Question about Mk Diamond MK - 170 Wet Cutting Tile Saw
Blade replacement on mk-170 tile saw.
Time to replace blade. Lost owners manual. Cannot get nut loose on shaft. Can shaft be locked somehow to get nut loosened?
Thanks
  • 3 more comments
  • earm0007 Sep 17, 2013
    Bought mine at an auction for $30 ... great saw ... cut granite so thick I have to cut from front and back ...can't find a drive belt for it ... anyone know the right size ?? Anyone have a manual for this saw that may LIST the drive belt size, source, other good stuff...
    Found the MANUAL!!! Go to http://powertool.manualsonline.com/manua...
    OOPS! got multiple posts ...scroll down the list of manuals until you find : 46225 - Harbor Freight Tools Assembaly and Operating Instruction 10" TILE SAW 46225...that's the good news .. the bad news is that it is a minimal manual ...and did not give the &^%^*&&^%^$#@$# belt size !!
  • 76 Answers
Take a pair of good vise grips and hook onto blade tightly, slide uo against back braket. that will hold the blade from spinning while you remove the nut, try bumping your ratchet/ wrench w/ a rubber mallet or hammer. hope this helps
Posted on Nov 05, 2008
My T250B has a spring return pin to the left of the blade on the housing. UNPLUG the saw ...hold this pin in the down position and rotate the blade with your hand ... the pin will fall into a hole in the shaft and hold the blade while you undo the nut ... may need three hands ...*L*
Posted on Sep 17, 2013
I am not sure I can be any clearer than to say the saw dooes not cut the tile square.
the problem is probably the slide cart you set tile on to push it into the blade,on the right side theres a roller you can adjust the the height of the tray,or look at the very bottom of the cutting arm,left hand side,on the outside,where its painted red, theres 2 bolts that hold the cutting arm to the frame of the saw body,try this first, i bet nuts got loose and the cutting arm dropped a tiny bit screwing everything up
Dec 28, 2010 | Mk Diamond Mk Tile Saw Mk-101 Pro24 10in
Saw is not cutting true / will not cut a straight line ?
Check blade is on properly. Remove blade and clean area where mounts to shaft. Make sure proper washers are in place. If blade is bent or wobbles replace. If blade is dull replace. Be sure you're getting enough water to saw. Don't force the tile through, let the saw do the work. Nothing helps any kind of saw more than a nice new blade.
Jul 01, 2010 | Diamond Products Mk - 101 10" Tile Saw
Looking for shaft lock to change the blade on MK 170 wet saw
Just use a rag and grab the blade. Unless the threads are messed up you don't have to hold the arbor still, just the blade.
Apr 27, 2010 | Mk Diamond MK - 170 Wet Cutting Tile Saw
How do I remove the blade from a Makita MK470 tile saw? I can't figure out how to hold the saw blade so that I can turn the nut hodling it on. The nut is on pretty tight and I need to lock the blade so I...
There is not a lock on this saw. If the blade is to tight to hold by hand you need to use an impact wrench. It will loosen the nut before the blade has time to start spinning.
Nov 11, 2009 | Saws
How do you remove the blade on tile cutter model mk470 mk diamond products, inc
Unplug the saw, raise the guard fully, grasp the blade to hold it and loosen the nut then remove the blade.
Sep 12, 2009 | Mk Diamond Products, Inc. 7 In. Wet...
MK water saw - water goes every where but on the blade!
When you say you turn the pressure up, I presume you mean you are opening the suction on the side of the pump.
On the saw which I have used in the past it is difficult to aim the warter spray. I opted for more water (open the suction on the pump) and let it go. most of it went onto the saw blade - some went onto the tile, some on me and some on the wall --- put a piece of cardboard or something behind your saw to help contain the overspray.
Sep 07, 2009 | Mk Diamond MK - 170 Wet Cutting Tile Saw
The saw in not pumping water
I have came across to possible solutions with other tile saws in the past. One is that your pump could have picked up a small piece of tile or sedement from the basin and got stuck in the water port where it comes out on to the blade. The first thing I would try is to disconnect the hose frome the blade shroud while saw is off. **** on the end of the hose until you get water. Sometimes the line needs to be primed and filled with water. Once you get water you can turn the pump or saw on while disconnected to see if water flows. Keep loose hoses away from blade though! If nothing then try the blocked port. Good luck
Dec 03, 2008 | Mk Diamond MK - 170 Wet Cutting Tile Saw
RYOBI TS254 change saw blade???
should have blade lock button remove blade with proper size wrench reinstall new blade in reverse remember some of these the loosening of the blade will be clockwise so if nut dont come loose try clockwise to loosen good luck
Apr 22, 2008 | Irwin Miter Saw Laser Guide Attachment...
Mk Diamond MK - 170 Wet Cutting Tile Saw Logo
2,488 people viewed this question
Top Mk Diamond Saws Experts
JonSnell Electronic
JonSnell Electronic
Regalo Tiles
Are you a Mk Diamond Saw Expert? Answer questions, earn points and help others
