Maybe get an Aerial company to check it out for you as you might not be picking up a strong enough signal.
Dec 27, 2007 | Combination Televisions
No Sound
First of all try getting a Symphonic remote - not that expensive. Then you can access all areas of the TV, including all sub menus and see how the audio is set-up.. Could be you have it in SAP mode, (Second Audio Programming), in which case you will hear nothing...
Nov 19, 2007 | Symphonic SC519DD 19 in. TV/DVD Combo
CCVG297 broksonic 9" TV
When the channels show up in red thats an indication that they are not programmed into the TV set. Your going to need the original remote, go into the menu and then press auto scan with an attenna attached to the set. If it wont scan then you have a bad microprocessor
Sep 25, 2006 | Broksonic CCVG297 9 in. TV/DVD Combo
Open Questions:
See all Panasonic PV-DF2035 20 in. TV/VCR/DVD Combo Questions
Panasonic PV-DF2035 20 in. TV/VCR/DVD Combo Logo
23 people viewed this question
Top Panasonic Combination Televisions Experts
Are you a Panasonic Combination Television Expert? Answer questions, earn points and help others
